Posts posted by Mirabell61
Status :
I started my luck in painting the white waterline stripe. I know its a tricky task on the clinkered Hull, whos done it before will know what I mean. If viewing from horizontal waterline level the stripe will be straight, if at an angle the white paint line on the strakes will be more or less a bit "zick zack" on the steps. Next will be to mask off the white line with Tamiya tape and get the underwater red or green coat (resembling the antiouling)
Nils
Good morning Pete,
the "drawings" I used are : (please ref to my post #208)
from the book Herman Winkler on page 53
and the drawing from the web, beneath the forstanding drawing, (my post #208)
lines and frame plan are taken from Hermann Winklers book, page 53, of course there are quite a lot of details to be done in typical scratch build mode, but if you wish you would have my build log for comparism, or whatever you feel is worth adopting from the web`s free information..... For example I wanted the fish containments, the engine, the berths, the swivible centerboard, the engine cover, a minimum of furniture in the cabin, the oven, the ballast stones, the bilge pump, 2 scaled crew figures, the faked hatch covers to the bilge area, the horizontal plank connectors, ...etc...., and whatever is still to come...
For rigging and sails later on there is enough information on the web and in the books mentioned above.
I do`nt know what plan Mathias is using, guess he mentioned it somewhere, it must be very detailed, and I also did`nt find the source, but it is not needed....
Nils
many thanks Pete,
Have one side done with the plugs, 3 planks left on the portrside. Trust I`ve never drilled so many holes before.
First mark the positions, make a small centering point. drill 0,6 mm. enlarge to 1 mm, place the toothpicks and dip the pointed end in CA before, chisel off the overstanding pics, file and sand flush. I guess that all who did a good looking treenailing on the hulls and decks experienced the same exercise, for me it was new .....
Nils
Excellent work Daniel, such a beauty !!
Nils
- mtaylor, paulsutcliffe and druxey
3
nice work Phil,
are you going to rig her, and perhaps with sails ?
Nils
- marktiedens, michael mott, rafine and 17 others
20
Many thanks for Geert, and for all that clicked the "likes button"...
Geert.
yes, I`m also happy with the effect, trust it will look fine above the waterline. (varnished natural wood). At the waterline there will probably be a horizontal white stripe and below that either green or red "anti fouling" coating, I doubt if the plugs in that area will show through the paint, but we shall see later on.
Nils
- G.L., cog, Keith Black and 3 others
6
Kortes,
Wunderbar,
congratulations, you`ve built a beautiful ship. She looks so realistic. This little jewel is so well done, rich in detail, very neatly performed and real candy for ones eye to see
Nils
- Keith Black and mtaylor
2
Lovely work Hof,
looking at the fuselage construction, the real plane must have looked somehow the same. One can imagine that unfreindly bullits went through it like through butter...
Nils
- mtaylor, Canute and popeye the sailor
3
I am enjoying your build log Geert,
it looks like a real boat beingset up in the workshop...
Nils
- FriedClams, mtaylor and G.L.
3
1 hour ago, Peter Cane said:
You did not tell us it was to be Viking powered as well Nils!!...but the oars are a bit short?
Pete
You`re right Pete,
thats why I cut then all off......
Ì`m really pleased with the outcome of the wooden plugs, got all in nice row alignment. The lighter wood color of the picks is a good contrast to the pear planks
Now all the others can be done in the same way..
Nils
Status :
transfering the waterline to the model, and beginning to put wooden (Bamboo toothpicks) into the horizontal, overlapping clinker planks. I did`nt do this before, so its a jump into the cold water.
I did my best to get the 1 mm toothpick holes in alignment, starting with the upper stb. plank. Check of the outcome will follow tomorrow, when the toothpicks are trimmed off and the plank sanded over.
Nils
the little jig for marking the waterline
thin bamboo toothpicks
a trial with 1 mm holes in the planks (Chose this one)
trial 1,5 mm holes ( found them too large)
picks glued in lightly with CA
- Dubz, FriedClams, cog and 10 others
13
Oh Pete!
I do hope my input of the last post did not upset you too much....
Your "Bluenose" will for sure have more displacement capacity to carry a suitable ballast. I will be following your progress with great interest.
I wanted to show you what I meant with the lines of the "America" I built, but did not complete. You`ll see why it reminded me of your "Bluenose". Some years ago my PC broke down, and all the personell files, and hundreds of pics, also modeling pics went lost with it. Fortunately I posted to a thread here at MSW to my rememberance, where I found my only still existing pics after searching...
Have a nice weekend
Nils
Yacht America, hull closed and watertght, but not complete, deck and fitting out started....
The length of the hull was about 1380 mm, as long as the sideboard where its standing on
3 Kg extra internal lead-weight made the hull already reach the waterline
There were two large hatch plates, under grating and skylight, flush with the deck in order to give access to all RC equipment and winshes etc
- Siggi52, mtaylor, GrandpaPhil and 1 other
4
Thank you very much for your kind words Pete,
I see were walking down the same lane, your suggestions for fuel tank, brass filling cap, shiny straps etc, many thanks I`ll see what I can do about it. I was also thinking of placing a steelbarrel with Shell / Mobil Oil,. or so... enblem on it aft, next to the motor. My wife suggested there should be some blue/white checkered pillow cases for the berths of the cabin
Nils
Good morning Pete,
Motor preference, certain make ? Actualy no, the engine I chose was a free chosen fictive engine that would comprise motor housing, gear- and clutch housing, cylinder, shaft, flywheel, front bearing shield, water pump, oil dip stick, starter, generator, mounting brackets, V-belts,cooling- and exhaust tubes, clutchlever and propshaft coupling. I know that some essentual devices will still be missing, such as tank, gasoil injection unit, ignition box, glow plug, etc....
Some time ago I saw a Zeesboat plan being offered at Ebay, It could perhaps be worth searching there or in the web (Google) from time to time.
Mathias was using pear wood for planking, and yes, same as you did, I was amazed that neither glue stains nor toolmarks were to be seen there, he is a genius (what a skilled work !! )
What spooks aroung in my mind is, how can I achieve the old fishing workboat character, seeing all the newdays leisure Zeesboot craft. Example the wonderful deck Mathias built would probably be too fine for the fishermens muddy and scratchy boots and scraping network and fishing equipment ....
I must admit that a strong criteria for me is also ( in lack of carving or clay modeing skills), to choose the scale for the boat due to the scale-true crew figurines. Here I found two figures from make "Pola" which are actualy forseen as driver and stoker ( now converted to fishermen father & son) on scale "G" steam locomotives scale 1: 25 resp. 1:24
Nils
Good morning Pete,
thanks for sharing your progress, I very much admire your large version of the "Bluenose" you are at,.....it reminds me a bit of the schooner yacht "America" I built for RC in about the same large size. I wated to build a boat that could be seen, out on the water. The hull was plank on ply frame from mahagony wood planking, and to get her 100% watertight, coated with glasfibre roving mesh and epoxyd resin. The hull had true shape, was very sharp cut and grazile, and I already during the build had doubts if later on I could get enough inboard lead ballast inside at the lowest possible point, stradeling the keel and the neighboured frames. When the first time in water, I was quite disappointed that although the hull itself was a lightweight,
the waterline was already reached with appr. only 3 KG inboard lead ballast, (which would have been far too light for the large sail area to compensate). So the ship without the ballast went to the shelf. I sold it many years later to a modeling enthusiast in Hamburg and never saw or heared about it after that.
Trust that an removeable exterior fin keel with lead bulb would have been the better choise
Wishing you good success with the "Bluenose". The Billing boats Bluenose, I still have, was one of the first models I made when I was much younger, because I fell in love with the lines of this beautiful "Glouster Fisher" of the Great Banks
Nils
Hi Pete,
looks like you caught fire !
I support your comments about Mathias`s incredible Zeesboot, (on the Wettringer Forum), the other models or kits on the web did neighter increase my blood pressure nor inspiration, when I was in search during the preparation phase...
Yes, stove and brown sails will be fitted to my boot.
Perhaps the tuc engines of this link my be of help for you..
Nils
- cog, Keith Black, popeye the sailor and 1 other
4
Good morning Pete,
I shall be very pleased to see another Zeesboot to be laid on Keel here at MSW, and shall be pleased to help you in this evaluation period.....,
now to your questions...
Cheers, Nils
Model dimensions:
The model in scale 1:24 is 495 mm long between the posts, will be appr. 750 , mm aver all (bow- and aft spars)
Mainmasthight appr. 490 mm
Beam 155 mm
There are several books available, two of them I am using, and can recommend they are :
-Zeesboote Segler durch die Zeiten, by Hermann Winkler
- Erlebniswelt Zeesenboote, by Timm,Stütz
this one also contains the overview plan I am basicly using, as well as the overview from the web, both motorized, one with fish containment boxes placed left/right of the centerboard
if I`m not mistaken this build is from the web page : https://www.modelships.de/Zeesenboot/Zeesenboot_dt.htm
- cog, Keith Black, rafine and 9 others
12
Thank you very much Pete,
You are right with the thoughts about the natural curve of planks. The moment when the bow and the stern area is "fuller and rounder" in shape, there definately would be more adjustment to be made especialy to the clinkered planks....
Nils
Good morning Kees,
Thanks very much for your nice comment.....
Nils
Zeesboot by Mirabell61 - FINISHED - scale 1:24 - wooden fishing vessel c. 1876 - small
Thank you very much Geert,
is your gaff day boat sailor also going to be clinkered ?
Nils
