Everything posted by dvm27
Echo by Maury S - FINISHED - Cross-Section
dvm27 replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
Maury, Correct. The small lines between the frames delineates the top of the inboard scupper box (fore) and the pump discharge (aft). I would hold off on these until David covers these in his cross-section updates. You'll want to make sure you deck and waterways are correctly installed first I should think.- 324 replies
ancre Le Fleuron 1729 by rekon54 - 1:24
dvm27 replied to rekon54's topic in - Build logs for subjects built 1501 - 1750
Thank you for this Master Class in ship building. Keep those photos coming. -
I really love your wood color palate, Gary. Is that Swiss pear for the beams, riders etc?
Echo by oneslim - cross-section
dvm27 replied to oneslim's topic in - Build logs for subjects built 1751 - 1800
For those attending the workshop I will have a table saw if you want to redo your scored rising wood the way bob did. -
Sorry I missed your posting before, Bob. You get an A+ for the homework and extra credit for the fancy-pants acrylic squaring jig! Greg -
Check out Jerzy's site http://www.jbmodel.eu/index.php?main_page=product_info&cPath=47_52&products_id=629http://www.jbmodel.eu/index.php?main_page=product_info&cPath=47_52&products_id=629. His blocks are quite good
Furled , unfurled or no sails -Preference
dvm27 replied to Canada Steve's topic in Masting, rigging and sails
I'm not a huge fan of furled sails in static models but only because they usually appear over-scale and bulky. However, it can be done, and to good effect. For example see http://www.shipmodels.com.ua/eng/models/elite/le_rivoli/index.htm and the beautiful work of Dr. Mike. I've read somewhere that decreasing the canvas (model sail) size by 25% helps keep proportions correct. -
I also use carpenters glue exclusively for the simple reason that I can debond it when I screw up. Something we Swan class builders get very good at!
- 1,449 replies
Probably just a temporary brain freeze Toni but you wouldn't see a chock from the outside, only the joint between the frames. The outside looks the same regardless of whether the joint is chocked or scarphed. To be honest, I am using chocked joints on Speedwell simply because I find them easier to do.
- 1,449 replies
Dave, Your list is a bit generic so far. If you are building from kits The Period Ship Handbook series by Keith Julier is excellent. If you're scratch building The Fully Framed Model series by David Antscherl and Greg Herbert or Ships of the American revolution and Their Models by Harold Hahn are essential. For general reference of that period Arming and Fitting by Brian Lavery and Englishman of War by Peter Goodwin are essential. Chuck Passaro's practicums and building manuals are terrific for the middle.
I'm thoroughly enjoying the reposting of these excellent logs. Those ribbands on your fully framed hull demonstrate how truly fair you've made her. Quite an elegant hull.
That's funny, Ben. Many years ago my wife asked me what I wanted for my 40th birthday present. I told her I wanted to spend a few days in Harold Hahn's workshop. She thought I was kidding. I was not!
ancre LE BONHOMME RICHARD by Jeronimo - FINISHED
dvm27 replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Beautiful, Karl! It looks like the French were very fond of poulet.- 662 replies
- bonhomme richard
- frigate
Thank you gentlemen! Erik, for the tarred joints I use acid free black paper (craft and artists supply stores have this) and white glue. Depending on the joint I'll use thicker or thinner paper and the edges are shaved clean with a blade. I would strongly suggest preparing a test wood/paper/wood sandwich first and applying the finish you prefer as a test to make sure the paper doesn't bleed onto the wood surface. Finally, I perforate the surface of the paper between joints with a pin to make sure glue adequately penetrates through to the other side. I also make sure to use treenails or fasteners in these joints. As yet haven't had a joint failure. I've also used carpenters glue tinted with aniline dye powders. This works well too but is a holy mess.
Welcome back, Karl. You are truly the master of the sectional model!- 662 replies
- bonhomme richard
- frigate
More than likely, these Navy Board models were built as collaborations under the supervision of the Master Shipwright. The team consisted of master carvers, jewelers and apprentice shipwrights. Little is known of them but a few have left notes behind hidden in the models and have recently been discovered via endoscopes. One excellent reference on the builders and their models is Ship Models, Their Purpose and Development from 1650 to the Present, by Brian Lavery and Simon Stevens.
