GrandpaPhil
NRG Member-
Everything posted by GrandpaPhil
Looking good! I added “planking” to mine. However, this being a steel ship, you could always add plating made of thin card. That would cover the hole too.
Welcome!
Hello from Kiowa, Colorado
GrandpaPhil replied to Doug from Kiowa's topic in New member Introductions
Welcome! -
Welcome!
Welcome!
Alright, I figured out the 1/8” diameter deadeyes: It took me two hours and nearly 20 attempts to get 5 good ones. I need 30 of them. First, I mark the holes. Second, I use a straight pin as a center punch. Third, I drill the hole. Fourth, I cut the groove around the deadeye with my trusty scalpel. Fifth, I cut the deadeye off of the dowel rod with my trusty razor saw. Lastly, I CAREFULLY finish drilling the holes. All movements throughout this process must be slow and measured or the deadeye will disintegrate.
Welcome!
Welcome!
Speaking of deadeyes, here’s 40 x 3/16” deadeyes. I only needed 36 of them, but I always make extra. These are not anywhere near as nice as machine made deadeyes or those made by other people on this forum, but they will fulfill the function and look decent once installed. I’ll clean them up a bit when I ink them brown. I need 30 of them now that are 1/8” diameter. Those will be interesting.
All eyebolts are installed in the hull. Touch ups are done. The hull is now ready for final sealing and weathering. I have to let the model dry overnight so the paint can cure prior to sealing. This prevents paint bleed over. Once the sealant dries I’ll drybush the hull to make it look well used but well cared for. Then I’ll run a drill bit through all holes to clear them. After that it will be time to install chainplates with their respective fittings. Somewhere along the way the hull rigging will get done to include the anchors. I’m getting ready to make the deadeyes now.
Alright, I did some research. I have a plan, have perused my plans and have a good idea of what I need to do. I just found out that I will be making multiple types of blocks, including some that I had never heard, such as the ramshead block and the Continental lifting block. I have heard of fiddle blocks, but have never used them. The learning process is half the fun for me. I am thoroughly enjoying this model. I have only completed two square rigged vessels, but neither had even half of the rigging that they should have, so rigging this model with a full set of rigging lines will be a first for me. The major benefit is that after I build this, the Revenge should be a lot more manageable. Now to finish the hull fittings and get the rest of the painting done. Then I can add hull rigging. The deadeyes and chain plates, along with the covering pieces will be among the final pieces that get added to the hull.
All primary fittings inside the bulwarks are complete and installed. I have two pieces to make for the hull, sheaves that one set of rigging lines run through. Then I need to complete all touch ups, seal the model and apply all weathering coats to make this ship look well used, but well cared for. I want this ship to look like some guy’s livelihood that he used to take care of his family. That is my goal. This looks like the 17th Century equivalent of an owner-operator’s Mack Truck to me and that’s the look I am going for. As soon as I figure out how I am going to rig this model, I will complete all of the rest of the eyebolts and other secondary fittings required to belay everything. The masts, sails and standing rigging are easy. It is tracing out all the running rigging and where to belay everything to that is difficult for me. More the belaying part than anything else.
