Mirabell61
Everything posted by Mirabell61
  1. Peter, your rigged sails look very nice indeed, the hoops give the realistic touch Nils
  2. Mark, a very nice and harmonic looking stern portion, lovely work... Nils
  3. very nice work Igor, it`s a beautiful (pleasure) schooner yacht Nils
  4. nice work Martin, I second Bob`s comment (beautiful bulkheads), but perhaps you may be planing a cutaway in the quarterdeck to allow sight below.... Nils
  5. lovely work Bob, shrouds and pendants are well done... Nils
  6. a beautiful rendering of that frigate Bava, love those pics in your Post # 2, very elegant lines Nils
  7. Hi Ben, nice that you`ve fixed the warp, it would have looked at you ever after if not..... The planking now is coming nicely. For the planking ends I would choose version 1 (overlap the transom) so you see the planks against the transom in view from aft. If the transom also has a structural planking, the side planking would also end up overlapping with the stucture-planked transom Nils
  8. Thanks for those links Gerhard, I have just found and ordered a whole bunch (Convolute) of small toothwheels from used wrist watches, but trust from your "links" there will also be a useful source. Perhaps I`ll get them on Saturday, we`ll see... Nils
  9. Thanks for you complement John, I`m thinking about how to build those cargo winches with twin steam cylinders drive. (two of six winches in total go onto the forecastle deck), looking for toothwheels to suit the scale.... Nils
  10. Peter, many thanks for that information. When I looked at that video taken by divers off the Dakhla peninsula I was amazed that the name lettering was still so well visable appr. 102 years under the ocean surface. Would highly appreciate any updates on this if you should be able to get some in due time.... Nils
  11. Hi Gerhard, looks very encouraging your involvement in metal working, turning, soldering, and you`ve also been very busy with repeatable mass production these days, Good work !! Nils
  12. Hi Gerhard, thanks for your word, by the way, (know you`re only kidding....) there is a beautiful 4 meter long "beast" in 1:50 scale, to be seen in post #181, fist pic, of this thread, so you would know what you`re in for with that.... Nils
  13. beautiful work Ed, thanks for sharing, the planking of the boat looks fantastic Nils
  14. Very nice build Hartmut, I am missing the view into the beautiful furnished cabins, as the deck seems to hinder quite some sight to the interior, maybe it`s only the angle and distance of the picture taken.... A wonderful ship !! Nils
  15. Many thanks to - Pete - Peter - Patrick - Ed - Albert - Dirk - Steve - Greg - Mark (Taylor) - Piet- for those nice comments and remarks as well as to the appreciations by all who activated the "likes" button Pete, the foredeck is obviously not complete yet, there are still to come steam winches, skylights, hatches, bollards, chocks spare anchors, etc... Peter, you`re right, the Stettiner Vulcan had quite some innovative ideas for their builds, and had been improving from ship to ship, especially in that decade around turn of the century Patrick, glad you like it, it`s not that Lillyput scale as yours, but here 1:144 is also quite a challenge Ed, Yes Ed, if one sees how the ship dip-sticks her nose into the onrolling rough sea, these breakwaters are very welcome and they have to be strong enough to withstand the water forces Albert, Thanks for your nice complement Dirk, thanks, it`s not so easy to stick close to the scale at all times..... Steve, access to the forecastle, next to that companionway between the chain slides, will be over a gangway from the promenade deck and by two stairways leading up from the "waist" (pit) deck I was wondering myself how the crew would pass over the breakwater barriers, if not with some sort of short steps or doors in the breakwaters. Would appreciate if someone knows.... For the mooring lines there will be some more bollards and plenty of chocks mounted on the forecastle deck. May need to cut some fields free in the railings Greg, a very nice complement, highly appreciated, Mark (Taylor), a very nice complement, highly appreciated, Piet, I thought I could do all in soft soldering, but some small parts have to be glued with CA (a "mix" so to say) Nils
  16. Update fitting out the forecastle deck..... now the capstans, the chain slideways, some bollards, anchors, etc. ...... have been fitted, and some painting is done.The breakwaters are permanently mounted Nils
  17. Ben, yoùr comment is right, and as the warp is only effecting the stern end, I suggest to end the horizontal circular saw cut appr. 15-20 mm before the transom. The keel will then be fixed at the end and the warped part will pull into the correct position. For safety reasons I would put a (removable) clamp over the aft keel area in order to prevent this portion from splitting and giving the sternpost stability during the process (depending on the keel`s ply quality). There`s no risk in ruining the model, as the warp is minimal as you said.... Wish you good success, thumbs up.... Nils
  18. Oh yes Bob, this is the fun part of the build.... Nils
  19. Hi Ben, do`nt worry , that warp can be settled quite easily....., and without harming or effecting your deck This is how I would do it: (ref. to the hand scetch included...) two variations possible... first way, in the upper scetch you would need to remove slight vertical bits of the bulkheads on the concave side, with naked saw blade or so.. Then cut (through the wood horizontally with small circular sawblade (Dremel or so) into the keel. Now you have way to correct the outer keel into the correct position. In case you would have sanded away already too much bulkheads profile, buffer up the surface there with small stripes. The keel width remains the same width over the length second way. Cut away thin vertical slots next to the keel on the concave side and insert a horizontal (tapered to the ends) stripe of fill-wood next to the keel, in order to compensate the concave area. Do`nt worry about the keel getting a bit thicker there. If necessary, buffer up the bulkheads to get good symmetric straking over the boat`s length Hope this is understanable... (click on pic to enlarge) Cheers, Nils sorry, my scaner is not working, so a photo pic must do
  20. beautiful Build Pete, she must be good for top speed when surfing on her own bow wave... Nils
