Keith Black
Everything posted by Keith Black
  1. Thank you @Cathead @Roger Pellett @mcb @AJohnson @wefalck @mbp521 @Rick310 @mtaylor @BANYAN @Glen McGuire @Knocklouder @Bob Cleek @My Fathers Son for your Holiday wishes, kind thoughts, and support and thank you to Andy, Siggi, Tom, Dave, and Phil for the likes. It's been busy times at the worktable, I got the gaff rigged and the lifts around the foremast rigged. The blocks at the base of the mast sit at the edge of a diameter the size of a US penny, .75 inches. The distance between the block's inside edge and the mast is .2 inches and .1 inches between the belaying pins and block's inside edge. The block (gaff lift) between the companionway railing is so tight I had to glue the block's sheave side perpendicular to the mast and once rigged, it was twisted 90 degrees to line up correctly. It's kinda like SIB work without the bottle, it's all done with tweezers. The main problem is the thread wants to hang up on everything and the belaying pins are easily bent out of position. I really don't care how long it takes to preform a task at this scale as long as I'm successful. Sometimes the result is more suggestion than 100% accuracy and that'll just have to be okay. I worked Christmas Eve and most of Christmas Day.....'the blocks were hung by the foremast with care in hopes that' Thank you for following along and smooth sailing to all throughout the New Year. Keith
  2. Chris, Merry Christmas and Happy New Year to you and yours. Two nice looking Pups.
  3. Aleksandr, great post. Happy Holidays and a Happy New Year to you and yours.......Keith
  4. Andrew, welcome to MSW. Merry Christmas and Happy New Year. Glad to have you aboard.
  5. A long past due 'hello' to all. The last time I posted a meaningful build addition was April the third. We ran down a couple of rabbit holes and while I throughly enjoyed the tangents they didn't add to the task at hand. Once again, thank you to all who helped chase those pesky wabbits and to all for the likes. The hiatus was due in most part because I absolutely detest working on shrouds but I have managed to strop the 56 deadeyes for the main's lower shrouds and have one pair lashed. Pretty good for nine months, eh? My mind wasn't in a good place, stropping deadeyes is tedious rote work and once my fingers are engaged my mind slips into neutral. My thoughts kept going back to unhappier times and I couldn't shake it so I basically quit working on the Tennessee. Last week I thought, if I couldn't get over the shroud hump there is still plenty of other work to be done. So this past week I worked on getting the work table/area organized, installing the foremast for the last time, and installing the lift blocks that go round the mast which required some finger retraining. What a difference in my attitude and my enthusiasm. The Tennessee is back on the menu! As the Tennessee now sits. Foremast installed. Lift blocks installed. A Merry Christmas and Happy New Year to each of you and your families. Thank you for the kindness you've show me through the years.......Keith
  6. Peter, Merry Christmas and a Happy New Year to you and yours. The Sark is looking wonderful.
  7. Siggi, a very Merry Christmas and Happy New Year to you and yours.
  8. You are truly blessed, Mr Keith. A very Merry Christmas and Happy New Year to you and yours.
  9. Richie, welcome to MSW. Glad to have you aboard.
  10. Javelin, this is a neat little model and I'm sure your son will treasure it forever. Happy Holidays.
  11. Bob, sorry to hear you and all yours are sick, get well and have a Merry Christmas.
  12. Carter, welcome to MSW. Sounds like you hail from the world down under? Glad to have you aboard.
  13. 3M developed a UV activated Bondo and it sounded like the cat's meow so I purchased a can and proceeded to use it on filling the body panel on a car I was restoring (I can't remember which one). Once I had the panel filled I sat it out in the sun for the recommended amount of time and it was still soft. I allowed another couple of hours, still soft. I let that stupid panel sit for two days in the sun and it never hardened. I finally had to dig and scrape every bit of that worthless product off the panel. UV activated Bondo sounds great and might work......if you live on Venus. Roger, if you requiring more working time use less hardener. Work with small batches versus one large batch, slow and steady wins the race.
  14. Great YT videos and the results in the final photos is truly fantastic, Glen.
  15. Hank, welcome to MSW. Thank you for your service and I hope you're able to locate the necessary tools. Glad to have you aboard.
  16. The sails turned out incredibly realistic making the whole totally believable. Fantastic job, Mr Glen.
  17. I can see a ship's boat being towed in favorable weather as a matter of course but in rough seas, with the possibility of being swamped or separated from, I suspect the the ship's boat was brought aboard and lashed down.
  18. SJ, welcome to MSW. I don't have the answer to your question but I'm sure someone will have one for you shortly. Glad to have you aboard.
  19. I look forward to your Kearsarge build, this transitional period in ships absolutely fascinates me.
