Everything posted by BANYAN
Thanks Mark, Per and Dave; and all for the likes. It was a quiet BD but just what you need as the good doctor says above. That's the two most complex yards in place now so hopefully the others will not take as long. cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
You're going along rapidly Greg; that PE looks good where you have used it so far. Those baseboards look a treat, especially with the grain showing the way it does. cheers Pat
- 342 replies
- dreadnought
- zvezda
THE 74-GUN SHIP by Jeronimo
BANYAN replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
I had missed your latest build log Karl, beautiful work - but we have come to expect that from you. cheers Pat- 194 replies
Thanks all for comments and birthday wishes - appreciated. John, no need to paste mate but thanks anyway. I was aware of inner and outer tricing lines, and interpret the same way. My intention is to show one tackle hanging from the pendant with both tricing lines fitted; the remainder will be the outer tricing only with the tackle hauled taut (pendant pulled in along the yard, but I don't think I will seize it also. WRT the positioning, AOTS shows two shroud blocks fitted one above the other on the leading shroud of each set at about the cheek level, one for inner and one for outer. I think I will stay with the AOTS as I have also used that belay plan for the running rigging else where( Braces leads for example) and the lead works nicely for the shroud cleats. Thanks for the heads-up mate, much appreciated. cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
Second instalment. The rigging is slackened to allow the jeers to be lowered about half way down the mast, I seize the slings around the yard. I then prepare the parrel off the yard and fit it after the yard has been slung and raised a little closer to the tops. After tightening it I haul the completed yard. cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
Hi folks, next instalment (if the site lets me - third attempt - seems Win 10 and Internet and this site causes BSODs - I have tried three different browsers!!!!). This posts starts with the yard fitted with the stirrups and hardware (from earlier posts). All blocks etc are prerigged with running loops, with the loop large enough to fit over the stirrups etc without causing damage etc. [edit: ignore the stain run on the stunsail boom, that wipes off very easy - I let its it for a while for the stain to penetrate the wood which is Huon Pine with natural oils, so it takes the stain a little time to penetrate] cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
It's the screw-ups we learn from Mark; thanks for posting them. At least with the "death star" recutting/shaping is a tad easier We also have to remember that the macro-photos also make things look worse than they really are to the eye. cheers Pat
Thanks John, appreciated. Last night I found two small blocks seized to the leading edge of each fore shroud (Main and Fore) in the AOTS running rigging overall drawing. Very faint lines which turned out to be (according to the AOTS) lead blocks for the tricing lines which ten led to the foremost shroud cleats for belaying. I'll check those two other reference you provided and decide from there. Many thanks mate, for this and pointing out my error (or should I blame the dockies? ). Pat
- 517 replies
- Endeavour
- Artesania Latina
Good idea Greg. Do you have any concerns this tape may lift over time? cheers Pat
- 342 replies
- dreadnought
- zvezda
Hi folks, a (major) error has been pointed out to me which at this stage I don't think I will try to fix as I need to complete this project. I point it out that any members who use this as a guide/refer to it are aware. The stunsail booms are cranked the wrong way They should be to the fore side of the yard not behind. My reasoning for not correcting it is that this is my first major build and I have learned so much from it, and there are a few other errors the keen eyed might pick (noticed too late) and fixing these would require a major effort/refit. I think that at some stage I will revisit Endeavour and I can then be aware of these in that, and future builds. cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
HMB Endeavour by mikec - Eaglemoss
BANYAN replied to mikec's topic in - Kit build logs for subjects built from 1751 - 1800
Nice to see you out of the hangar and back iin the dockyard Mike BTW I am working on a 1:1 build of a Airspeed oxford (WWII Trainer) also used by the NZAF I think. cheers Pat Edit: Sorry Mike typed SAAF instead of NZAF - both used the OxBox but my mind must have been elsewhere. -
Hi Mark, please note I was not questioning the decoration of the railings, only the purpose of such an open area. The french loved their decoration (even more than the English I think?). Druxey's comment sure adds weight for a use of that open space, especially if the Captain's head was in one of the quarter galleries. cheers Pat
bucket rail
BANYAN replied to jray47's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
AS HSM pointed out, for fire fighting; they were filled with sand I believe. cheers Pat -
Glenn, I think pigment based paints were still the only option back then (please check this though) so they were not a pure white. I use Admiralty paints which are acrylic, pigment based and designed from samples of paint taken from the Victory I think? They have a matt sheen finish. Perhaps another option for you to consider? cheers Pat
What would the purpose of those railing be for Mark? I don't see any ready access other then the windows, to gain entry for use as a recreation area - not saying your interpretation is incorrect, just seems strange? cheers Pat
The beauty of plastic/resin; the hull comes together so much faster than planking cheers Pat
- 342 replies
- dreadnought
- zvezda
Thanks Dave, but I have been at it for 12 years - very slow indeed. The pace has only picked up since I retired. cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
Thanks Jom. appreciate you looking in. We all aspire to better build quality; I have a fair bit to go to catch some of the great builder son this forum. cheers Pat.
- 517 replies
- Endeavour
- Artesania Latina
A Lorch Micro-Mill that never was ...
BANYAN replied to wefalck's topic in Modeling tools and Workshop Equipment
Very nice Wefalck; I drool every time I visit your tools pages, engineering art! cheers Pat -
Thanks for all of the comments and likes folks, much appreciated. Sure helps the run home! Sorry Sjors, the dockies flat out refused a further production run cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
