Everything posted by HIPEXEC
Still holding off on installing that stern piece.
- 1,756 replies
- constitution
- constructo
I've already bought my beeswax even though I am no where near rigging.
I'm "dry" fitting the frames of the lower gunports before gluing them in place. Constructo calls for me to fit the lower and upper frames pieces before the side pieces.
- 1,756 replies
- constitution
- constructo
Whatever you do....do it carefully! Think and plan it. Good luck.
Here I go again! Having to play chess with a poorly fitting piece provided by Constructo.. The pre-cut stern is about 2mm too big in the vertical even though I built the frame exactly as it appeared in the plans. Now I have to "play chess" all the way to the last page to make sure I don't cut off too much to finish the veneer planks. If the plan called for me to finish it with full size planks...it will fit. So now I stop and think and thinks and think. I'm going to skip the stern and frame the lower gunports while I think.
- 1,756 replies
- constitution
- constructo
I finished framing the upper gunports. Very tedious work. Now I can finish trimming the deck since the upper gunports are not fragile now.
- 1,756 replies
- constitution
- constructo
Tedious framing. My new tool has given me better quality woodworking, but at a price. It is very slow, tedious, work: measure, cut on miter box, square an end, measure again, sand-it, place it, then repeat for the two remaining pieces, then glue in place carefully watching for alignment, squareness and glue drips. Wow. At least the results are very good. You can see the difference by looking at the ports to the left. I can see I'll be framing for a while.
- 1,756 replies
- constitution
- constructo
Here's my newest tool....a Sand-it. I hope it gives me the square cuts I'll need to do all the fine carpentry work needed to finish my model. I'll have to practice, though, since there is no power source to run the sander...my right hand has to do that while my left hand feeds the part? Practice will make perfect...I hope. P.S. I find that I am all thumbs trying to fit these tiny frame pieces. Also, I find that my engineering is all off. I'm trying to make perfectly square frames when I find that the gunwales are far from square and perpendicular. So, I settled on gluing the sill or base piece first, then cutting one vertical to get the exact angle at the sill to give me a perfect match. All very tedious but rewarding. I'll have to sharpen my engineering skills for future pieces.
- 1,756 replies
- constitution
- constructo
I decided to invent my own way of drilling all aspect perpendicular holes in the deck. I made a jig that lays flat on the deck and only lets the drill bit make a completely perpendicular hole. I also put some masking tape on the bit to let me know when I'm deep enough (10mm). I also put tape over the prospective hole site to prevent splintering. What do you know, it worked!!!
- 1,756 replies
- constitution
- constructo
I need to drill three holes that will be perpendicular to the deck from every aspect. Any tips as to how to do this. I'm about to build a drilling guide that will sit perfectly flat with a perpendicular hole in it. I have no idea if this will work. I would like to hear all ideas. My first build the masts had a rearward rake and it took me forever to get them parallel and aligned. The perpendicular ones should be easier?
The plans call for me to add more realism to the deck planks. To make it easier, the plans called for me too lay full length planks, which is what I did. Then, I scribed cuts in the planks simulating the actual way planks are laid. Now, I just added the nails. I tried several methods and didn't like the outcome. I tried drilling with a mini drill bit, but it splintered the planks. Then I tried a very pointed awl. That method didn't give me nail-like impressions. So, I got this bright idea to sharpen several #2 pencils and try simulating the nails with them....the result was the best of everything I had tried. Today, an old model maker friend looked at them and actually thought I had hammered nails in!
- 1,756 replies
- constitution
- constructo
I framed a few of the upper gunports and they are much stronger. I'd really have to exert a lot of force to snap them. Not like before. I don't think planks held by tape would do the trick. These gunports have to be framed anyway, so I'll just do them all and feel much safer. I have to put some deck trim around the base of the gunwales on the inside. That would be tricky if I didn't support those gunports. It will be close work with my thick fingers working right against the gunwales.
- 1,756 replies
- constitution
- constructo
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
HIPEXEC replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Unbelievable! I'm in awe. Great work.- 883 replies
- royal caroline
- ship of the line
I started framing the upper gunports the old fashion way. A mitre box and eyeball sanding the ends. Very tedious! I just ordered a Micro-Mark "Sand-it" which looks like will give me furniture finish cuts that will fit nice and tight. Augie gave me the tip, so thank you Augie.
- 1,756 replies
- constitution
- constructo
Gunwales are complete. Now I have to carefully file and sand the excess wood and glue off. Next, I'll skip way ahead and install the frames on the upper gunports for added support so I don't break them while adding deck trim, bow stems and rudder post, aft cabin windows and stern windows. Then I'll install the top rails.
- 1,756 replies
- constitution
- constructo
