Everything posted by RossR
I have completed the planking and added the cap rail. I am really happy with the planking, but I a really disapointed in my staining results. My three previous kits were from Occre and they supply Lime Wood for the light color wood in their kits. I stains up really nicely, and I have not had to worry about using any sort of pre-stain product. Clearly the basswood needed something to help it evenly absorb the stain. I did some research online, and sounds like the only real solution involved a lot of sanding which is not really an option when using 1/32 inch material. I am glad I am learning this lesson on this model and not my Essex or Syren. Next up will be adding the frame and painting the background black.
You may have noticed in some of my photos, the wale was installed using a darker colored wood. I decided to buy some walnut and use that for the wale, cap rail and any of parts that were colored black in the prototype. The wale will consist of 2 layers of 1/32 material. After installing the first layer for the wale, I was not satisfied with the result. I struggled to get a smooth edge. I decided to remove the first layer and create the first layer with a continuous strip of basswood to ensure a nice smooth edge. I used two 1/32 x 1/8 inch strips for the bottom layer. I will complete the wale with the walnut on the second layer. Here is the model with the first layer of the wale installed and all of the planking below the wale completed. Above the wale I decided to use 1/32 x 3/16 inch basswood strips instead of cutting the pieces out of the basswood sheets. To create the template for the cap rail, I used a piece of cardstock and traced the outside line of the rail. I then used a compass to create the the full width of the cap rail. Below is the hull with the cap rail installed. I used 1/16 walnut for the cap rail. I thought 1/32 material wasn't substantial enough for the cap rail. I used a hobby knife to cut the cap rail, but that was difficult with that thickness of walnut. I should have used my scroll saw instead. next I will plank the stern, add the second layer of the wale, and stain and varnish the hull.
Moving toward the rear, I added a small piece of backing between bulkheads F and G to support the steeler that was added at the stern. Looking at the model now, I don’t think I made the steeler or drop plank look and elegant as I should have. I think I was so focused on getting a good fit between planks I didn’t think about how the plank looked. One area where I deviated from the plans was the method that I used to create the tape template. The instructions used blue painters tape and a compass to mark the bottom edge of the plank. Instead of traditional blue painters tape, I used Frog Tape brand Delicate Surface painters tape which is a translucent yellow color. I start my process by making sure that the tick marks on the bulkheads are as dark as possible. I then place the tape across the bulkheads. The marks show through the tape. I then use a carpenters pencil and lay the lead across the top edge of the plank below the one I am creating and make a pencil mark on the tape to make the mark for the bottom edge of the plank I am creating. I then trace the tick marks that represent the top edge of the plank on the tape. I put the tape onto a light colored section of my cutting mat and use a french curve, ruler and anything else I can find that connects the tick marks with the correct curve. I then place tape on my basswood and use a scalpel to cut out the piece. I leave a little extra meat on each end and use my Ultimation sander to get the angle right so it meet up with the adjacent part and slowly reduce the length until I have an nice snug fit. A few months ago there was some discussion about knives and other cutting tools and after following the conversations I decided to purchase a scalpel handle and a box of blades. The scalpel blades work great for cutting the 1/32 inch material for this model. The blades are very sharp, but do not stay sharp as long as a good exacto knife blade. You can buy a box of 100 for about 10 cents a blade on Amazon, so even though they don’t last as long, they are a good value. below are pictures with the bottom two of three belts complete. I will have more details on the planking process in my next post.
For fairing the hull I made some sanding sticks out of some paint stir sticks and some smaller ones out tongue depressors. Those in conjunction with this flexible sanding tool were used to fair the hull. I think fairing a hull is the least enjoyable yet most important steps in building a model. I found I needed to work in small amounts over several days. Frequent checking with a plank and patience are the keys. I shimmed a couple more bulkheads to get things right. After I was satisfied with the fairing I used a string to determine the line if the garboard strake. I followed the instructions on the with of the garboard and the broad strake. After the broad stake was installed, I created tick strips for each of the bulkheads. Starting with bulkhead A, I marked off 12 equal width blanks using the planking fan. I then repeated that for each bulkhead moving forward. Eventually I dropped one plank from the middle of the bulkhead 4A leaving 11 planks at the bow. I think one of the most important letters I learned on this project was to take the time to redo things if I am not satisfied with the results. The first plank at the bow above the broad plank was created installed and removed 3 times before I decided the 4th one was worth keeping. I was a little worried at that point thinking every plank was going to require 4 tries before I was successful. However, I quickly became better at creating the tape template for the planks and cutting the planks out. Creating the plank above the drop blank was one of the more complex planks that I needed to create. It took a couple tries to get one that fit properly, but I am pretty happy with the final result. I will have more information on the planking on my next post.
Impressive work on the calculations. I am by no means a planking expert, so I will have more questions for you than answers. are you planning on edge bending your planks to achieve the required curve at the bow, or will you be cutting curved planks out of sheet stock? If you are edge bending will you make the tapered planks based solely on you calculations? how will you handle the taper required from your last bulkhead to the bow or stern? I am near the end if my first successful planking project, so to repeat, I am not a planking expert, but you will likely need to adjust and fit these based on the hull and not just these calculations. They will be a great starting point.
After gluing the keelson to the building board, I used some micro chisels purchased from Lee Valley Tools to deepen the notches that the bulkhead will fit into. I used a machinists square, legos and a few other items to keep the bulkheads square. I was a little skeptical of how good of a bond I would get to the building board since there was no downward clamping pressure where the two items met. I was pleasantly surprise at how secure the bond is. The kit came with laser cut pieces to glue between the bulkheads for added strength and stability. I found these were just a bit on the small side to use. At first I worried that it was because my bulkheads were not square, but I never ran into a situation when they were too big, so I decided they must just be a little too small. I used scrap wood to create the parts needed. It became obvious that some of my bulkheads would require shims. In at least one case it was because I didn’t make a deep enough cut in the keelson. I had some .6 mm sapeli left over from my Occre builds, and dimensionally it worked great. It is so flexible it fit around curve of the bulkhead easily. The only issue I ran into is the dark color made pencil marks difficult to see. Next up is fairing the hull.
Me too. Fine line between calming you just a little and calming a little too much, but I enjoy a little scotch while modeling occasionally.
- 332 replies
- Harpy
- Vanguard Models
When I started building my NRG Half Hull, I didn’t know if I would do a build log on this one. After the NRG had a sale on this kit a couple of years ago there were a number of really well done build logs and I wasn’t sure If I would have much more to offer. I did take a bunch of pictures along the way, and now that I am a few weeks into it, I have decided to post a build log and share my experience. I don’t remember which build log mentioned this, but someone commented that they found building on the foam board suggested in the instructions difficult. I had the same concern, so I decided to build my model directly on a piece of poplar that will be the permanent board for display after the model is compete. The instructions have you glue the print to the foam board. Since my board will be the permanent display board I didn't want to glue the plan to it, but I needed to find a way to transfer critical points to the board I was using. I taped the plan to the board and used a small awl to transfer critical points to the building board. I then connected the dots to have some reference points for gluing the various parts to the building board. I then removed material from the keel, keelson, stem, deadwood and other related parts to create the rabbet. After creating the rabbet, I glued the parts to the building board using the small marks made with the awl to get everything placed properly. The board I used is big enough to accommodate a frame that I intended to add after the half hull was compete, so there was a significant distance to the edge and some parts of the model and clamping created some challenges. I was able to get creative with a bottle of scotch to get a strong bond to the building board. I used Titebond Wood Glue for almost everything on this model. I will cover attaching the bulkheads next.
After two and a half years I have finally finished my Frigate Diana. It took me awhile to determine how I was going to mount the ship. This kit does not come with either a cradle for displaying the final model or for use during the build. I built a crude cradle to use during the build, but I wanted to mount the finished model on a couple of pedestals mounted to a piece of live edge walnut that I already owned. Unfortunately I didn't plan ahead. I should have drilled holes into the bulkhead former to accommodate long pins when I could flip it over. I didn't do that so I had to figure out a way to drill those holes from below with out flipping the model over. The base is 1 inch thick, and the pedestals are about 1.5 inches high I installed a 4 inch long 1/8 inch diameter threaded rod from the bottom side of the base though the pedestals leaving about 1.5 inches that are inserted into the bulkhead former. The bulk head former is slightly less than 1/4 inch thick, leaving very little margin for error. I did have a problem with one of the holes, luckily it was on the side that is not displayed. After being in this house for about 10 months so far, thanks to my wife we have found a way to display my models. At the bottom of the stairs to our basement we have a niche in the wall my wife wasn't sure what we wanted to do with. As an early Father's Day present she found a chest of drawers that had been refinished and we decided to use that chest as a way to display my models in the niche. The Frigate Diana's base is mounted directly to a couple of shelf brackets. I want to thank everyone that viewed, liked and commented on this build log. I really appreciated all of you interest. I have already started my NRG half hull, and will get a build log started and catch anyone who is interested in that project soon. After that I though I would build the US Brig Syren that is in my inventory, but I think I will go with the USF Essex instead. Hopefully I get that started in the next 30 - 60 days.
Best White Wood Glue For Ship Building
RossR replied to OldeManToad's topic in Modeling tools and Workshop Equipment
Titebond will let go with some alcohol. I brush a little alcohol on the joint and it lets go in about 10 minutes. I have used Weldwood with good results. If you can use the thin CA without making a mess congratulations. I really struggled with the thin CA and threw mine away. I find my self using Titebond more and more instead of CA, but it is good to have a few options in your tool box. -
We are lucky to have people like you and Chris Watton to push the envelop and use new technology to advance our hobby. I recently purchased some of your printed blocks, the level of detail on the 3/32 and 2mm blocks is just incredible. I will be practicing stropping the 3/32 inch blocks for use in my next build, either the USF Essex or US Brig Syren. The belay pins look great. I will be interested in how the 3/16 pins work out.
I use a round wooden handle from a pin pusher. I am not positive, but I think for laminate countertops tops a roller would be used, but no clamps that I am aware of. I can’t speak to what cobblers do, no knowledge on that subject. Occre specifies the use of contact cement in their models for the second planking and has good video instruction on its use in the series of videos for HMS Beagle. I know a lot of kits would have thicker material for the second layer of planking, I am not sure if contact cement is best in those models, but if you building an Occre model with two layers of planking I would recommend following Occre’s instructions.
I see this comment from time to time. Contact cement is used for laminate countertops, and I have lived in houses with 50 year old countertops that show no sign of the glue letting go. it does have very specific applications and certainly isn’t useful for most modeling applications. If you have 100% surface contact, especially when one layer is as thin as Occre’s second layer of planking or two flat surfaces like decking on a plywood base, I think it is an good product to use. You do need to use it properly. Apply it to both pieces and wait for it to dry to a point of being slightly tacky when you touch it. When the two tacky pieces make contact you get a very strong bond.
I don’t know if I am more impressed with your quality or speed. The combination of the two is amazing. Great work.
- 73 replies
- Harpy
- Vanguard Models
Using CA, I have had success, for example, my pin rails were glued to the bulwarks after the bulwark had a second layer of Shellac. The edge of the pin rails would have been left unfinished. The bulwark would have received two coats with a sanding with fine steel wool after each. I had one pin rail come off and need to be re-glued. I think as more layers or thicker layers of shellac are added you will have less success. Items with less surface area are more problematic, but that would be true if glueing bare wood to bare wood also.
There have been a number of very nice results from first time builders with this kit. I think you made a good choice. Good luck with your build.
- 37 replies
I have reached a milestone on the model today. I have added the driver topsail and the bow sprit sail. This completes the rigging on the ship. two items left. Adding the anchors and then adding a lot of rope coils.
I really enjoy your build logs. Your work is always great,
- 73 replies
- Harpy
- Vanguard Models
