Everything posted by Rustyj
Ah the first of several sore arm moments! Very nice and also dusty shop is a happy shop!
- 840 replies
- winchelsea
- Syren Ship Model Company
Thanks Maurice. It's all to the excellent design. Well I must say I had more time in the workshop these last three days than I did in the last two months. It was wonderful! There are 3 layers to the hawse hole area. They were clamped on the model and heated to set the curve. After shaping and gluing them in place I sanded the upper cheek and hair bracket to fit the hull curve. You can see how I left the frieze longer than needed. I then over lapped it and using a sharp scalpel blade cut it to match and glued it in place. You can see the completed overlap and the scroll also added. I have to yet permanently attach the figure head as I'm worried I'll do some sort of damage to it. Next I'll shape the bolster, drill out the hawse holes and add the knee above the hawse holes. What a great weekend!
- 642 replies
- winchelsea
Yes Chuck slow and steady it is! Also thanks, JJ and Vladimir ands all the likes.
- 642 replies
- winchelsea
So far so good I think. On the starboard side I used temporary double sided tape to attach the template. With this I was able to mark off the location of the cheeks and hair bracket. I had to make some minor adjustments to the stem and figurehead to get everything in an alignment that I liked. The frieze on the checks was left a little long to overlap onto the hair bracket. Once the hair bracket was in place I used a sharp scalp blade to cut the frieze. There will be a lot of cleaning and paint touch up once I'm finished. On to the port side now.
- 642 replies
- winchelsea
Thanks Chuck, Its all been fun but now it's onto more fun! I shaped and added the frieze to the checks. I then started shaping the hair brackets. There are three layers and I started with the center one. I removed the char and rounded the edges. Next I have to shape it to fit snug against the hull and stem. It's hard to see in this picture but I've got a good bit of adjusting to do. Once the inner piece is shaped to fit the two outer pieces will be glued on. There is an etched line in the top piece that will hopefully give me the correct angle for when attaching the hair brackets. Lots of different angles and planes. Gulp. Here I go!
- 642 replies
- winchelsea
Thanks Tim and Glenn! Also thanks for the likes!
- 642 replies
- winchelsea
The bridle ports are now finished and permanently in place. I'm glad there aren't any more to do. Next I'll start on checks, hair brackets and hawse holes but first I had to paint the upper portion of the stem. Between coats I sanded the faces of the multiple pieces with some 320 grit sandpaper. These pieces are all cut from Cherry wood and part of the chapter 5 package.
- 642 replies
- winchelsea
Very nice work Derek. Just like you anywhere there were laminations that would end up painted I coated them with wood filler just in case.
- 345 replies
- Duchess Of Kingston
- Vanguard Models
Thanks Chuck. Hi Glenn, I found fitting the lids more challenging than the brass so no problem! Also thanks for the likes!
- 642 replies
- winchelsea
Thanks Kevin, Sorry missed your post. Also thanks for all the likes. Trudging along slowly. Just got back from a little trip to keep the Admiral happy. I've finished the lids on the port side and heading to the bridle ports.
- 642 replies
- winchelsea
Hi Tim, I have the MF 70 and agree with Justin P. Great little mill but I don't think spindle sanding would be good. At the time I didn't have a drill press but I did have a Dremel drill press. I built a stand and it worked real well on something as small as the echo. If you do have a drill press then chucking a sanding spindle in it works real well too.
I've been trudging along with the gun ports on the starboard side. They are set in place but the hinges have not been attached yet. I will remove the three port lids that will be open and attach them later. Until I make the stand I'll be knocking them off every other day! On to the port side now.
- 642 replies
- winchelsea
Great explanation and execution Mike!
- 607 replies
- winchelsea
That is simply stunning!
- 1,784 replies
- winchelsea
Very nice job on the planking Derek. Very neat and clean. Sorry no help from me as I think it will look great either way you go.
- 345 replies
- Vanguard Models
Thanks Chuck, Yes they were long in the making. It's one of those man I've been working on these for how long and that's all that is done moments. Thanks Glenn. When you get to that point in your build send the brass. Can't guarantee the turnaround time though! Thanks for all the likes too.
- 642 replies
- winchelsea
A little update here. All the gun port lids have been made and painted. The eye bolts and ring bolts are made and ready to go. The the hinges have been cut from wider brass stock. They have the holes for the eye bolts drilled and filed to shape. The tops now need to be filed and shaped to accept the hinge bolt. That's it for now.
- 642 replies
- winchelsea
Sorry B.E. After reading the two Glenn's logs I guess I had a brain cramp! Your work was excellent too! 😊
- 857 replies
- Sphinx
- Vanguard Models
