tlevine
Posts posted by tlevine
  1. I have finally finished the upper deck framing.  The first three photos show the deck before final fairing.  The last two are after everything has been sanded down.  I started with 100 grit and progressively sanded down to 400 grit.  I finished with a razor blade scraper.  There was a slight hump in beam 20 which was corrected with the sanding.
  2. Druxey, the counter timbers are safe (so far).  David, I've seen your hands!  But even my fingers are too large for some of these spaces so I do most of the fine work with needle holders and jeweler's forceps.  A needle holder is similar to a hemostat but it has no deep ridges and the joint is much closer to the tip.
    Ed, I did just as you suggested a few frames forward but these beams are too short to spring them sufficiently.  It is almost as easy to temporarily glue the knees to the beams in situ, mark their positions, debond, rebuild off the model to drill bolt holes and re-install using the bolt holes as a guide.
    Ben and David, thanks for looking in.
  3. Ed, Nils, John and Ben thank you.  Hope to have some more progress this weekend.
    What I am discovering is that fitting everything together in these last few beam sets is a logistical challange.  Because the hull is tapering, I can no longer slide a beam/knee assembly in to place.  Right now the best sequence is of construction is beam-carlings-ledges (to stabilize the carlings and prevent lateral shift)-hanging knees-lodging knees.  For final gluing, the lodging knees should be installed before the hanging knees.  Finally, the ledges between the outer carlings and the lodging knees are installed.
  4. It has been a few weeks since the last update.  Not that much has been accomplished because of that four letter word...work.  I have all of the carlings temporarily installed, as well as the ledges between the carlings.  I am still adjusting the height of the last two deck beams.  The transom knee was made overly thick and now the top of the beams is lower than the top of the knee.  The knee will be sanded down once I am happy with the fair run of the deck. Beam set 16 is completed.  Only six more beams to go!  The bracing across the outer counter timbers has been removed for the pictures.  I decided not to build any more structures that stand proud of the deck until the deck is completed and sanded fair.  The main mast partner kept getting bumped when I was truing the middle part of the deck.  This should make sanding easier.
  5. I also used brass rods for mounting.  Both the rods and the "fancy" base came from Hobby Lobby.  I did not taper them but I did drill a pilot hole in the keel assembly prior to press-fitting them in place.  I then removed them until the model was completed.  Keep in mind that the model weighs next to nothing so minimal strength is required for the mounting supports.
  6. I used castello boxwood for my planking.  My approach was different from the kit instructions in that I spiled the planks in a more prototypical manner rather than attempting to edge-bend them.  I did not have to soak any of the planks.  The castello is a pleasure to work with.  It holds an edge and there are no fuzzies after sanding.  I did not apply a sanding sealer...a must if you are using the enclosed basswood.
  7. My general approach for fabricating and installing the beam sets has been one complete set at a time.  This worked well where there was no curvature of the hull but I had difficulty with the run of the outer carlings at the fore end of the upper deck and decided to change my approach as I neared the stern. I set out all of the beams and tack glued them in place.  I then drew fair lines for the outer carlings.  The deck beams were removed as I worked on them, only mortising the outer carlings.  The carlings were then tack glued without gluing the beam.  This continued until the last two beams.  The transom knee abuts the for end of the transom and extends along the hull just past beam 20.  It is set down on to the deck clamp and "bolted" to the frames and transom.  The last two beams are mortised into the transom knee.
    The pictures show the run of the lateral carlings.  No finish shaping or sanding has been done yet.  I broke off the port counter timbers (again!) and just stuck it back on so that area looks out of whack.  I will probably have to remake it when it comes time to make the counter.
  8. You are absolutely right Remco.  In fact, I have a tripod in my car trunk and on occasion I do use it.  Just lazy I guess.  Also, the dog has knocked the tripod over in the past (thank goodness the camera was not mounted on it at the time) and once I open it up I tend to leave it open the rest of the day.  The dog is on vacation this weekend with the husband, so I will drag it out of car.
  9. J.D., my cameral setup is anything but fancy.  I use a Canon T3i camera fitted with the standard lens (18-55mm).  I turn on all the lights in the kitchen, hold my breath so I can use shutter speeds of 1/60 and hope for the best.  Sometimes I use the built-in flash but that normally gives me too much shadowing.  Needless to say, I take 4-6 shots of the same thing and save the best one.  A macro lens is on my "someday" list, along with a mill, a disc sander, a Jim-saw...
    David, see you in a few months.
  10. Work progresses slowly on the upper deck framing.  No pics this week.  The next significant structure to construct is the capstan step.  In TFFM this is shown as a roughly rectangular block of wood inserted between the beams and its supporting carlings.  On the Atalanta plans there is a ovate structure instead.  This would seem to have much less strength than the one suggested by David.  I am looking for some help on this one.  Is the structure shown on the plan correct?  Or is this seated on top of a rectangular step?
  11. John and Elia, thank you for your kind comments.  Thanks for all the Likes as well.  A little more has been accomplished this weekend.  I have applied the finish to the pantry.  Beam set 14 has been installed and beam set 15 is in progess.  The middle carlings are larger to support the capstain partner.  Unlike the carlings for the mast partners, this piece is installed like a regular carling (ie from on top) rather than under the beam.
  12. The pantry is located on the lower deck in front of the ladderway.  It is constructed with partially louvered walls like the sail room.  In contrast to the sail room, there is a standard swinging door rather than a slider.  I finally tried to cut the slat mortises on the table saw.  I had to free-hand their locations as I could not quickly develop a jig.  A piece of 1 x 1 mm brass clamped down to the saw table would have done the trick but I did not have any and when I tried to cut wood this dimension it disintigrated.  I think they came out reasonably well.  Next time I would run out to the model railroad store a few towns away and buy the brass square as the mortises look better even though once the slats are inserted there is really no difference in appearance.
    The plan shows the door underneath the beam (not installed on these pictures).  I found this odd because this would limit the door height and also because a support stanchion could be incorporated into the door frame if the door was located between frames.  I built the door in the location shown on the plan.  I also decided not to put a pillar under beam 13 as this would end up in the middle of the pantry and restrict the storage possibilities.  A stanchion on the starboard wall will be the substitute for the pillar.
