Everything posted by cog
Nice, looks very promising. Didn't have the second item (crane-ish things) in full PE?
"aside from resorting to the use of a two stage epoxy, I have yet to find a suitable cement for it." I used UHU on both Smit Rotterdam and Smit Nederland, which worked rather well, if I may say so
- 453 replies
- thermopylae
- sergal
"There appears to be quite a bit of extra length behind the collar." On my plastic build I had to take some lengths off the brass turrets too (nearly 2 cm!) so that doesn't make me wonder
When you find them, let me know where I can get a pair!!! Now Slog mentionned it, I wondered what that ridge/ring was for ... but the difference in scale = 1/200 vs my plastic 1/350 - put me off too ... so much more details ...
captcha is browser problem. If it happens on Firefox, try chrome, or Edge.
- 455 replies
- slightly modified
- greyhound
Dennis, According to Evans' Waka Taua, most were painted red (shark liver oil & either red ochre or burnt karamea clay pg35)
Why do you use a brilliant laquer instead of a matt for the cask(s)?
- 692 replies
- eagle of algier
- chebec
I prefere the Very Old Gouda (the one with salt christals in it ) a very old farmer's cheese from around Gouda would be even better ... I cannot imagine sculpy being like that ...
- 305 replies
- utrecht
- statenjacht
Just one I broke three, but my hull was/is resin, does that give me any credits when I buy a new set!?!?
The Holiday season is nearing ... which is a bit dual ...
You are quite accomplished at soldering Mark. I wouldn't have tried to solder stainless steel though ... still wonder if such a weld would hold at all ... so maybe it is a bit of luck it isn't stainless Cheers
If this planking is not your definite layer, you need not be very accurate. A smooth finish would do, the run of the planks is less important. like this The final layer defines the look and feel of the hull in the end. If the final layer, you will have some steelers e.a. to make
- 455 replies
- slightly modified
- greyhound
Nice idea though Vossie. You can watch a flying example in the last revision of the Three Musquetiers movie
- 453 replies
- thermopylae
- sergal
It does, as a few other brands do. Actually, TS17 and XF16 ... may be what you need see chart Tamiya Colour Chart.pdf
Have a good look at ladders, and things which needs to be installed first as other bits will run over them ... I made that mistake, and I seem to see rungs crossed bij those horizontal rails/rungs or whatever you call them ... I like those louvres better than the pontos part. Although, I wouldn't know if it is better in view of contemporary usage or not
HMCSS Victoria 1855 by BANYAN - 1:72
cog replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
As Russ wrote ... uncanny- 1,005 replies
- gun dispatch vessel
- victoria
You might try a sheet of thin paper in front of your working lights to diffuse the light ... looks pritty spiffy though
Looks like a lion which needs to go urgently to the john ... Nice picture though
- 305 replies
- utrecht
- statenjacht
Nice work, Dan, how did you cut out the ring itself, what I see the punch doesn't meet that circumference ...
