Everything posted by HIPEXEC
I'm building a Constructo Constitution and am happy with it so far. It has several "bugs" in the instructions which have given me a fit, but I think it will be quite beautiful when finally finished. Rich
Nothing! I have to shop for some trim/molding or modify some of the smaller planks to have a trim like appearance. I'm going to a doll house shop to see what they have.
- 1,756 replies
- constitution
- constructo
Sjors, I'm trying to figure out what to do as we speak. That is where I set the transom on a wrong angle in the beginning. Any ideeas? Rich
- 1,756 replies
- constitution
- constructo
I'm almost though laying the new floors in my house and still managed to make some progress with my model. I'm trying to rectify the mistake of the wrong angle on the transom by retrofitting the whole gallery. I've fabricated a lower frame to hold the pre-cut window provided by Constructo (this happens to be the tarnished one that Construct says they will replace. I'll have to fabricate fore and aft spacers to compensate for the wrong angle. The window will be final installed when I get the replacement. While I was fiddling with this project, I managed to break an upper gunport. Like Wes told me, It glued back just fine.
- 1,756 replies
- constitution
- constructo
Ship's construction on hold account of home construction project. I'm working on the whole stern area whenever I get a minute. I had to re-build one of the window frames on account of a mis-alignment.
- 1,756 replies
- constitution
- constructo
Important all Constructo model builders. Now that I've rectified all the errors made way back when, let me alert all future Constructo builders. When mounting the false stern piece to the false keel, double check the correct angle with the plan. I glued mine to the pre-cut angle and didn't check the drawing and when I got around to finishing the stern area, the angle is off by at least 2 to 4 degrees. That screws up many things that I have already fixed or will have to fix at a great amount of time consuming work.
- 1,756 replies
- constitution
- constructo
I decided to check the symmetry of my hand carved gallery replacements, so I took a bird's eye photo. Not bad!
- 1,756 replies
- constitution
- constructo
Port side gallery rough planked top to bottom. I'm taking the grandkids on a spring break vacation until next weekend, so all ship building will be suspended on account of I'm the only shipyard worker.
- 1,756 replies
- constitution
- constructo
Starboard gallery rough planked top to bottom. I'll plank the port side next, then clean up the rough edges.
- 1,756 replies
- constitution
- constructo
Looks great! I thought the stern would be a piece of cake, but it's just as tedious as planking. Lots of angles and curves to deal with. Rich
- 2,191 replies
- confederacy
- Model Shipways
90 % of the transom is planked. Now I'm starting to plank the starboard gallery or castle. It's tricky. After all of that is planked, I'll have to clean it all up. It's full of jagged edges and small spaces with some glue spots. Hard to do all these bends and curves without all this.
- 1,756 replies
- constitution
- constructo
I'm going to copy your jig method when it comes time to rig my guns. Thanks, Rich
- 335 replies
- Constitution
- Mamoli
(and 3 more)
- 1,756 replies
- constitution
- constructo
Constructo said they will send me a replacement for the damaged part...I take back what I said about them.
- 1,756 replies
- constitution
- constructo
I e-mailed Constructos distributor in Spain a few days ago. I got their name from Phils Hobby Shop where I bought the model. I'm going to buy "Flitz" as recommended by Augie. I found it on Ebay for fast shipping. I hope I don't need any more parts!
- 1,756 replies
- constitution
- constructo
I used some "Brasso" I had to clean up the tarnished brass piece. It's not a bad clean-up. I'll look into Augie's stuff. too. By the way, Constructo's distributor hasn't answered my e-mails as of yet? Not very good support. In fact no support.
- 1,756 replies
- constitution
- constructo
I just finished tapering my transition plank from 1.5 mm on one edge to 0.5 mm on the other edge. I just glued it in.
- 1,756 replies
- constitution
- constructo
I made a tapered plank to transition from the added stern piece I made to add to the original stern. I also glued on the stern post so I can plank up to it for a neater stern when it's done.
- 1,756 replies
- constitution
- constructo
I've glued all the gallery pieces on today. Tomorrow I'll start veneer planking the whole end of the ship.
- 1,756 replies
- constitution
- constructo
Here we go again! I opened the plastic bag containing the transom & bowsprit decorations and they are bent, stained with some kind of dried liquid spots, the black contrast background is gone, so it's just brass on brass, missing stars, and to top it off, the angle on the windows is a few degrees off from my build....and my build is right off the built in angle the kit came with. Go figure!?
- 1,756 replies
- constitution
- constructo
