Everything posted by Jim Lad
What a difference! Great work Popeye! John
- 165 replies
- united states
- revell
Yep, coils are much easier added separately, Ollie. John
- 803 replies
- colonial cutter
- modellers shipyard
Crikey, mate, she's actually nearly there! What a journey you've been on, Kats. Obviously you're going to have to start looking in rubbish skips for another wreck! John
- 237 replies
- cutty sark
- revell
Either way for the boat for me, Ollie. If truth be known, in practice the boat was probably upended over the skylight or some other totally inappropriate place. John
- 803 replies
- colonial cutter
SS Vinal Haven by TBlack - FINISHED
Jim Lad replied to TBlack's topic in - Build logs for subjects built 1851 - 1900
Tom, Actually, I hope the starboard light is green! What sort of jack would she have flown? The company's house flag? John- 326 replies
- vinal haven
- steam ship
You kayak down a beach? The gun tackles look like they're spread a bit far apart, mate. Attached to the bulwark a little closer to the sides of the guns would look better, if it can be done. John
- 803 replies
- colonial cutter
Very nice progress, Popeye - she's looking good. John
- 165 replies
- united states
- revell
I think it's up to you, Bob - whatever you think will look best on the model. She would surely have been flying flags at some time - certainly for her launch and probably on national holidays, so if you fly flags you'll still be historically accurate. John- 326 replies
- vinal haven
- steam ship
Your hull is cleaner, Bob! When you add the flag staffs etc. she'll be a dead ringer for the original. John- 326 replies
- vinal haven
- steam ship
20 gauge shackles
Jim Lad replied to michael mott's topic in Metal Work, Soldering and Metal Fittings
Hmmmm. Very interesting idea, Michael. I'll have to give it a try. John -
Harriet McGregor by Boccherini
Jim Lad replied to Boccherini's topic in - Build logs for subjects built 1851 - 1900
Excellent blacksmithing there. Just a bit of advice - don't fit them permanently until you need to - they'll catch on everything within ten metres! John -
She's coming along nicely, Ollie. Just a totally trivial point - did you know that for some totally unknown reason most boats stowed on stern davits are stowed with their bow to starboard? It's not a rule and it's not invariable practice, but it just seems that most boats are stowed that way! Re your deadeye spacer;- that's the type used by Harold Underhill, but I've found that a 'single hole' type spacer is a pest as the deadeyes keep trying to turn around the spacer while you're working on them. Try a 'two hole' type for comparison. Get a small scrap of wood and, using a deadeye as a jig, drill two small holes spaced so that they line up with the two parallel holes on the deadeye at each end, spaced so that the deadeyes will be the correct distance apart. glue short pieces of wire into the holes and the spacer can then work by holding two holes on each deadeye, preventing them from turning when you put tension on the shroud. John
- 803 replies
- colonial cutter
Great sawdusting, Mark! Now that you've made big pieces of wood out of the little pieces that you made from big pieces, you can proceed to make littler pieces! John
