Everything posted by BANYAN
Hi folks, to get back the the key discussion here, I think it prudent (for the time being) to ignore the technical definition of what exactly is a "transom" and concentrate on whether a tiller support was fitted (and when). Once this has been determined, its naming convention can be sorted later? Only a suggestion! Druxey, I agree WRT hard fact, but I think this discussion was not trying to establish hard fact for the existence of the Tiller Support but whether such a device was a possible fit (at some stage) as implied by "interpretation of several cited log/ entries, and the curved device shown on one of the draughts - that latter part is fact as it is drawn there - but what is it? That part can only remain conjecture unless hard evidence is found. I think (correct me if I am wrong) that Dashi is trying to establish what this was, but we may never be able to truly determine that, but could arrive at some very real possibilities? Similar to the yet to be fully resolved issue of whether Endeavour was fitted with bumpkins/boomkins? I don't think there is any harm in postulating as long it is recognised that is simply a postulation? The log text cited by Dashi, indicates that Cook had been experiencing troubles with the tiller for some time and that he set his armourers and carpenters to work to try and resolve the issue; and with some success in NZ. This included fixing the iron work, including the 'braces' (still to be defined). From my naval experience, fitting a 'jury' rig to overcome a design deficiency, or temporarily fix damaged equipment, is not unheard of (and probably acceptable back in those days also), and if the fix proved satisfactory to the task, could be formally submitted as a design change and eventually included in the ship's official drawings and if necessary, also updated in the related technical documentation. This approach forms the basis of my interpretation of the cited text. What I am suggesting, and is only one possible interpretation of the cited text, is that Cook may very well have contrived a jury rigged support for the tiller (in addition to fixing transom timbers, metal work etc) to overcome the issues he was experiencing, and that on his return to England, submitted the results of this "fix' in his reports to the Admiralty. This may then have been formally included in the 1771 refit (and may therefore be the basis of the drawn curved shape in the draught - it may also have been a steering compensation device, or even a combo of both - we will probably never really know?). Cook was the type to try new or different things, and such a support would certainly have assisted in bearing the load of the tiller arm. As an example of Cook's willingness to try different solutions, there is a Parkinson drawing (I think it is Parkinson) which suggests that at some stage he also rigged a spare spar across the transom to provide additional flexibility to the working of the mizzen/driver (let's not deviate on that discussion here though ). In summary, I am suggesting that Cook must have tried several options to resolve the many tiller issues he cites in his log/journal. From what I have been able to determine, I do not think a tiller support was fitted in the 1768 refit, but it is possible that some form of tiller support may very well have been contrived as a jury rigged fitting during the voyage, and later formally accepted and fitted during the 1771 refit. One interpretation of the cited text infers a 'fix', but at best, the statement is a little ambiguous in that it does not directly state it was a tiller support, but it also does not eliminate it. Therefore I submit that we should not ignore it? Ranging shots complete; fire for effect cheers Pat
Making Shackles my way…
BANYAN replied to Thanasis's topic in Metal Work, Soldering and Metal Fittings
Nicely documented technique Thanasis; thanks for taking the time to share. cheers Pat -
Niiiice! This will be an interesting and challenging build Greg. With or without torpedo nets? The real question though - will you ever come back to wood? cheers Pat
- 342 replies
- dreadnought
- zvezda
Mark those scroll sanders are great. I saw a tip on here some time ago which I am not sure if you have seen. the tip suggested glueing wood backers to the sanding strip to prevent round-over of the sanded piece. cheers Pat
I would like to echo the choice/suggestions made by a few members for models of ships dating to the "transition" period (steam/sail). Any model would need to meet the interests of many rather than the few to be commercially viable, so I will stick to a selection where there are ample NMM plans, some contemporary reference books, and included multiple ships in the vessel Class to allow some personalisation/customisation by the builder. My selection meets these criteria while still offering interest to builders from several nations as these vessels were resold or built for more than the RN. - Gun Despatch vessels of the Arrow, Vigilance or perhaps the Albatross Class (Crimean War plus period). - Good wood quality, resin and PE rather than mixed metal, and brass or resin cannon (with appropriate detail) etc. - Perhaps two versions of each kit (one for beginners, POB, with lower quality materials etc and another for more experienced builders, POF, with better quality wood, options for higher quality materials and fittings etc. - Scale 1:60 or 1:64? (1:48 would be nice but rather large to display for many) - Good plans and instructions essential - especially for rigging as practices throughout this period varied and evolved. - Laser cut or CNC milled parts (not die stamped etc); consider planking templates (spilling method). If this path were taken, an author may also be inspired to produce some sorely needed reference material using builds of these kits for pictures etc, and collate the contemporary materials such as Peake, Paasche etc. This period sadly lacks modern reference books in the vein of the "Construction and Fitting of ..." etc books. Sorry if I have strayed into another area here. cheers Pat
Oh boy that is small; you've achieved great detail for something so tiny Piet. I look forward to this diorama. cheers Pat
Very neat work as usual Danny. I particularly like the effect of having the cut-through for detail of the hatch and grating as it shows their construction very nicely; something not shown very often or if at all. cheers Pat
- 268 replies
I really look forward to your updates and missed last week's contribution but, this has more than made up for it. Ditto Greg's remarks. cheers Pat
Hi Dashi. Another interpretation of that wording "for the want of which the Tiller..." could also imply that a transom had not been formally fitted to Endeavour in the 1768 refit and that he was now fitting one (running improvement so to speak) as a result of the constant tiller issues; and this improvement was then formally amended into the plans of 1771? cheers Pat
Sjors, Shaking off the holiday "pace" can be difficult cheers Pat
- 1,616 replies
- caldercraft
- agamemnon
Beautiful work Dave - geez I am peeved I missed your log until now. That is an inspirational carving and sculpting effort which really enhances the build. cheers Pat
- 962 replies
- sovereign of the seas
- ship of the line
A small update. I have rigged the fore mast lower yard and the method seems to work. Photos of fitting the main mast lower yard will follow in my log. I assemble the parrels on the bench top using two lanyards/ropes with a very small eye on one end of each. I seize the eyes together and this forms one end of the parrel rope with each tail end reeved through the ribs (6) and trucks (2 rows of 5). I use electronics micro-hook clamps (don't know the name) to pinch the rope at each end of the outer ribs to keep the assembly in place temporarily, leaving sufficient length of the seized ends of the ropes to form a loop that will easily slide over the pre-rigged yard. I then offer the yard to the mast about 3 inches (75mm) below the tops, pass the tail end of the ropes around the mast and then counter-wrap these around the yard, pulling through the excess of the loop on the other end and cinch them loosely. I then remove the clamps and tighten the ropes a little more, but being careful not to prevent the whole assembly being able to move up and down the mast. I then wrap the tail end of the parrel rope back around the mast within the hollow of the ribs, pass around the yards on the other side and return the tails back to the other side where I tie them off (around the yard). I then attach the tye sling strops (seize the two loops of each together) around the yard and hoist the yard back up to its required position carefully adjusting the parrel as it goes up. Net result looks OK. However, I think the beads I am using for the trucks are a little small as the parrel assembly does not wrap around the mast as much as I think it should. I hope this is of some use to others. cheers Pat p.s. Can anyone tell me what size the cat-hook (triple block) should be for Endeavour? For other dimensions (spars etc), I have used a 6th rate as the equivalent, so that should suffice - I can't find anything except for a 1st rate.
Chuck, I really like the look of your latest offering. this will be a very nice addition to the 19th century longboat. Add mee to your furture sales list please. cheers Pat
- 269 replies
- Queen Anne Barge
- Syren Ship Model Company
Thanks Nick, an interesting concept which I may employ. cheers Pat
Frustrations aside Greg, she is a little beauty and well worth you efforts. Quite the miniature fleet you have started there cheers Pat
Terry, taking a closer look at your initial photo, I note that the gap at the top of the door is smaller to the rear (left of photo), and that the door appears to be angled slightly inwards towards the rear (more of the after jamb is visible). This gives the impression it is slightly ajar which is consistent with a hinged door. Would not a sliding door have a consistent gap right across the top? That said, earlier photographs (due to the camera focal length) can give a false impression and this could simply be a trick of the light. This also does not explain the hardware, or lack of visible doorknob/handle. Could it simply be masked/shadowed, or removed for maintenance (hence door ajar)? I have also attempted to clean-up the shot just a bit and can make out what could be the hint a handle (circled); what do you think - I could be just jumping at shadows here? Click on the image for larger view. cheers Pat
- 11 replies
- 19th century
- Galilee
- (and 6 more)
