Everything posted by Rustyj
Thanks for the props Augie. Yes it's boxwood and you can see it was cut from different batches of wood. I never noticed the color difference until I started planking her. Thankfully as it ages the difference is not so obvious.
- 2,191 replies
- confederacy
- Model Shipways
A1000 hours! Wow. Well worth every minute I say.
- 2,191 replies
- confederacy
- Model Shipways
Hi Grant. Looking really good there. Those mini spales are great. I wish I had them when doing the deck clamps.
- 456 replies
- finished
- bomb ketch
Hi Augie, Really nice workmanship. I agree the water ways and margin plank on both sides looks good. Copies of the plans are a must for aligning the lower stanchions. Great job!
- 2,191 replies
- confederacy
- Model Shipways
Great job on the rigging Bob. As Augie said its pure gold.
- 1,477 replies
- essex
- model shipways
Well done Grant. You did a great job on it!
- 456 replies
- finished
- bomb ketch
Hi Bob. You're masts and rigging are outstanding. So crisp and clean. I'm really enjoying following along.
- 1,477 replies
- essex
- model shipways
Hi Grant. Best of luck to you on your surgery. That shell room was one testy little jig saw puzzle. Hopefully you've got it licked now. Again my best to you for a speedy recovery!
- 456 replies
- finished
- bomb ketch
Hi Ben. There sure is a lot of sanding on a big frame like that. I too sanded to 150 grit on the areas to be planked and then progressively down to 400. Very seldom did I go any finer than that. Keep up the great work.
- 889 replies
Great work Mobbsie. I danced to that tune whilst building that too. You got a good ear for the music
- 255 replies
- granado
- bomb ketch
Cutter Cheerful 1806 by Maury S - 1:48 - POB
Rustyj replied to Maury S's topic in - Build logs for subjects built 1801 - 1850
Very nice Maury. Reading this really makes me want to dive in and join you! I'll just have to settle for watching your fine workmanship. -
That's some fine work there Bob. Always a pleasure to check in on you.
- 1,477 replies
- essex
- model shipways
Hi Mobbsie, Everything is looking really good. I sure am enjoying watching all these builds.
- 255 replies
- granado
- bomb ketch
I LIKE IT! Well done Grant and I agree. Do the bolts.
- 456 replies
- finished
- bomb ketch
Hi Grant. I'd really like to see them sanded and the poly finish applied first. I found out the hard way that the poly can really change the look.
- 456 replies
- finished
- bomb ketch
Hi Maury, As you said getting the shape right is very important and the sanding will take a bit as that plywood is strong stuff. She's looking really really good. -
How to avoid table saw fuzzies?
Rustyj replied to Keith_W's topic in Modeling tools and Workshop Equipment
Hi Keith. As Mark said height and speed are important. I've also noticed that the number of teeth per inch can have something to do with it too. You may need to use a higher TPI blade. -
Hi Ben, I've just caught up with what you've been up to. Well done and congratulations on getting that last frame in. Following Remco's advise/motto is never a bad thing either!
- 889 replies
Very well done! It's great that you are getting together and working through the build. I'm sure it's both helpful and fun.
- 255 replies
- granado
- bomb ketch
Hi Grant. Looking really nice! I would not sand any finer inboard for now. I had to do a little more sanding later when it came time to place the deck clamps and shot locker. Once you know those will fit sand to the finish that makes you happy.
- 456 replies
- finished
- bomb ketch
