Posts posted by Mirabell61
super Siggi,
nice photos also. Will you have some outcuts in the deck allowing view to the below interior ?
Nils
- davyboy, mtaylor, Keith Black and 2 others
5
49 minutes ago, Veszett Roka said:
Another vote for German Merchant flag. I'd assume that the flag change is rather an artistic, dramatic episode than real event. Captains were never play hero just for fun, they WERE hero because that times require them to be.
So realistic flag +1
Thank you Veszett,
Nils
7 hours ago, Paul Le Wol said:
Nils, the plumbing looks excellent. ( as well as everything else)
Thank you for your nice comment Paul
Nils
- mtaylor, Paul Le Wol and Canute
3
48 minutes ago, Jim Lad said:
Depends whether you want to go movie or more realistic, Nils. I' think I'd go for the merchant flag (being ex Merchant Navy).
John
Many thanks John,
I`ll take your opinion for more realistic as well. (official Merchant flag of those years)
The novel "The Sea Chase" by Andrew Geer of 1948 begins in your hometown in Sydney Harbour appr. two days before WW2 broke out. I saw this movie so many years ago , but still remember, that the captain ordered even to break down the wooden Lifeboats and everything made of wood on the steamer for feeding the boilers in lack of coal on his escape...
Nils
thank you very much Keith,
I hope I`m achieving a good mix of the old 1918 Corsicana and the 1955 movie-ship Ergenstrasse.
I`m wondering wich nationality flag they were flying, as the capt. had order to "break through the British controlled lines" and head back to Germany. in that case it would not have been wise to set the German flag anyhow.
In the movie the capt. set the German marine war-flag ( it was a civel ship though ! ) at the time the Ergenstrasse was intercepted in the Norway waters by the Royal Navy.
As a civel ship she must have been flying the official (between 1935 and end of WW2) german merchant ship flag, which is the general red backgrond with the white Hakenkreuz on it. In the movie the capt. held this in hands for setting but then decided to set the war-flag instead, like German battle ships were flying. I would like to set a flag to my model, but unfortunately do`nt know wich one, Any recomendations ?
Nils
- mtaylor, Keith Black, Canute and 1 other
4
Update
before rigging the aft mast, I connected the tubes to the fresh-water tank.....
Nils
the stb. side tubing :
discharge to mach.room, winter anti-icing with bypass heater-spool from the funnel inside, and swanneck vent on top of the tank for tank ventilation
port side tubing : filling tube from lower freshwater supply, discharge, local for boats deck with tap. Maybe I`ll also hang a small bucket near the tap
the two heavy front bollards with mooring rope for going through the bow front bulwark openings
- Keith Black, wefalck, Retired guy and 14 others
16
1
This is to pass on my special thanks to all fellow builders with their kind recommendations for scaled wire ropes for rigging purposes.
I have own good experience with using steel rope like the (meantime not any more common) remote wire control for model power planes.
This steel "Diamantlitze" is either total 0,5 mm OD, 19 strand x 0,1 wire .....or total OD 0,25 mm 7, strand x 0,1 mm. Both are galvanic tin coated.
I applied this very suitable material (50 Meters on the spool) for soldering for the stays and shrouds of my tallship-models Pamir and Gorch Fock, as those would be spanned and confrontrated with considerable pull-forces caused by the working bottleneck screws
Nils
- _SalD_, Canute, FriedClams and 7 others
10
44 minutes ago, Veszett Roka said:
Nils,
Search for Litz, or Litze wire in electronics shops:
https://audioverse.de/produkt/21-awg-up-occ-wire-litz-wire
Usually they made from very thin, sub-0.05 mm wires, sometimes thinner than human hair.
Good point Vezett,
many thanks for your comment. The "Litze" is silver-coated, which is good for applying, but the seller recommends special caution when soldering, is nothing for beginners...
Nils
- Canute, Retired guy, Keith Black and 1 other
4
Eberhard,
many thanks for your idea input here. I`ll have that in mind. Also the possible use of fishing-line (Japanese) material sounds interesting
Nils
- FriedClams, mtaylor, Canute and 1 other
4
12 hours ago, Retired guy said:
Deck is looking very good Nils lots of details 👍
Regards
Richard
Many thanks Richard, I`m pleased you like it
Nils
- Canute, Retired guy and mtaylor
3
Nice find Cotrecerf,
thanks for sharing this
Nils
- Keith Black, Canute and mtaylor
3
Thank you very much, Javelin, John and Phil,
for your good advice with the making of fake wire. I`ll keep that in mind...., but meantime can also live with the greyish 0,7mm polyester rope, also used for the davits rigging.
I`ve just made the infeeds of the coal chutes for the bunkers, and acc. to Andy`s post (#137) and my post (138) they are situated (dryfit) on the boats deck near the funnel. Stb. side is a closed chute cover, and port side the cover is open with view into the chute. They may be shifted a bit, when the tube connections to the watertank are made
Nils
cover for the coal chute closed
and open on port side
- Valeriy V, FriedClams, FlyingFish and 13 others
16
10 hours ago, Jim Lad said:
She's looks great, Nils. Just to be pedantic, all the cargo gear rigging would have been wire rope.
John
Thanks John,
your words made me smile this morning, but who knows, perhaps someone one day will show me how it goes with wire ropes for these small winches.
The stays will be of tin galvanized steel rope.
Nils
- mtaylor, Canute and Keith Black
3
Update
Made the rigging for the boats and for the cargo derricks. There are also hand-winches for the boats. The fastening points for the stays are set, I`m waiting for some ordered workable bottleneck-screws to arrive. The bridge still needs to be done.
Nils
all holds have supporting brackets
The cargo derricks are rigged
the boats have their own hand-winches (two per boat)
the derrick winches are rigged
beautiful work Valeriy,
I like the reinforcement brackets at the mid-island front area...
Nils
- Keith Black, Valeriy V, FriedClams and 1 other
4
Thank you very much Richard,
for looking in intensively...., and for your kind comment
yes, I use brass quite often as this is a nice material to solder
Nils
- Keith Black, Canute, FriedClams and 2 others
5
Thanks for your input here Keith,
it looks like this has been an interesting sort of study for metal-plate riviting on a not further known or named dummy hull, in order to try out the process. The copper-plates seem to be real rivited and additionally soldered afterwards
Nils
- Keith Black, mtaylor, FriedClams and 1 other
4
thank you very much Javelin,
I love old steam ships, and of course the riviting detail, knowing that it may be slightly oversized for that scale, but the rivited hull would loose its characteristic look, which I I like to see on the model. It shows up quite well, even through the painting. The riviting must be made out, also when the model is viewed in it`s casing from a meter away or so...
Nils
- Keith Black, mtaylor, Canute and 1 other
4
Keith,
I see you`re gonna do it in the approved handcraft way (hand held jig saw) etc. I`m myself 75 years now and I still love scratch-building by doing the frames in this way.
Will stay tuned... I wish you much fun in building the lovely Cangarda
Nils
- mtaylor, FriedClams, Mark Pearse and 1 other
4
Update
today the stanchions for the hold-sides are done, the first fairlead for the mooring ropes and in combination with a heavy twin-bollard on deck
Nils
the guiderails for the rudder chain run alon the hold sides, behind the stanchions
the Panama fairlead is directly behind the through lead opening in the bulwark
bulwark outside view, will probably paint the fairlead black
in combination twin-bollard with Panama fairlead
mooring rope ( 2 mm polyester) for aft portside welldeck
thats a real little gem Javelin,
Nils
- Glen McGuire, Keith Black, Canute and 1 other
4
ERGENSTRASSE by Mirabell61 - FINISHED - 1:87 - steamship
Update
not much for today,
the forward- and aft mast-stays as well as the aft funnel stays are mounted. The stairs from the boats deck to the bridge in dryfit, a little brass waterbucket hanging attached to the superstructure, and the lashing device for the aft lifeboat strap
Nils
stair to the bridge
frontmast stay attachment
aft attachment
Waterbucket
aft stay arrangement
boats strap with lashing device
front attachment
mast attachment for forward stays
