Everything posted by cog
HMCSS Victoria 1855 by BANYAN - 1:72
cog replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Does the lower part slide in between the upper parts sides? What I mean is is the upper part a U form or just a plain strip. If a U form, you can have an etched part with two folds, you can still use your nut and bolt thing, and you can solder the lower part to the upper part for strength, or use a pin to fix them together- 993 replies
- gun dispatch vessel
- victoria
Well then, you are way quicker than me. Last week I did 1.5 tripple AA guns in 2.5 hours ... I have 27 in total ... about a week and a half work I'd say. Just couldn't finish the job then as I got meself a nasty flu, sneezing and coughing doesn't seem to help much with those parts. So don't sweat it. You just get to spend a wee bit more time on your model!!
HAve them made so you can fold them in two for strength. On my builds with PE there are quite a few parts which are folded (not for strengt, but for the look of strength) It is easier to etch a thin sheet, than a thicker one, at least if you need to get holes ... Cheers- 993 replies
- victoria
Does the clear plastic have any real use, or is it just for a few (very few?) windows ...
Ah wait till the riggin' comes along ... and gun ropes ...
- 455 replies
- slightly modified
- greyhound
You are certain ... not had a tot of something ??? (te diep in het glas gekeken ..)
- 305 replies
- utrecht
- statenjacht
Thanks Scott. You seem to forget that my glue blotches are far bigger than yours 1/350 vs 1/200 Wish him well from me! Cheers
Sorry to hear about your dad, it is important to be there. Sometimes it is all that matters mate. All the best for your dad, hang in there!
Have a look at the last image of the funnel in my post ... that's glue all over, even visible after painting!!! You are doing a marvelos job so far!
You may need to remember the hot soaking method, or hot soaking and drying ...
- 455 replies
- slightly modified
- greyhound
get somthing black. drench your toothpicks in ink so they'll be black all the way through ... just a thought. Have a look at what they do in the scratch build section
- 91 replies
- kolderstok
- duyfken
Nice work OC. Good base for your second layer
- 455 replies
- slightly modified
- greyhound
I was just about to ask whether you could build this kind of vessel easier, considering your hands, than the plastic ones ...
- 455 replies
- slightly modified
- greyhound
So this lion is not just in dire straits, but also has a split personality ...:wacko:
- 305 replies
- utrecht
- statenjacht
Start with the piece which you need to build it up, and so o, and so forth ... Although you could start with the rigging, but where to put it
What's stoppin' you Probably the wisest thing to do, i.e. as far as you are not allowed to build at her place ...!
Any left-overs ... Else you might try to get one at a nearby hobby shop Looks rather spiffy for a first layer
- 455 replies
- slightly modified
- greyhound
Different PE set (other made) probably ... I know on the Musashi the crane and catapults are full PE items ... both Pontos and Fly Hawk, although not Eduard ...
