Everything posted by Gregory
The copper leaf itself is very fragile, not much thicker than a layer of paint, but the patina showed no signs of coming off when I buffed it. With something like copper tape, you might have some wiggle room to burnish some of it off, if it is too dark for your taste. It actually ended up a little darker than I planned. I did leave it overnight, but I wish I had of monitored it and checked every hour or so. This was a very small piece, and I did it inside of a zippered sandwich bag with one egg. I was thinking with something like the hull of a ship, I would make a framework to drape plastic over and put my eggs under
Which one? Rattlesnake, Fair American, Prince de Neufchatel , Armed Virginia Sloop ?
Hey guys, the question was: " ....which have the most detailed build instruction? Can we try to answer that question, instead of launching off into our thoughts on the other pitfalls that a beginner might encounter?
Vanguard Models Next would be any ModelShipways kit designed by Chuck Passaro as well as any kit from Syren Ship Model Co.
Forming a rabbet
Gregory replied to DaveBaxt's topic in Building, Framing, Planking and plating a ships hull and deck
If you go the route of replacing the stem and keel, my FET method will work. You can see in my Resolution build where I replaced the stem and keel, but I didn't have the FET, I used an added strip to form the rabbet -
Forming a rabbet
Dave , after looking at your build log I have to ask, is the stem and keel part of the backbone? If so, my method of using the FET for the rabbet in the stem area probably would not work after all. -
Forming a rabbet
Dave , I actually used the Proxxon FET to form a rabbet on the MS 1:48 longboat, including the stem/bow. I'll have to get back to you later with some pics. -
Cordless Micro Drills
Gregory replied to CLovehitch's topic in Modeling tools and Workshop Equipment
Along with what Bob is saying, I don't see that being much more useful than a pin vise. It is going to stall very easily and the tool selection is very limited compared to devices with a 1/8 collet sharing the Dremel type tools. While not cordless, I have found this to be very useful for light work. It weighs in at 6.8 oz, so is very easy to use. Dremel 2050-15 Stylo It also takes the Dremel keyless chuck eliminating the need to change collets for the smallest drill bits on up to 1/8 for all Dremel type accessories. -
Jiggling or Nibbling
Gregory replied to CLovehitch's topic in Building, Framing, Planking and plating a ships hull and deck
The Jiggling or Nibbling didnt show up till late 18th century.. The hook method that Allan illustrated may have been used. -
Split ring making process
Gregory replied to Dave_E's topic in Metal Work, Soldering and Metal Fittings
While I'm sure soldering produces a great result it introduces a another set of tools, materials and skill set, and the result requires blackening. It might fit better in another topic, as the one who requested help said: -
Thanks for starting this. I have struggled with making these look good. I really like CPDDET's fine cut-off disks.. I now have some on order. Like everything he does, Chuck makes it look so easy. He's probably made thousands of these. If only he would start selling them.. -
Coating with CA might work as well.
