Everything posted by BANYAN
Help in Identifying an Unknown Tool
BANYAN replied to BANYAN's topic in Modeling tools and Workshop Equipment
Thanks Rick and Gaetan - will need to find one cheers Pat -
Great recovery Ulises, remember the alcohol is for medicinal purposes ..... cheers Pat
- 786 replies
- Royal Louis
- Finished
Ah, thats the beastie - many thanks Gaetan. My source is looking around his stuff to see if the block is there. cheers Pat -
Oh the joys of modelling Ulises - Good luck with the fix, seems you have a solution inmind. cheers Pat
- 786 replies
- Royal Louis
- Finished
Hi Ben, you'll have to start feeding that passenger soon, they're nothing but a bag of boners Great to see you've sorted the electrics. A question though. i don't recall if this will be a floating/working model. If so, how will you get the oars to lift out of the water on the forward stroke so that it doesn't counteract the after stroke (propelling forward)? If it is a working static, won't be an issue. I am sure you have some clever system worked out with Arthur. cheers Pat
Beautiful work Druxey, the real hint of your resolve for top quality was highlighted in an earlier post about the tholes where you made almost three times as many as you needed so that you could select only the best. This discipline, and the lesson for us mere apprentices, is only reinforced with the redo rather than trim to size of the frieze. cheers Pat
- 641 replies
- greenwich hospital
- barge
A fortune maybe Mark, but then how would you learn to be a 'master' of your trade/craft The rudder looks great and appears to sit hang nicely against the stern post cheers Pat
Looking really trim John; hope the health is back to normal for you soonest. Best wishes Pat
- 745 replies
- francis pritt
- mission ship
A couple of very nicely detailed ships there Greg; you'll have a miniature fleet before you know it cheers Pat
Thank you very much Rick, Mark and Bob - appreciate the feedback. I had a thought after I had posted it may have been a scribe due to the two pins; but had not even thought on the missing block Thanks also for the tip on the planes TLC - I will take a look. These look to have been used by a carpenter (based on the wear and tear) with the soles having been trued. that said, I intend to pull them down, clean all parts, resharpen the blades and retrue the soles and the sides of the rebate plane. cheers Pat -
Hi all, thanks for looking in and the encouraging words; too many to thank individually, so I will keep this general. WRT stain or painting the yards - I am still not decided. I have found no definitive evidence that they were painted black in that period and remain open to suggestions. I have some time yet to decide as I am contemplating putting furled sails on and I need some time to investigate that also. WRT to the jewellers mitre anvil (THANKS Per) - I believe MicroMark may also have them but please check that they are not a cheaper version. The real thing is made of a very hard metal (I think steel or an alloy) so that you can safely cut or file against the surface. This makes them a little expensive though, but makes the metal work so much easier and cleaner. cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
Hi folks, I have recently had some old tools come my way (#7, #4, #71 and #78 planes; and a bunch of other small odds and ends). Among the other items was this small hand held tool that looks like it may be some form of vise. The screew (metal into hardwood thread, slides the brass strip back and forth in the slot which can open to about75mm. The slot is about about 3 -4 mm wide. There are the stubs of what appear to have been two brass pins visible, on on the fixed end, one on the sliding part. if not a vise, I intend to use it as such, as it is ideal for holding short lengths for sanding, bevelling and drilling or the like. Any ideas or clues please? cheers Pat
A small update with some progress made on the yards. The metal block you see is a jewellers block that allows a clean cut at 90, 45 or 60 degrees for round or square material; this has been quite handy for these very small bits. The design for these yard arm iron work is for the bent piece to slip over the end then the rings are slid over that. I used a small jewellers anvil to splay some brass tube to get the angled inner diameter before slicing off the thin rings. Some of the yards have had some of the additional fittings/furniture added but still need to be cleaned up and stained. cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
That looks great Mark, a marked improvement (sorry, no pun intended0. Your testing seems to be paying dividends. I use Birchwood casey almost exclusively now for th reasons you have given. cheers Pat
Interesting gluing technique. Will the glue affect the wood when it comes time to stain/poly them; or, will you sand them back a bit first? They certainly look good, and stronger for the process. cheers Pat
- 786 replies
- Royal Louis
- Finished
Hi Sjors, I am a bit of a late-comer to your log but glad I looked in. Your "Agie" is looking very good mate, and despite the sequence issues, the rigging is looking good. cheers Pat
- 1,616 replies
- caldercraft
- agamemnon
Hi Daniel, could these be the base for buckets (fire - filled with sand). I seem to recall a photo/drawing of Victory and other larger ships with buckets located along this area. These could be 'interpreted' as projecting bases with metal strap supports from either side and wrapping around the base? cheers Pat
