GrandpaPhil
Everything posted by GrandpaPhil
  1. Very impressive collection! Excellent work!
  2. I’m not aware of any Napoleonic R/C kits out there, but you should check out Jerry Todd’s R/C builds. He has built the Constitution, Pride of Baltimore, Constellation and Macedonian as R/C models. There is also a book called “Building a Working Model Warship: HMS Warrior 1860” by William Mowll that talks about his R/C Warrior. I actually just ordered that book after reading Jerry’s build logs here.
  3. There’s a discussion going on, on another build here which is discussing using a 45 degree planking technique to make a lightweight, but very rigid hull, especially after 3 layers. I may have to try that planking technique for the inner hull because most of this model is going to be covered in either wood grain contact paper, “armor” plates or copper tape anyway.
  4. Your educated guesses have been really good up to this point! I would trust them any day!
  5. Very nice technique! I’m going to have to try the 45 degree planking trick! I cut everything out with a scalpel.
  6. I’m just using card. For your windows, I would do them in two pieces from cardstock. One outer frame and then make an inner frame to get the same effect as 3d printing them.
  7. It’s the same thing I did here. That’s a binnacle at 1:98 scale. I used layered card for the impression of detail.
  8. I would personally recommend Vanguard Models’s Cutter HMS Alert or one of their fishing boats for a good starter kit. The gentleman who owns the company and designs the kits, Chris Watton, is a member of this forum. His kits are top notch. The instructions are phenomenal.
  9. This model is incredible! What about double layered card, sealed? I’ve had a lot of success making mass small detail parts from it. I’ll be making the window frames from card, for another model later this year.
  10. The Main Deck Rope Coils are on: There’s a band that goes around the base. I only put the bands around the ones at the Foremast, because I don’t think it adds anything to the model at this scale and actually detracts from the appearance.
