Rustyj
Everything posted by Rustyj
  1. Thanks for the props Augie. Yes it's boxwood and you can see it was cut from different batches of wood. I never noticed the color difference until I started planking her. Thankfully as it ages the difference is not so obvious.
  2. Hi Grant. Looking really good there. Those mini spales are great. I wish I had them when doing the deck clamps.
  3. Hi Vic. Your doing a fantastic job on your Confederacy. As they say you've gotta keep the admiral (boss) happy. Ben is busy in the scratch build section doing a pof Pegasus.
  4. Hi Augie, Really nice workmanship. I agree the water ways and margin plank on both sides looks good. Copies of the plans are a must for aligning the lower stanchions. Great job!
  5. Great job on the rigging Bob. As Augie said its pure gold.
  6. Hi Bob. You're masts and rigging are outstanding. So crisp and clean. I'm really enjoying following along.
  7. Hi Grant. Best of luck to you on your surgery. That shell room was one testy little jig saw puzzle. Hopefully you've got it licked now. Again my best to you for a speedy recovery!
  8. Hi Ben. There sure is a lot of sanding on a big frame like that. I too sanded to 150 grit on the areas to be planked and then progressively down to 400. Very seldom did I go any finer than that. Keep up the great work.
  9. Great work Mobbsie. I danced to that tune whilst building that too. You got a good ear for the music
  10. Very nice Maury. Reading this really makes me want to dive in and join you! I'll just have to settle for watching your fine workmanship.
  11. That's some fine work there Bob. Always a pleasure to check in on you.
  12. Hi Mobbsie, Everything is looking really good. I sure am enjoying watching all these builds.
  13. Hi Grant. I'd really like to see them sanded and the poly finish applied first. I found out the hard way that the poly can really change the look.
  14. Hi Maury, As you said getting the shape right is very important and the sanding will take a bit as that plywood is strong stuff. She's looking really really good.
  15. I'd say that you are doing a good job on a very taxing portion of the build. Keep it up.
  16. Hi Keith. As Mark said height and speed are important. I've also noticed that the number of teeth per inch can have something to do with it too. You may need to use a higher TPI blade.
  17. Hi Ben, I've just caught up with what you've been up to. Well done and congratulations on getting that last frame in. Following Remco's advise/motto is never a bad thing either!
  18. Very well done! It's great that you are getting together and working through the build. I'm sure it's both helpful and fun.
  19. Hi Grant. Looking really nice! I would not sand any finer inboard for now. I had to do a little more sanding later when it came time to place the deck clamps and shot locker. Once you know those will fit sand to the finish that makes you happy.
