yvesvidal
Everything posted by yvesvidal
  1. Folks, I have made little progress recently and I am working on installing some of the main deck beams, concentrating on the bow and front of the ship. I still have to build a third ladder for the access to the bunks cabin (from the rear house). I have debated about installing the ceilings in the inside of the boat and decided otherwise. The three main reasons are: 1) I am too advanced with the installation of the deck beams, which is making the planking of the ceiling a nightmare. 2) There is very little data to how the ceiling was installed in this craft, and the renovated Emma in mystic does not have any, to my knowledge. 3) I want to be able to see through the hull and the ceiling would prevent a view of the well and the bunk cabin. 4) I am lazy .... Hopefully, I will post more pictures soon. Yves
  2. A few little progress: access ladders and a couple more knees. The ladders are built using the leftovers of the main clamps. They are respectively 4.3 mm long and 4.5 mm long. Width is 1/2 inch or 12.7 mm for the rungs. I decided to install 4 rungs/steps on each. The basswood of the ladders is first wiped with Wipe-on-Poly to remove some of the grain and prepare the wood to staining. I am using these tricks from Chuck Passaro described on his multiple threads about building Syren and Confederate. The wood is then stained with Sherry Min-Wax. It is very light in color and will stand out better in the dark confines of the inside. Small paper strips are cut and glued to simulate the metal parts used to secure the ladders to the floor and frame of the ship. Tiny drops of AC glue are supposed to represent bolts or rivets. Mine are not too realistic and I should use liquid AC next time instead of the Gel glue. It may create a rounder and fuller bubble. The ladders are installed in the hull, leaning against the well. The front Ladder: and the rear ladder: Finally, I made two more knees and used again the in-between parts of the main deck beams (from the laser cur sheet) to build the intermediate beams: With the ladder installed and pretty much the interior of the ship finished, I can move ahead and finish building the deck beams. Once this is done, access to the inside of the hull, will be almost impossible with my big fingers.... Yves
  3. Folks, Here is the picture I found on the Internet, showing the inside of the Emma C Berry during restoration. As you can see, some of the frames have been doubled and painted white, as part of the restoration process. Clamps, knees and deck beams have also been protected by a coat of white paint. Only the original frames seem to have kept their patina. I may do that on my model: use an aging wood stain for the frames and paint all knees and deck beams with white acrylic. It should look good and allow a lot of inside details to stand out. Yves
  4. Guys, Thanks for your compliments and encouragements. I do not have too much time, just a few minutes every day to dedicate to this build, so it will go slow at times. Right now, I am working on the knees and deck beams. I am planning to show a portion of the deck un-planked and thus must build the knees and a maximum of details underneath. However, where the deck will be covered, I may not do the knees, or replace them by a piece of wood of the proper thickness. For the time being, I have done two of them, in the center of the deck where they will be visible from the top or from underneath, through the opened hull. Model Shipways provides in the kit a small laser cut sheet with only deck beams. Unfortunately, and this issue has been raised by other modellers, the curve and shape of these deck beams are not matching the main beams, causing an uneven deck. I solved the problem by simply not using the small laser cut sheet, and relying entirely on the main deck beams and the pieces of wood, in between them. The fact is that these separations are of the exact same curvature, and are slightly less thick than the main beams, making it a perfect fit. The result as you can see is very good and the curve of the deck is constant and even. To install the pseudo deck beam, just cut them off of the main laser cut sheet, place them equally/centered across the hull, as if they were a main beam, and mark your measurements before cutting the pieces. Now, we just have a few more knees to build and a lot of beams to cut and sand gently. In the restored Emma C Berry at Mystic Seaport, the knees and deck beams are painted in white color. Although it is not possible to board Emma and go below, I came across some pictures on the Internet showing the inside of the hull during the restoration. All the new double frames, knees and deck beams are painted in white. I may do that on my model. We'll see. Yves
  5. Thanks to Firefox Caches, I was able to recover the beginning of the Build Log. Here it is for your pleasure: Folks, Here is another log of that famous little boat, made by Model Shipways at the scale of 1/32. It is a serious kit for moderate level as it is a planking on frames. The instructions are also rather fuzzy, allowing you to approach the building in your own way. The booklet going with the kit is starting to show its age and the instructions provided are in no ways comparable to modern assembly books provided by Amati or the ultimate perfection such as the instructions booklet written by Chuck Passaro. At times, this kit feels like you are actually scratch building this beautiful model. The use and selection of wood strips is sometimes rather blurry and you have to use your best judgement. Along the assembly phases, you will have to be careful about saving the wood and strips, as there is none or very little spare. The picture below was taken by a member of this forum and graciously posted for all of us to enjoy. It is a beautiful picture showing the elegant and timeless lines of that little fishing boat resting at Mystic Seaport, in Connecticut: Fortunately, the Internet abounds with information about the Emma C Berry and this forum has a couple of Logs which have helped me tremendously. I wanted to express my sincere gratitude for the wonderful Build Logs by Maurys and Anno1766 (Ovali) as well as a Russian Modeller whom I ignore the name. A lot has been said about Emma C Berry from Model Shipways, and thus I will simply present some pictures of my own model and elaborate on a few delicate steps (delicate for me, of course) of the construction. The first picture shows the kit offered by Model Shipways. This is exactly as I intend to build the model, with a view to the inside of the hull, the inside of the well and some of the deck planking removed. I got my kit from EBay at a very good price as Model Expo runs some specials occasionally. The kit cost me less than $100.00, which is a real bargain. There are also some people who are selling kits that they bought long time ago and never got to put together. It is a common practice among modellers to accumulate kits and realize a few years later than the spark to make them is gone. And so is the time and energy. The picture above from the Model Expo site, shows some of the parts in the kit. The kit provides an excellent way of building the complicated hull of Emma. We have no less than 25 frames to be glued to the keel. A stand sliding parallel to the keel allows you to position each frame perfectly. The important thing here is to position the top of each frame according to the distance measured on the plan. Also, make sure that the frames are centered. Everything else is not too difficult. I approached the gluing of each frame in the following way: Glue both sides of the frames on the plan, using CA glue. Prior to gluing, frames which need some beveling are lightly sanded but not much. It is in fact much easier to fair the hull later, when all frames have been glued and stiffened by the clamps. In addition, the fairing will be true and smoother than if you were to bevel each frame individually. You can trust me on that one: once the clamps and the deck beams have been installed, your delicate assembly of frames will not budge under the frictions of the sand paper block. With this approach, I managed to glue one frame per day, and sometimes two per day. Frames were glued to the keel using Yellow Carpenter Glue which is very hard once dried. The following picture borrowed from the Russian modeler (I did not take any picture of my build at this early stage) shows the entire set of frames installed on the keel. The view is glorious and that boat resembles the bone system of a fish. It is quite a sight. It also makes perfect sense why early ship architects would have used such approach to build boats: just observe nature and replicate it! At this stage, the structure is very, very fragile. The wood on my kit is brittle (probably old - kit was dated 2003) and you have to be careful when handling it. Fortunately, the installation of the clamps is going to change completely the stiffness of the hull. Again, on that previous picture borrowed from our talented Russian modeller, you can see the two clamps which were pre-bent, after soaking them for 10 minutes in hot water. The picture below shows the clamps installed. I glued mine with Yellow Carpenter's Glue again, for extra strength. A cloth pin was installed on each frame and left drying for an entire night (50 pins total). Thanks to the clamps, the hull is suddenly very stiff and flexible at the same time. You can twist it gently, and it snaps back in place, perfectly straight and sound. Those clamps are playing a critical role in the stiffness of the hull. At this point (and I would wait to have some deck beams installed), you could almost start fairing the hull in preparation for the planking. However, before we plank, there is all the inside and deck to be built. Since very little is known about how Emma C Berry was equipped when it was active, there is a degree of freedom which is allowed. The well is precisely described on the plan, and I decided to build mine partially open as I want to show the boat under restoration (as depicted on the cover of the kit box). Besides, that well is a unique feature on a sailboat and deserves some attention and questions from the people who will look at the model. The well is painted inside, with acrylic red approaching the anti-fouling paint used to repel clams and algae. The outside of the well is painted with Payne's Grey, also in acrylic medium: The front of the boat is simply equipped with a flooring made of small basswood strips and painted light grey with a hue of blue, of my own mixing: The rear section of the hull is equipped with two bunks as suggested by the restoration book from Mystic Seaport and the plan of the kit. Again, the same acrylic color is used. Most of the structures are made with the tiniest strips provided by Model Shipways and glued first with CA glue, and later on re-enforced with white glue for additional strength. http://imageshack.us/a/img96/6199/emma5y.jpg With a couple of deck beams glued in position, the hull is now very stiff and the fairing can be done with a block of sandpaper equipped with 100 to 180 grit. Yves
