Everything posted by BANYAN
Very nice detail indeed Greg. Great t see you constantly looking to improve your models - this one for example already looked good; but this will add that extra flourish. cheers Pat
The overall look with the toned down masts looks great Rob; very nice! cheers Pat
- 3,560 replies
- clipper
- hull model
NAIAD 1797 by Bitao - 1:60
BANYAN replied to Bitao's topic in - Build logs for subjects built 1751 - 1800
Wonderful detail and quality cheers Pat -
Very nice 'smithing' yet again Keith; impressive! One would be a radar platform, the other for a GPS or small satcom aerial (or even a TV aerial) I think. cheers Pat
Randy, further to Ed's excellent advice, I have made up a small tube extension for the end of my vac hose that results in a very useful accessory. The flexibility of a thin walled plastic tube allows me to manoeuvre it into tight places - you can find many sizes at an Aquarium supplier). Use one of those step down reduction adapters to fit the hose as best possible; then use telescoped tube of various sizes to get as close as possible to the final size you want, then pack any gaps with silicon sealer or use tape if only narrow gaps. If you push the tubes further back one into each other without creating a long series of stepped tubes, you end up with a short fat end that can slide inside the adapter. Put a bit of pantyhose/stocking between/over the adapter and thickened tube end when sucking up small parts (rather than having to dig them out of the vacuum bag cheers Pat
- 3,618 replies
- young america
- clipper
Clever use of the toothpicks Brian; those oars turned out nicely. I have seen examples of painted oar handless but not their blade tips. The dark paint on the tips, in the photos at least, appears to foreshorten the blade and make them look flat ended - perhaps not a problem to the naked eye? cheers Pat
Looks good Rob. The red is a little 'loud' but sure is distinctive - I don't think this appears 'in your face' and is acceptable, especially if you are putting a matt finish on. cheers Pat
- 3,560 replies
- clipper
- hull model
Couldn't agree more with the previous correspondents Keith - you black (sorry gold) -smithing and especially the way you approach each piece is always worth viewing. In the words of that cheeky young mite , " Please sir, can I have some more". cheers Pat
I admire your openness (about errors) and work ethic to get it right Rob. cheers Pat
- 3,560 replies
- clipper
- hull model
Ditto mate; the blue just seems a little too bright for my taste - but as others have said - your model, your choice. cheers Pat
- 143 replies
Look forward to seeing your rigging progressing Keith. Welcome to my rigging world (research, uncertainty and frustration) . One author I have found very useful for the rigging of our period is 'Seamanship' by Commander G.S. Nares of 1868. Others that may help are 'Seamanship' by S.B. Luce also 1868 and 'The Boy's Manual of Seamanship and Gunnery', 2nd Edition, by C. Burney, 1871. All of these are available as free PDF downloads. cheers Pat
Also doubles a chisel - see also tools used convert small project to large. Perhaps the most useful - also paint lid opener, weeding tool, paint and rust scraper... but most importantly, for punching holes in the top of a beer can when the ring-tab parts! 🥳 cheers Pat
Your tooling skills are every bit, if not better, than your modelling skills Eberhard. An artisan! cheers Pat
Great work on 'chapeling those masts Rob, very nice indeed despite your so called imperfections. cheers Pat
- 3,560 replies
- clipper
- hull model
Definition of 'Single' WRT rigging/ropes
BANYAN replied to BANYAN's topic in Masting, rigging and sails
Hi Keith, the lower yards were hoisted and lowered using the mast pendants and mast tackles (heavy). Once hoisted, they were transferred to their respective patent truss and supported with sling chains, then the tackles removed. Once in place they were rarely lowered unless for repairs or mast replacement etc. cheers Pat -
Interesting concept, look forward to seeing the results Rob. cheers Pat
- 3,560 replies
- clipper
- hull model
Thanks Eberhard, that was my interpretation also but continue to be confounded by the Rigging Warrant entries - in this instance the very specific inclusions against the fore lower yard: @ line 1 "Lifts, single - 3.25ins hemp rope, 12.5 fathoms, associated with two 7" double blocks and two clip hooks." @ line 2 "Lifts, Tackle - 2.25ins hemp rope, 34 fathoms, associated with two 7" single blocks." The custom used through out is that the total number of blocks, hooks etc listed are used for both sides, BUT the lengths of rope are specific for an individual line (in this case each lift is 12.5 fathoms long etc). The other custom used is that the line immediately following is associated with that line (usually the tackle for that line - but in this case very clearly identified as such). If using the 'lift' alone (pure definition of single), the 75 foot length places its end about 15 feet above the deck - BUT, if then worked with a tackle, the tackle has sufficient length to be worked from a height of the lower yards - this suggests the tackle would be just some 15 feet with a very, very long working part? The ONLY other thought I have is that perhaps the upper lead block was placed much higher than the lower Cap (perhaps at the topmast stop?) - but this would be very unusual. In some ways this configuration makes a bit of sense as the working angle from the yardarm to the lower cap would be very shallow. In Victoria, the upper mast was a combined pole (top, topgallant and royal masts all in one). If I moved the lead block to such a point, the lengths make sense, but again no extra block is listed - perhaps again the top rope block could be reutilised (snatch block). What do you think? My first thoughts were that the tackles are used as purchases, but that leaves a very long length of the lift and a very short tackle (as shown in Keith's photo). However, if the lift is made up as a tackle as shown by Underhill (earlier illustration) the lengths of rope provided fit very well, but the number of blocks provided is short by one single 7" single block per side. All very confusing Thanks again for your suggestion. Pat -
Hi Keith thanks for the photo; not sure what I am looking at, but if you mean the line abaft the mast with the short purchase - yep that is about the only way I see it working with the listed items - but run into the same issue; the amount of line specified for the purchase is much to long. Thanks again. cheers Pat
