Posts posted by Mike Y
Thanks for the tips!
Speaking of, have you ever been in maritime museum in Karskrona? Is it worth visiting to see lots of good models? Or their collection is as small as in Sjöhistoriska?
Thanks for a feedback! Probably I just looking on a wrong youtubes. Will try proxxon.
I'm looking for a small and not powerful disk sander. Feature-wise, it should have a tilting table.
Proxxon is a perfect match, but according to youtube videos, it's quite loud. (http://www.amazon.com/Proxxon-37060-Disc-Sander-125/dp/B002XZMJZ4/)
I have proxxon belt sander, and it's disgustingly loud. I use it very rarely due to that.
Is there some sander that is reasonably quiet? And small? I don't need lots of power to sand frames, for example. I can go with time and grits instead of pushing detail hard, loading the motor.
Hej Per! I'm in Stockholm. If you too - I would be happy to invite you for a grill & beer
I'm not a native swede though, moved here just 2 years ago. But pretty much enjoy people and unspoken rules here
P.S.: Do you know some shipmodelling clubs in Sweden? Apart from a Boat Builders on Skeppsholmen, who build 1:1 models.
Stuntflyer, you are right. Thanks for noticing that! Really appreciate it. It got rounded when I unglued keel from false keel and was sanding away remainings of the glue.
I made a very big bevel on Pinnace and it was a mistake - caused a tiny gap between plank and keel. So on Longboat I opted for a small bevel. If it's too small - easy to fix with a sharp hobby knife
Per, maybe it's no need to worry?
That parts would be sanded away when the planking is done, so it should not be a big deal, if it do not stop you from installing frames or planking.
Making false keel of boxwood could be tricky (cuts for frames must be on a precise 90 degrees).
I used this photo from somebody's build log (sorry, forgot which one):
When doing that scarf, the trick to avoid misalignment is to use a constant and predefined cut depth, because it will affect not only the "cutoff" parts, but the edges of the planks.
And keep in mind that it's a fully mirrored joint, so both sides could be cut clamped together.
Here is the sketch, notice that all red lines are equal (representing the cut depts).
But maybe there is some easy trick to cut that scarf quick, clean and precise. I did just a few scarfs, and hope that some experienced builder can share a trick to make such scarfs fast and easy
Ok, boxwood stem and keel looks really better, I actually did not expected how better!
Sanded it with 400 => 600 => 1200 => 2000 grits. After 2000 grit castello starts to change the color to a deeper yellow, and starts to have a shine. Really interesting transformation! Need to experiment a lot when it would be a time to apply some protective finish:
Used another kind of scarf joint for keel. I know it is not the joint that should be really used on a keel, but it just looks nicer, and just wanted to practice that tricky joint on such scale. Looks ok, or maybe I should have made it longer? Right now joint is done on an angle around 60deg, but maybe something closer to 70-75 would be better (if joint length is three times joint width).
What is the golden rule of thumb for such joints?
Close-up:
Next step is frame fitting. Frames are gently sanded, and ready to go!
Floyd, maybe we had kits from different production batches, in my kit the stem have a proper grain direction, and it's not fragile at all. But thanks for a heads up!
Actually decided to make stem and keel out of boxwood. The reason is different - stem is a bit grey, and it's not something you can sand away. It's just how basswood looks like when it's cross grain:
It's quite visible on a contrast with keel, which have another grain direction. Looks dirty.
So making it out of boxwood.
Thanks Chuck! Now I understand. Will do a proper marking this time
I placed the first 2 planks from the shear line down first according to the instructions. I then drew tick marks down to the keel as described in Chucks instructions. When drawing the tick marks be sure to insert the card stock into the bevel of the false keel. The tick marks at the keel will show you the shape of the garboard plank, I think. At least it did for me.
Stuntflyer, thanks for coming! Your build log is one of my references! Understood the idea, will try.
However, question still applies. What is the benefit of mounting the gardboard plank early on? I installed it quite late on Pinnace, and failed to find any problem caused by it. Or I'm probably just missing something, because lots of experienced builders mount it as early as possible, so it should make some sense. Would appreciate your thoughts!
Floyd, no, I didn't applied poly. I will apply it later when things are done. No feeling that it's fragile. Of course, you should handle it with care.. Plus the layer of poly is sooo thin and not so strong, that it will not protect stem from breaking if I, say, hit it with the hand.
But also there is no load on a stem. While planking, I clamp the hull using temporary piece of wood glued to frames on top, and frames are connected with each other:
I don't have exact photo, but imagine a piece of scrap wood glued right on a center.
It's quite a strong construction, hull is flipped upside down and clamped in a table vice, and then only way to break stem is to hit it accidentally
Actually never understood the idea of mounting the gardboard plank first. It is quite difficult to get its shape right. I planked pinnace from top to the bottom, and the gardboard was shaped only when I had just 3-4 plank layers left. Then you clearly see remaining width, have enough planks to make fine corrections, and can easilly shape the gardboard as needed.
Installing gardboard plank right on the start will require a really good calculations and intuition..
But, again, disclaimer - I'm not a planking expert.. Sorry..
Sure! However, I'm also not a planking expert, and will use methods described in some other build logs on that forum, like http://modelshipworld.com/index.php?/topic/1465-18th-century-longboat-by-bobf-ms-148-tri-club/ or http://modelshipworld.com/index.php?/topic/4930-18th-century-longboat-by-stuntflyer-mike-model-shipways/
Just in case somebody is interested - I started the longboat build log - http://modelshipworld.com/index.php?/topic/6801-18th-century-longboat-by-mike-y-model-shipways-148/
Nothing interesting there (yet), but a warm welcome to all subscribers of this log, I will try to make it as interesting as possible.
Popcorn, beer, sandwiches, sawdust!
It is second build, first one was a similar model - English Pinnace
This time I will make it slower, no rush. And will try to avoid all mistakes done on Pinnace
I will use kit details for frames and keel, and boxwood for everything else.
No paint, no stain, only natural wood colour. No friesers, and no paintings on a transom also. Instead, it would be planked and treenailed.
Sorry for skipping the decorations, I just prefer the simple design.
For a start - traditional photos of every longboat builder - parts sanded from laser char, keel and falsekeel, simple building jig to hold it straight.
First pinnace mistake avoided - bevel on a false keel is smaller, different angle, to gently handle a plank on an angle specified by frames. Sounds obvious, but on a pinnace I made a bevel with a wrong angle, and there was a small gap between garboard plank and keel.
First impression - it is sooooooo small! Very nice scale, it is big enough to make it with a good precision (I hope), but fits into a palm. Should be very cute when done
Thanks for that wave of comments!
Finished the display case. I made it out of plexiglass sheets and L shaped furu wood.
Looks so-so, CA is not the best way to glue plexiglass, and frankly I failed to cut accurate glass rectangles with required precision. So next time will buy a manufactured case.
It sounds ridiculous, but I have no place to put the model on display. This problem slightly crossed my mind before, but I preferred not to think where to put model before it's finished.
So now it is going to the drawer, until I move from rental to my own apartment, where I can easily mount a nice shelf on a wall
Next build would be a scratch Oliver Cromwell using Hahn's method, but I just ordered it from Lumberyard a few weeks ago.
So will start a Longboat build while waiting. Hope that Oliver Cromwell will arrive in a matter of a month or so, hence Longboat would become a side build - when I will feel bored with cutting big pieces into small pieces to make a big pieces to cut them into small pieces to make a big pieces © mtaylor.
- 42rocker, mtaylor, GrandpaPhil and 5 others
8
Remco, thanks again for sharing your knowledge!
Depends on a glue, but with PVA-based wood glues usually one surface is enough. Applying it to two surfaces you will most probably have too many glue, which you will need to remove later.
But try your glue on a scrap pieces, the best answer is just an experiment.
But now the good part. Quoting Chuck's manual - "That completes the model!!!" I'm still in progress with the display case, but she is completed! Yahooo!
Chuck, thanks again for that fun build, that looks simple, but actually forces to learn new techniques and go to the next level of accuracy.
Next buid would be a Longboat, since my wife really thinks it looks better with sails, and I want to make a better planking with boxwood
Ok, in reality I just want to make a pinnace again, this time avoiding all mistakes I did, but making the same model again is kind of silly, and I really love the look of longboat. Also, longboat build would be much slower - I will not rush things to complete it quicker.
Thanks everybody who watched, helped and commented - it is quite fun, much better then just modelling without being able to share!
- fatih79, Mirabell61, DBorgens and 16 others
19
- ggrieco, fnkershner, mtaylor and 2 others
5
Remco, would you mind if I bother you with a next batch of questions regarding finish? it is one of the best I ever saw, so I am trying to learn on best examples!
What is the benefit of microcrystalline wax comparing to tung oil, why do you prefer it now? And all that comparing to wipe-on-poly?
Do you apply finish to a tiny pieces, like the beds, closets, etc?
What finish have you used for frames?
And the last one - what is your tactics for when to finish? Do you apply it before gluing, or after?
Thanks for all advices!
- Erebus and Terror and MEDDO
2
Hooray! I finished all the messy part of gluing metal parts onto wood parts. Damn CA! Hate it!
Metal bumper looks much better then a paper one. Or I probably just cant work with the paper (some build logs of ships from card totally changed the view on paper)
Rudder tiller have a brass rod inside to make a stronger joint with a rudder:
And here is the rudder installed. Fully functional, you can rotate it gently
Trunk of the pinnace looked too empty. Then I started to think... What could be there? It is a flashy pinnace, not the one that is used to carry food supply. It is intended to transport officers. What they could carry with them?? Aha! Some high quality booze, to make sure it will not disappear while officers are on the shore.
So here is a tiny booze tank:
SKÅL!
- fatih79, gjdale, Pete Jaquith and 12 others
15
18th Century Longboat by Nirvana - FINISHED - Model Shipways - 1:48
Frame alignment is really critical to have a smooth shape of the hull, better fix it now, not fixable if planking is done.
I had just one single frame a bit out of line on Pinnace, it was hardly visible when model is not planked. Result - skewed hull shape. Nobody sees it except me, but I know it's there![:)](https://modelshipworld.com/uploads/emoticons/default_smile.png)
