Everything posted by BANYAN
Most definitely interested , many thanks for letting us know. Being a 'custom' produced item, will this make it more expensive? I understand there may be set-up costs etc, but if enough interest is shown, would it be worth tooling up a production line again? I ask this as the international postage of products from the US has increased so much that I have stopped buying except for some very specific items. These blades were very good, and if costs remain reasonable I would certainly be placing an order. cheers Pat
Not hard to pay close attention to such a very nicely made model; especially with the research that has gone into it. Thanks for the explanation. cheers Pat
- 3,560 replies
- clipper
- hull model
That would make an interesting diorama - was it ever done? Either way, an interesting addition to the model. cheers Pat
A great testament to your modelling skills Rob, and to the great research you and others have completed. The only (very minor) point I have is that in one of the shots (midships on the upper deck), the base of the lower masts 'appears' a little thick compared to the photo. However, that is likely due to the camera (especially in the lens qualities between the old and yours) which will drastically distort the perspective and create differences in foreshortening of that part of the deck space - I know you have measured this so is bound to be right. cheers Pat
- 3,560 replies
- clipper
- hull model
NAIAD 1797 by Bitao - 1:60
BANYAN replied to Bitao's topic in - Build logs for subjects built 1751 - 1800
Sensational joinery; your attention to detail and the quality of your work is outstanding. cheers Pat -
Very nice detail indeed Greg. Great t see you constantly looking to improve your models - this one for example already looked good; but this will add that extra flourish. cheers Pat
The overall look with the toned down masts looks great Rob; very nice! cheers Pat
- 3,560 replies
- clipper
- hull model
Wonderful detail and quality cheers Pat -
Very nice 'smithing' yet again Keith; impressive! One would be a radar platform, the other for a GPS or small satcom aerial (or even a TV aerial) I think. cheers Pat
Randy, further to Ed's excellent advice, I have made up a small tube extension for the end of my vac hose that results in a very useful accessory. The flexibility of a thin walled plastic tube allows me to manoeuvre it into tight places - you can find many sizes at an Aquarium supplier). Use one of those step down reduction adapters to fit the hose as best possible; then use telescoped tube of various sizes to get as close as possible to the final size you want, then pack any gaps with silicon sealer or use tape if only narrow gaps. If you push the tubes further back one into each other without creating a long series of stepped tubes, you end up with a short fat end that can slide inside the adapter. Put a bit of pantyhose/stocking between/over the adapter and thickened tube end when sucking up small parts (rather than having to dig them out of the vacuum bag cheers Pat
- 3,618 replies
- young america
- clipper
Clever use of the toothpicks Brian; those oars turned out nicely. I have seen examples of painted oar handless but not their blade tips. The dark paint on the tips, in the photos at least, appears to foreshorten the blade and make them look flat ended - perhaps not a problem to the naked eye? cheers Pat
Looks good Rob. The red is a little 'loud' but sure is distinctive - I don't think this appears 'in your face' and is acceptable, especially if you are putting a matt finish on. cheers Pat
- 3,560 replies
- clipper
- hull model
Couldn't agree more with the previous correspondents Keith - you black (sorry gold) -smithing and especially the way you approach each piece is always worth viewing. In the words of that cheeky young mite , " Please sir, can I have some more". cheers Pat
I admire your openness (about errors) and work ethic to get it right Rob. cheers Pat
- 3,560 replies
- clipper
- hull model
Ditto mate; the blue just seems a little too bright for my taste - but as others have said - your model, your choice. cheers Pat
- 143 replies
Look forward to seeing your rigging progressing Keith. Welcome to my rigging world (research, uncertainty and frustration) . One author I have found very useful for the rigging of our period is 'Seamanship' by Commander G.S. Nares of 1868. Others that may help are 'Seamanship' by S.B. Luce also 1868 and 'The Boy's Manual of Seamanship and Gunnery', 2nd Edition, by C. Burney, 1871. All of these are available as free PDF downloads. cheers Pat
Also doubles a chisel - see also tools used convert small project to large. Perhaps the most useful - also paint lid opener, weeding tool, paint and rust scraper... but most importantly, for punching holes in the top of a beer can when the ring-tab parts! 🥳 cheers Pat
Your tooling skills are every bit, if not better, than your modelling skills Eberhard. An artisan! cheers Pat
Great work on 'chapeling those masts Rob, very nice indeed despite your so called imperfections. cheers Pat
- 3,560 replies
- clipper
- hull model
Definition of 'Single' WRT rigging/ropes
BANYAN replied to BANYAN's topic in Masting, rigging and sails
Hi Keith, the lower yards were hoisted and lowered using the mast pendants and mast tackles (heavy). Once hoisted, they were transferred to their respective patent truss and supported with sling chains, then the tackles removed. Once in place they were rarely lowered unless for repairs or mast replacement etc. cheers Pat
