Everything posted by BANYAN
Some nice rigging work there Dave. Glad you liked the work station - mine was a version developed from the "Crab" built by the late Hubert Sicard - he has some great material on his website "wooden ships for dummies". His site is still up but I am not sure if you can enter if you were not a member at the time of his passing. cheers Pat
Hi Ulises, the method for measuring mast and jib boom / bowsprit angles is also dependent on what tools (levels) you have. I think what you have done verifies you are in the ballpark. One method I use is very similar top your approach, in that I ensure the work surface and waterline are parallel. I then use a digital angle level/protractor which I zero on the work surface and then place on the spar to be measured and read off the angle (adjusting the alignment chocks etc as I go to achieve the correct angle). Another, more crude method I have used is to print off a paper protractor (series of lines at regularly spaced intervals). I stick this to a temporary holder (scrap wood) then use a plumb-bob to align a true perpendicular and adjust the paper protractor to the required orientation and perpendicular alignment. Then read off the spar angle against the lines. Again you need to ensure the work surface and the waterline are parallel and preferably level. I hope that makes sense. I used this method until I purchased the digital angle level which are quite affordable - very often on special for a few dollars at our local hardware outlets such as Bunnings (in Australia). This image of one is taken from an eBay advertisement; it differs from mine in that the bubble level on the top is an additional enhancement. I have not ties etc with this provider with the image used only to illustrate the device. cheers Pat
- 786 replies
- Royal Louis
- Finished
You're not mucking around, your progress is impressive! cheers Pat
- 786 replies
- Royal Louis
- Finished
Hi Druxey, exquisite work! WRT suggestions on Operational display of oars - if there are no crew then not operational? A feathered display might be more realistic? just an opinion - and how else would a viewer appreciate the full detail of those miniature masterpieces? cheers Pat
- 641 replies
- greenwich hospital
- barge
Solder and brass blackening
BANYAN replied to Cabbie's topic in Metal Work, Soldering and Metal Fittings
Chris - For soldering paste (silver and copper) I use Australian Jewellers Supplies / House of Jewellery - http://jewellerssupplies.com.au/soldering-welding-c-95.html?__utma=187725425.995140569.1462256671.1462256671.1462256671.1&__utmb=187725425.0.10.1462256671&__utmc=187725425&__utmx=-&__utmz=187725425.1462256671.1.1.utmcsr=google|utmccn=(organic)|utmcmd=organic|utmctr=(not%20provided)&__utmv=-&__utmk=163156796 They may have some other things you might need also. Try ringing them; I have found them to be very helpful in determining exactly what you need etc (but unfortunately, they are slightly expensive). As to Birchwood Casey Blackening; I bought a large bottle ( more than a lifetimes supply) from a gun shop in Western Melbourne somewhere at a very reasonable price. If interested I can try and track down the name of the place. cheers Pat -
Congratulations on the Book Druxey, I am sure it will be another fine addition to many libraries. WRT the oars, the extended display over the baseboard in the rowing configuration looks 'busy' in the photo but may be fine on display - but what about the glass/acrylic case fit? If you stay with the existing base board, then perhaps an approach from left field? Have you considered standing them up vertically behind, or at either end of the boat (drill holes into the base boardand make the case a little taller)? Otherwise my vote would remain with oars tossed even if it hides some of the mast details cheers Pat
- 641 replies
- barge
A great follow-up on the launches Chuck - she will make a delightful model. cheers Pat
- 49 replies
- pinnace
- Syren Ship Model Company
Agree, too many oars outboard would distract I think; either bundled or standing upright but the latter would not be realistic? cheers Pat
- 641 replies
- barge
Hi Ken, sorry to have missed your log before this as I limit myself to a certain number of builds otherwise i would spend all day on the PC An interesting subject and build you have going; card is an area I have not yet dabbled in so I will pull up a chair and have a closer read from the beginning. cheers Pat
- 80 replies
- choctaw
- heinkel models
You have been busy; quite rapid progress - looking good cheers Pat
- 1,616 replies
- caldercraft
- agamemnon
Great detail and some nice soldering there Dave. It seems you are coming to grips with the resistance soldering? cheers Pat
Some excellent detail there Greg; the checkboard effect of the capstan scotchman looks really good. One milestone down, only a couple to go? cheers Pat
A Lorch Micro-Mill that never was ...
BANYAN replied to wefalck's topic in Modeling tools and Workshop Equipment
I'll take a seat also mate; these engineering exemplars of yours are not only informative but mouth watering results. cheers Pat -
Nice work Ulises; that patina looks great and well suited to this style of model. cheers Pat
- 786 replies
- Royal Louis
- Finished
