Everything posted by cog
Darn, I like that tower, Dan. I think I'll just stick to plastic and PE, this is out of my league ...
Ah, Jack, 't-is a wee bit awkard, but you'll get used to it ... one step forward two steps back ... You do, however, get a fair bit of practise!!!
Lou, A fellow bent person ... You should try Yamato/Musashi with the old tool from Tamiya. I do not even have to be sent around the bend look for my build log of Musashi ... (thought the pun was quite nice )
- 1,090 replies
- showcase models
- vendetta
Nice shots RGL Not rough weather ... mebby rough sprayin' ... today's harvest colour: Vallejo Fire Red (71.084) Found a picture of the funnels, which will be "enhanced" next. I expect a lot of time for a few very tiny items ... PE can send you round the bend
- 1,090 replies
- showcase models
- vendetta
So, Denis, what did you order for father's day?
- 1,090 replies
- showcase models
- vendetta
That's because there seem to be enough watchers
- 1,090 replies
- showcase models
- vendetta
Yupz, no time to sit on the couch with wifey, and watch a royal wedding
- 1,090 replies
- showcase models
- vendetta
Primed the hull, and copied the lines from the page with the paint schemes. Those I scratched in the hull with a knife.hope those stay visible
- 1,090 replies
- showcase models
- vendetta
Minor progress, mixed PE, i.e. partly kit, partly stock. The searchlight has but one part from the kit ... the little plastic pillar it is mounted on ...
- 1,090 replies
- showcase models
- vendetta
- 1,090 replies
- showcase models
- vendetta
- 1,090 replies
- showcase models
- vendetta
- 1,090 replies
- showcase models
- vendetta
Convincing an Admiral is never easy ... but yours is very understanding - at least, that's the impression I get from her. So did you order the Hood set or went for the simple selection, and being able to get yerself some other stuff on the side (like a PE tool )
- 1,090 replies
- showcase models
- vendetta
I always cut plywood with a saw, if I needt to do a "neat" job I'll make an incision first on the line to cut to avoid the splintering it does so easily
- 171 replies
- krabbenkutter
- authentic models
It's very shiny, I wouldn't have expected that. I love what you achieve with a simple brush, very impressive!
Denis, you do not need the hood set, to much PE for what you need If you want to add to the build, get some triple railing, 0.3mm 0.5mm and 1mm brass rod/tube, you could instead use Evergreen for those measures. You would want bollards, as those in the kit are a pain to cut, clean up, and actually use. Brass water tight doors, Bitish version, since I got loads of IJN I used those. Northstar has bridge furnishings, at 1/350 in resin. I ordered those too. The guns I got from shapeways. The mast I made from 0.5mm brassrod and 1mm brass tube. If you limit yourself to that, you'll be saving quite some money ... I have some PE from Eduard for Musashi, but am not thrilled about it, so beware RGL, you'll have to wait. Can't get the right contrast with the evening lighting. because of their colour. I'll have to try it with daylight, and hope that'll work Royal wedding ... no, nothing up North here ... probably not invited
- 1,090 replies
- showcase models
- vendetta
No I liked these better, when I look at the parts to make one, I knew before hand I can't get them as smooth as these. Furthermore, for me postage was good ... better than from the States. They are called 3D frosted print, not clear plastic. I ordered the torpedo tubes from them as well. I have a broken tube in the kit, how on earth that happened I wouldn't know. Ordered somewhere else 1/700 bollards, as all or most 1/350 available are to big, and those in the kit are impossible. Didn't know you are that old very devious mate
- 1,090 replies
- showcase models
- vendetta
Today's progress ... and the mailman brought a present, 3D printed (on demand) 102 mm V & W class guns
- 1,090 replies
- showcase models
- vendetta
Glad it wasn't more serious, Nils. Glad I can't see it, since it didn't happen Great recovery!!!
- 692 replies
- eagle of algier
- chebec
Bending sharp edges on brass strips
cog replied to Sandor Laza's topic in Metal Work, Soldering and Metal Fittings
Mr Laza, Have a look here and here you might find them closer to home if you search a bit. Most brass will have a somewhat roundish edge, you could try and file it slightly down to a sharp shape. Having said that, bending will always leave a round edge, you can get a straight sharp edge by soldering two pieces at e.g 90º The size in modelling, however, has it's limitations ... at least that's my experience as an amateur -
So far I've been lucky (nock wood) not much flying around, with total loss. Although, it will certainly happen one of these days, as parts to be used shrink further ... I didn't like the brass canvas option either, haven't fitted any yet. I am pondering on options, tissue paper, or shoji paper are the ones which remain for me. Have to do some testing ...
- 1,090 replies
- showcase models
- vendetta
