Everything posted by Barbossa
Hello, Sjors & Patrick good to hear from you and thanks for looking in, comments and all the likes. Hi B.E. and Jason : also good to hear from you Regarding the seats of ease : I'll defnintely need to check out the plans. I have the unpleasant feeling to have overlooked/forgotten something. Ahem... The cheecks & rails placement ( Yes, those pics were intentioned ) : although I used the supplied cheecks & rails , I noticed a gap between the lower rail and the figure-head's feet. As my carving and scratching skills were ( and still are ) limited, I made a kind of a connection piece. So in fact : you have the cheeck, the connection piece and the lower rail itself. The blue strip is just a painted paper strip which I glued upon the rails. Now it's position : If my understanding of the plans is correct : there's supposed to be a smaller plank just above the wales. When you take a look at the last pic you may notice a walnut plank between the black wales and the yellow wood. This one was supposed also to be painted in black, but I did not like the sight of that. But this is only my personal point of view. In summary : I fixed the lower rail according and on top of the "real" wale. Jason , I perfectly understand your frustration regarding this (quite visible) detail : the more sources you look up, the more different answers you get . A compromise beckons ?
Hi, It took a little bit longer but here's my best shot related to the seats of ease. Just behind them there's indeed an intriguing void, so I wouldn't felt that comfortable on these seats of ease.... Other pics are related to the preparations of the yards. Some bending was required. For the footsteps or whatever they were called I used 0,5 mm brass
Bedankt,
Dit bevestigd helemaal wat ik al vermoedde.
De onderste "wale" bevind zich net boven de waterlijn.
Ik maak er een "post" van in mijn bouwlog.
Eerst nog wat studeren over dit onderwerp.
Via de tekening van Mathew Baker moet dit zelfs rekenkundig te bewijzen zijn.
Hoop ik
Ps,
Hoe is't met de kat (wij hadden vroeger ook katten, vandaar)
Groetjes
Patrick
Prachtig werk, Hennie ! Great Job on an impressive ship.
- 214 replies
- agamemnon
- caldercraft
Well... little by little this journey comes to it's end And what a fantastic journey it still is. Fingers crossed for the cleaning
- 366 replies
- pegasus
- victory models
Hi Chris 2 different shipyards , both stunning work How do you manage ?
- 144 replies
- corsair
- bermuda boat
WOW !! This is a great job, Don There's so much more than the typical 17 th & 18 th century warships. I often make this mistake Wonderful photo's.
- 653 replies
- trabakul
- marisstella
Hi Jason, thaks for drawing my attention regarding the additional seats : I'll have to check this...stay tuned By the way : I completely forgot to post pics related to the seats in the gallion. This turned out rather well( a job for next W.E. ) Styrene has proven it's utility in previous occasions. I can only recommend it. Some tiny parts in cutting and shaping out of walnut ?...I don't think so. I have 2 diifferent sheets at my disposal : 0.25 mm and 0.5 mm. Now a less pleasant job : to the vet with my cat. She's 16 years old and not going to well lately and a blood analysis is required.
Hello, Yards : preparation : The stunsail brackets As Ray quite rightly at page 15 mentions (HMS Diana by Ray - FINISHED - Caldercraft/Jotika - A 38 gun Heavy Frigate, 1794) they are a bit oversized, indeed. I decided to go for the "styrene"-option. I used 0.25 mm thickness sheets. As the end of the yards are tapered, the strip that was to be bended and fixed with superglue around them, described a small curve. The stunsail brackets are to be overpainted anyway. The 3rd pic shows what was supplied with the kit I also had to fore a 1mm hole at both extremeties of each concerned yard, no big deal.
Great Job ! Especially the rigging : this is a benchmark for me.
- 1,616 replies
- caldercraft
- agamemnon
Congrats Bob, wonderful job I'm impressed by the quality as well as the speed of this performance.
Thanks a lot Patrick, much appreaciated this info. Pics related to the subject from HMS Victory are super !!!What a difference between sailors and officers, isn't it ? In the meantime, the problem has been solved. I'll post some pics next week. regardless the poor weather conditions, we're to spend an extended week-end at the Belgian coast. Perhaps other Diana - builders ( maybe also other kits ) faced the same problem ? The two protruding masts may obstruct the original ( correct ) position of the seats of ease At present I'm preparing the yards Thanks for the input.
Hi Nils As so many, I'm following your log with great interest & admiration. As this is a scratch-build log , I can only refer here to a famous German writer : "In der Beschränkung zeigt sich erst der Meister."
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Hi Chris, This is solid, least to say. Regarding the wooden hull, is this also a (double?) planking procedure, similar to period ships ? If so, a lot of sanding will be required to obtain a smooth surface, I guess. Went through some"googeling" : along with her sistership Musashi = these were huge ships
So far for the good news show. Here's a word of caution related to the position of the seats of ease in front of the gallion. As the pics show and as consequence of a mistake of mine the, holes are covered. So I filled them up, sanded with a high grid. I'll see were to install on the gallion the seats of ease later on. Sad but not critical.
Hi Nils, Sjors & Patrick Thanks for the nice comments & the likes. Patrick : Please, take a look in Sjors' Agamemnon buildlog. You'll find them. In other logs too : Vanguard, Pegasus,... Diana never had, so this detail is a bit fictitious, I'm afraid. Also the open bulwarks, I guess. But it's fun and those features were typical for ships from the second half of the XVIII century, so I still work within boundaries The funny thing is : I have no idea what purpose they had. Moreover, in French they are called "Pattes d'Oie", I think. So here's already another bird involved (Oie = Goose). I wonder in Dutch...? So if anyone has an some info regarding the use of those crowsfeet : feel free to drop a message
Crowsfeet ? I love them For the interested : the euphroe-blocks are made of styrene. Walnut was not an option I fixed 2 small sheets of 0,5 mmm and one of 0.25 mm in the middle : thas was (more or less) the suitable thickness. A needle and a pin to obtain the best possible alignment to fore the 0.8 mm holes The paint is from the Acrylico Vallejo-brand and the 311 colortype is until now the closest to wood, at least in my opinion, some more filing before assembly and that was that. Here's the pics (part I)
Hi Patrick This is very nicely coming allong. Frames & inner structure are super and very instructive to me Keep up the good work
- 756 replies
- galleon
- golden hind
