Rustyj
Everything posted by Rustyj
  1. Oh don't I know that. I must say I like the changes you've made to the v2.0 qgalleries over the ones we did in v1.0. Thanks nzreg. I've downloaded all sorts of pictures from various build logs and continuously bounce between them, the plans and Chucks directions. I'll still mess some up but hopefully will keep it to a minimum.
  2. Ouch! Sorry to hear about the battle damage your first hull received. I'm so glad you reordered and are back in business. Great job on the winch by the way!
  3. Thanks Jorge and thanks for all the like too! I've glued the transom in place and the filler pieces have been placed on top of the transom to cover the two layers. They are 1/64" thick! I've also placed the quarter galleries window. The starboard side framing has started. The two pieces have been temporally placed with rubber cement as I check them out before permanently gluing them in.
  4. Hi Shawn, Welcome aboard! I'm sure you'll enjoy building the Winnie. Don't worry about miss steps, we all could fill volumes confessing ours. Just take it slow and steady and continually check and recheck everything. Something I could do more of myself.
  5. I've cut the transom out of 3/64" thick stock. This is the third attempt and it seems it was the proverbial charm. First one the scroll saw went a wee bit out side the lines. The second one succumbed to heavy handed me. I rough cut it on the scroll saw leaving the lines. I then fine tuned it with knives, files and sanding sticks. I've clamped the transom in place so far the fit doesn't look to bad to me. Before I permanently glue it in place and plank the upper counter I will test fit as many pieces to see if there are any potential issues.
  6. I received chapter 3 laser cut parts in cherry from Syren today and I must say they looked great online and are even more impressive in person. Now the quarter galleries fun begins!
  7. Thanks Bob, I hope you are holding up well! Also thank for all the likes.
  8. I'm thinking it might have been the equivalent of two trees! Thanks Chuck, I'm looking forward to when I can visit you again! Thank Mike, Out of the frying pan and into the fire?
  9. Thanks Glenn, This is the second time I've planked the Winnie so I'm good there. After doing this big hull I'd gladly plank the Cheerful again! Thanks VTHokiEE and Don. Also all the like too!
  10. The last 11 strakes have been completed. Prior to starting the planking these strakes I checked my distance from the keel to the already completed 12 strakes. I noticed that at frames A and 1 (center of the model) the distance was 1/32" wider than the 11 1/4" strakes would cover. To remedy this the Garboard Strake was cut 1/32" wider and installed. I then added 2 more strakes above the Garboard. I then add 3 strakes to the completed upper strakes. This left me with 5 strakes to be completed between these two bands. I then rechecked and adjusted my remaining tick marks and then finished the planking. As you can see I still have to sand the planks at the stern post, add the stern post and trim the keel then chapter 3 will be completed.
  11. Hi Glenn, Sorry for the delay but I had to first shake some cobwebs loose. I took the lengths and pattern right from the plans. It's a four plank shift and the plans show the joint locations. I marked the bulkheads and got my plank lengths from there. Hope this helps.
  12. Hi Glenn, I think you're going to love this build and we're going to love following along. It's always fun to see how each modeler approaches a build.
