Everything posted by Gregory
Topmast stay rigging on the Cutter Cheerful.
Gregory replied to davyboy's topic in Masting, rigging and sails
The image I linked to above is from Chuck's prototype, and clearly shows the block on the top mast. Where did you source your Plans? Mine came from https://www.syrenshipmodelcompany.com/ Here is a relevant image from sheet 2 of 3.. Standing rigging. Edited: Dave, I just had a look at the start of Chuck's log where he posted some plans, which show the stay as you describe. It would appear there was at least one revision to those plans as provided in the full scale plans available for purchase. -
What plans are you looking at? On my plans, included with the starter kit from Chuck, the bowsprit is the standing end. The running end reeves through a block at the top mast, and runs to a two block tackle, attached to an eyebolt down on the mast or on the deck in front of the mast.. Perhaps Chuck can clarify. I believe this image from the build log, shows it attached to an eyebolt on the deck in front of the mast. https://modelshipworld.com/uploads/monthly_12_2016/post-2-0-68552000-1483056174.jpg I'm not 100% sure, because the wording on the plans says " ... an eyebolt on fore side of the mast. " -
In light of which, the frapping of gun tackle would seem appropriate on a model. No less so, than the neat coils laying on the deck, often seen on models. Would those coils represent actual practice on a working ship?
Might be able to help with more info... Any pictures?
I remember being a kid in the 50's, going to one of the local drug stores that sold plastic model kits, and looking at the pictures on the boxes. Particularly the small Constitution & Bounty. The $3.98 price tag was beyond my means at that time, but a passion was born.
. When I have done this, I put drops of white glue on the shrouds, and then, lay a small piece of line across the drops of glue on the shrouds to form the ratline, wiggle it a bit from side to side to pick up the glue, and it will stay in place until the glue dries if not disturbed. I can make a pic, if this is not clear.
- 64 replies
Yes.. I think the vote was con=1, sensus = 0 ..
- 64 replies
Sail design for 18th-century longboat?
Gregory replied to Cathead's topic in Masting, rigging and sails
I realized after re-reading a couple of times, that I may have not made my thoughts clear on this; being that, if this was not the practice at the time, why would a professional model builder do such a thing? My opinion was/is, that they would not. Leading me to believe the model is accurate.. -
I just noticed the moveable cover on the galley stack.. I don't think i have seen that feature modeled before.. Photo
- 742 replies
- constitution
- frigate
It sure makes me wonder why a modeler would have put the traveler under the tiller. It doesn't even meet the oft repeated criteria of " it looks good " .. -
FWIW they appear on the Hull model also.. With rope.. Hull Model
- 742 replies
- constitution
- frigate
Meant to add, as popeye2sea mentioned, moving it forward very much would interfere with the foresail..
There are several images in another thread.. This one has the main stay attaching near the fore mast..
Except for refinements and materials, everything is pretty much the same as it was hundreds of years ago..
- 10 replies
Do you have more information; pictures , of what you are referring to? I recently posted a tip about attaching hooks to blocks.. A little CA goes a long way..
I'm pretty sure that convoluted is not the way to go. I don't have Lee's. Perhaps someone who does can check it for you. I have to imagine, for the sake of easy handling, it would start at a ring bolt near the stern and belay to a cleat near the stern.
If I'm not mistaken, the Constitution has steps on the bowsprit. Seems like a convenient thing to have on a large ship..
Rigging Question (Probably first of many!)
Gregory replied to Bluto 1790's topic in Masting, rigging and sails
If you will notice, the number and set-up of those stays of your 50 gun ship, appears identical to Petersson's frigate. As far as belaying, taking the natural lead of the line to the closest pin, while avoiding interference with other lines, will probably not get you in trouble with any Admiral who may view your work.
