Posts posted by EricWilliamMarshall
Many thanks for the encouragement!! Every little bit helps!
- Retired guy, ccoyle, Cuda1949 and 5 others
8
I started work on the deck structures. While I’m sticking to the kit as is, I took a shot at improving on the printed veneer, since I have not used the printed veneer else where. The rings were made by wrapping 32 gauge wire around a thicker brass wire and then cutting with an xacto blade (diagonally across). I made two sizes, linked them (very fiddlely work) and glued all to the deck.
The instructions are brief but mention painting at this point. So I’m waving off on the use of the shavings here and simply following the instructions as best I can. I keep running a foul with the kit. The bits of wood for the bow ‘plates’ or ‘cheeks’ were too small. Drilling the hole through the deck and hull for the rudder was tricky.
- GrandpaPhil, catopower, thibaultron and 5 others
8
- thibaultron, coxswain, catopower and 6 others
9
- GrandpaPhil, Retired guy, coxswain and 1 other
4
- Duanelaker, ccoyle, Cuda1949 and 4 others
7
- Duanelaker, GrandpaPhil, coxswain and 2 others
5
- coxswain, GrandpaPhil, thibaultron and 3 others
6
Gaetan,
Thanks for your thoughtful reply. I’m ready to dip my toe in machining so seeing such a library is exciting; seeing your library, in light of you delightful work, more so!!
- FriedClams and mtaylor
2
- ccoyle, etubino, Retired guy and 6 others
9
19 hours ago, amateur said:
the standard way of doung this does not exist
Haha!! Fair enough! Thanks
Edward, thanks for the kind words!! I’m still in my early days of modeling and it is delightful hear such encouragement!
Many thanks yet again for the views and likes!
- ccoyle, Duanelaker, Edwardkenway and 7 others
10
@Jond I finished your suggested book, Barons of the Seas. It was an interesting history - I was surprised by how many the wealth families with connections to the opium trade described are names familiar to anyone who has lived in NYC! I didn’t realize how much overlap existed between the clippers and steamships nor to the mechanics and economics of the opium trade. What are some of your favorite books that you would recommend?
Unrelated, I haven’t found any good references for deck fittings or rigging and I’m open to suggestions!
In the absence of an good intel, I’ll just build the kit as per the limited details given in the kit.
Photos of the process described above. I used yellow to mark the suggested line in the plans and then overlaid the blue tape and 'felt' for the bump of the overlap and marked it in pencil.
Then I removed the blue tape and laid it on the wood to cut, added an offset then cut.
The kit’s supplied templates for the sides didn’t match the supplied hull. I was at loss as to how to proceed. I made in templates by putting (yellow) tape below the deck on the sides of the hull as per the plans then put a second layer of (blue) tape, which I marked with pencil to capture the curve. I removed the blue tape and stuck it to the sheet to be cut, thus transferring the 3D curve to a 2D surface for cutting. I then added a parallel line to match the transferred line and then did my cutting. If the there is a standard way to do this, I’m all ears!
I’ve attached all the slivers to their proper places on the decks. Then I used a cotton cloth and some hot water to remove the remaining paper. I think it looks better than the printed oak sheet but not as nice as I hoped. It looks better in the photo than the real world. C’est la vie! I going to sit on my hands for a day or two before deciding to proceed or try again.
Apologies, the last photo shows the photocopied paper still attached to some of the wood! Thanks for the advice though - I agree,
Opium Smuggler 1806 by EricWilliamMarshall - FINISHED - Authentic Models - Scale 1:75 - Schooner
Posted · Edited by EricWilliamMarshall
The supplied dowels have found new shapes and curves since the kit was created.
