Everything posted by Mirabell61
Piet and Michael, thank you so much for your nice compliments, I`m glad the metal work is liked, it gets a bit tricky with limiting the heat flow to spot areas when soldering, because it`s mostly done with the mini gas torch, but it is a good exercise Nils
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
many thanks Denis and Gerhard, for your nice comments Nils
- 2,625 replies
- passenger steamer
Thank you very much Grant and Boyd, Grant, trust in one more week those medical issues will be overcome Boyd, ...If I find something (material) that can be used somehow, I put it aside, together with an idea for usage, and probably ca`nt find it again when it is needed, like for that thin PVC tube, I searched a day or so.... Nils
- 2,625 replies
- passenger steamer
thank you all so much..... Denis, Martin, David, Bob, Michael and all the "likes" here a little update.... I`ve been at the lantern making this morning. I knew that I still had some clear PVC tube (for medical hospital oxygen masks) Together with with diam. 4 x 3 mm brass tube a square window was filed into the brass tube, and then the PVC tube was pushed into the framing lantern housings. There where the PVC tube passed the window it was bulbed out a bit, resembling the shape of the "glass" Nils filed a window into the brass tube push a clear PVC tube into the brass tube cut the tubes to length and fitted a concentric mounting pin The lanterns are fixed with a drop of CA (ca`nt solder here because of PVC). The overstanding holding pins will be clipped off to the right length watchout on station....
- 2,625 replies
- passenger steamer
very nicely done 3-sheave blocks Kees, Nils
- 434 replies
- pelikaan
- beamtrawler
thank you very much Druxey, Nils
- 2,625 replies
- passenger steamer
thank you very much Carl, It`s fun to carry on..... this morning I made the crow`s nest, the lantern brackets, and am dry fitting the access ladder.... For the lanterns I have something in mind, but have to do trials first Nils
- 2,625 replies
- passenger steamer
Hi Patrick, the "Mary Jean II" is a very elegant looking luxury yacht, all a bit larger than "Majellan", had a look at the general arrangement plan via Google Nils
- 1,083 replies
Gerhard, John, Mark, Michael, and the "likes"..... Thanks so much for your good wishes and compliments .... Nils
- 2,625 replies
- passenger steamer
Thank you very much Bob, Nils
- 2,625 replies
- passenger steamer
Hi Patrick, gently coming to the end with your "baby"....... When will you be opening the surprize box`s lid of the new project ? Nils
- 1,083 replies
Wow ! That will be another masterpiece Chuck.... are you intending also to leave her unplanked below the waterline, that filigrane structure is fantastic Nils
- 49 replies
- pinnace
- Syren Ship Model Company
thanks Patrick, it feels good to be back on deck again ..... Nils
- 2,625 replies
- passenger steamer
love this pinnace Chuck, I believe it`s one of the most beautiful ships boats on MSW. Those lines are so wonderful to kook at, pure 18th century art !! Thanks for sharing this beauty Nils
- 49 replies
- pinnace
Build log part 32 Building the foremast with attachment stations for the two derrick booms with double pivot joints to the mast, and several eyelets for fastening blocks, stays and flaglines. The spreader for the shrouds is fixed already, Ladder, crows nest, flag-boom and lantern brackets are still missing Nils rigging of derrick booms elevation stages of the mast joints with double pivots for the derrick cargo booms the rake of the foremast will be same as the funnels later on
- 2,625 replies
- passenger steamer
Thank you very much Bob, BTW, did you meantime find some better plans for a 26 ft. Navy motor workboat for "Pequot" ? Nils
- 2,625 replies
- passenger steamer
Thanks very much Greg, yes, the doc. did give me confedence that he will be able to get all right again by means of certain injections to the nerve root area, so no surgery ! no more upset... For the Royal Caroline scratch build in 1: 32 as I am very curious of what will come, it must be quite a "beast"..... Nils
- 2,625 replies
- passenger steamer
Hi Greg, Thanks for your compliment and your good wishes...... My health is improving now day by day, and I`m very happy and grateful with that. Today started a slight carry on with the work again and cut and soldered the the brass tube-bits of the tapered foremast together. I saw in your signiture that you`ve taken over The "HMY Royal Caroline" from our freind Greg. (the peg leg sailor) Please pass on good wishes and all the best to him. The R.C. with open port side, showing all decks and in 1:32 "super scale" sounds a great project ! Is it a kit or scratch build ? Will you be starting a build log here.... ? Nils bottom diam. 6,5 mm, tapered in 5 steps to top 2 mm, length 330 mm
- 2,625 replies
- passenger steamer
Congrats to completing your lovely "Pickle" Peter, a beautiful built ship, and the nice full suit of sails give her just the right look..... For your coming project I thiink the yacht "America" is a great choise, I fell in love with her lines once and started scratch buiiding the model, the hull had to be sold though, due to it`s size. Am looking very much forward to your begin , resp. keellaying.... Nils
- 293 replies
- pickle
- caldercraft
a beautiful built sloop Dave, I love it that you`re scarce with the paint brush and let the warm wooden tones work out, that gives a realistic impression, also the deck cutaway, well done Nils
- 306 replies
- armed virginia sloop
- Patrick Henry
