GrandpaPhil
Posts posted by GrandpaPhil
Aft deck pieces are now doubled.
Due to a minor issue resulting from the placement of my templates on the poster board and the page split of the plans in the book, I had to cut the deck pieces between bulkheads 1 and 2 and remove about 3/16”.
I have the forward deck pieces and bulkheads permanently installed. As soon as they finish drying I will pull the aft deck pieces and double them.
- mtaylor, GrantGoodale, Nikiforos and 4 others
- 7
10 hours ago, Omega1234 said:
Hi Phil
Talk about a ‘challenge’...this has it in spades! No doubt you’re up to it; especially with the very promising start you’ve made already.
I’ll be following along for support and encouragement.
Have a great Christmas and New Year!
Cheers.
Patrick
Patrick,
Thank you and welcome aboard!
Have a Merry Christmas and a Happy New Year!
Phil
12 hours ago, Wallace said:
I have to take my hat off to you Phil, I am impressed with what you are doing. It looks like it is a very steep learning curve but hey, that's why we do it right?
Thank you! Much appreciated!
I’ve definitely been learning a lot with this project!
I’ve answered all of my own questions about rescaling plans and transferring from the books, just by doing it.
I doubled the forward deck pieces, which should remove the waviness. I will double the aft deck pieces after I install the forward frames permanently.
Amazing work on both the Sovereign Of The Seas and the Royal Katherine!
- DORIS, BETAQDAVE, FrankWouts and 3 others
- 6
I also need to double the deck pieces
- jct, popeye the sailor and mtaylor
- 3
- CaptainSteve, ccoyle, RdK and 4 others
- 7
Quick question, what’s the best way to install a transom on a card model?
Should I just build up the stern frames like any other model, or just glue it to the stern after installing the deck and covering the hull?
Thank you for the information. I’ll remember that for next time. There are several ships in his books that I would like to build. Buying the plans in sheets would be very convenient.
I never actually scanned these, I just traced them and enlarged the tracings. This has been a highly educational project. I’ve been learning a lot.
It’s been a lot of fun too, I’ve never built from scratch before.
The only drawback to the posterboard is that I am having to double it in order to build up to the 1mm thickness that Ab mentioned in his tutorial. But, so far so good.
I traced the deck camber from Zu Monfeld and enlarged it to make a template which I transferred to the bulkheads.
I’m currently in the process of doubling the bulkheads below the main deck to gain more area to glue to.
Great way to make gratings!
- mtaylor, jct, thibaultron and 1 other
- 4
On 12/11/2018 at 9:44 PM, Wallace said:
They say a change is as good as a rest. It will be a pleasure to follow along with this one Phil.
Mark,
Thank you, much appreciated.
The Victory is on temporary hold while I build the Prince de Neufchatel from Chapelle plans. I’ll be back shortly.
- popeye the sailor, Nikiforos, RdK and 3 others
- 6
Prince de Neufchatel by GrandpaPhil - FINISHED - 1/72 - CARD - from Chapelle Plans
in - Build logs for subjects built 1801 - 1850
The deck is now installed and the glue is drying.
