Posts posted by Sea Hoss
Thank Yves and Mr. T, also for the likes all! Yes Yves, sometimes hard to get the ball rolling again...But I find once I get started on a build again, the hours blaze by and I find that it's 2AM! Looking forward to see both of your build logs to resume. Also I must add; pardon most of my picture's quality, my phone is junk and therefore, the camera is too. I should buy a decent digital camera in the future.
More done on ECB, wet well installed, left the starboard side open where the look through will be located. The forecastle sole is in with a cut out for the mast. Cabin sole and bunks are in also. Next up, ceiling planks then paint the interior before framing the deck. This is a fun little model, lots of detail crammed in.
From what I can see, you are certainly at least "an advanced beginner". Looks great so far!
- PeterB010, Duanelaker and KurtH
- 3
All frames have been beveled and installed. Transom shaped and beveled then attached to horn timber-knee-box block unit.
Haven't posted for a little while but I have been working on her here and there. For my first real POF attempt, this kit is not for beginners! The manual is not very easy to follow... I realized soon that most of the build will require constant referral to the plans. But that's cool, the plans have lots of info. Many detail shots of the trickier areas. So, bust out the measuring tools and get in that mode of thinking. So, the frames are beveled and installed.
I have also started Emma C. Berry a short while ago. I am now ready to begin on the frame work. Thank you for pointing out the problems that you encountered at this phase. I shall try to keep them in mind to avoid the problems. I will watch with interest as you progress and maybe gain some insight what is to come...
Great job! So much detail... The sail is perfect and mounting it on the whale is genius!
Had to shelf my USS Essex, too many missing parts and directions! Frustrating! Picked The Emma C. Berry for a good price and thought it is a good scale and very sexy ship. She was built and launched down the way in Noank, Conn. in 1866. Known as a "Noank Smack" fishing vessel. Got to it building the keel/skeg section, then putting together the build board and keel support unit with the frame clamp fixture. Ready to start the frames!
- gjdale, ccoyle, EricWilliamMarshall and 3 others
- 6
Fantastic work! Looks perfect, this build is great.
- ferretmary1 and Ondras71
- 2
You do great work my friend!
- popeye the sailor and J11
- 2
Just looked this build over again (I'm getting ready to dig into my little USS Essex solid hull version with determination!) this model came out great! There's so much detail! My model is ancient...boxed in 1957! got it on ebay for $15. I know by looking over yours that I'm missing a lot of parts and pieces. It's going to be a sort of 3/5 ths hull mounted on a backboard of some type. just to hang on a wall. So I wont get crazy withit, just for fun till I pick up a kit that will take some real time and attention to detail (and probably more tools!). Great job though!
Yes, I would sand the deck down till it feels smooth to your fingers. You can also throw on some light stain if desired, some do, some don't. I usually put on a couple coats of satin polycrylic by Minwax. Leaves a little sheen but not too glistening. Then I would generally hit it a little with 00 steel wool. This also seals the wood to moisture. This is a great model to begin a long learning but highly satisfying hobby. I'll enjoy your progress on her.
That's how we do it, adapt and overcome!
Your model looks great! First build of this type, you did a nifty job.
Emma C Berry 1866 by Sea Hoss - FINISHED - Model Shipways
in - Kit build logs for subjects built from 1851 - 1900
Been working on The Emma C. slowly but surely. Stained interior areas that will remain that way, started on the ceiling planking as described in the manual.
