ASAT
Members-
Everything posted by ASAT
What a great solution to a lot of work and wood thrown away learning how to do it right! I think I may have to follow in your footsteps, I was wondering how I could replicate those spur beams and keep all those carlings (carlines?) in alignment.....have you asked Tom if you can get replacement decks? Or is it pretty much one of the sub kits? Lou
- 312 replies
- enterprise
- caf
Much improved effort all around Kevin, Wow! that could be a great selling advert for Proxxon! (But you still had to drive it, so kudo's to you for perseverance as well!)
- 312 replies
- enterprise
- caf
Glenn, that looks great to me...primer alone is just fine, especially in the relatively protective environment of a scale model.... a top coat has a bit more hardness than primer but primer will be plenty durable .... I like the result you have achieved.
- 778 replies
- cheerful
- Syren Ship Model Company
What? ...😳??
I’ve decided to dive in to POF with both feet.... I ordered the CAF Enterprise and Le Coureur, I plan to build the Le Coureur pretty much as designed but the Enterprise I hope to build using the upright method utilizing the Ed Tosti Naiad books as a construction guide. Get going on your build log James, I plan to use your log as a guide for L.C. 😀 Lou
Looks great Kevin - are you going to trenail every frame on that lower deck?
- 312 replies
- enterprise
- caf
Yeah, I have made several shapes of sanders from wood also, but I found that as you move to the fwd cants and even the stern its hard to keep your block across two or three frames at a time, unless you make lots of different radiused blocks- the foam will conform and I find its easier to control the amount of material removed - YMMV...
- 312 replies
- enterprise
- caf
James, I found that some 1.9lb EPP foam (like computer, electronics shipping protection) the really stiff stuff works a treat as a sanding block - easily shaped with a serrated knife, and provides enough stiffness but still conforms to a concave, curved shape. Depending on what part of the hull you are fairing, you need various shaped blocks..... I have also wanted to try these : https://woodworker.com/soft-contour-hand-sanders-mssu-150-362.asp?GF=150-362
- 312 replies
- enterprise
- caf
Byrnes Table Saw making a 1mm by 1mm strip
ASAT replied to CharlieZardoz's topic in Modeling tools and Workshop Equipment
rule #5: talk to the wood, apologize for the pain you are incurring to it’s essence, carefully collect and bury the dust created from the cut. -
Yeah I don’t use a push stick - first I set a “bit” of offset clearance on the far end of the fence, I use my left hand to push the billet Down onto the table and also into the fence (fence is on the right side of blade), and my right hand (fingers) to push the billet into the blade path, as your billet gets close to the end of the cut I move my right hand around to the back of the saw and pull the piece you are cutting the rest of the way through the cut. Have you seen this user guide? https://modelshipworld.com/applications/core/interface/file/attachment.php?id=471844 -
What are the dimensions and type of wood billet you are starting with? The process is you use a larger saw to create a smaller billet down to say 3/8 to 1/2” thick, then move to the jimsaw and cut 1mm thick planks off of it (so now they are 3/8” ish x 1mm thick strips) and then take those planks and run them through again making 1x1mm strips .... hope that helps.... -
Swan-Class Sloop by Stuglo - FINISHED - 1:48
ASAT replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Huh? I was encouraged by your first post, “ hey, a guy like me! finally gonna get some insight into a TTFM build” but then you have done a ton of stuff and I don’t know how you got there? Could you point me to a link of the Oneida blog you refer to (2014)? I have one of those stalled midway also, maybe I could return to that as well with renewed enthusiasm.... 😀. Lou- 475 replies
Hi Mike, from my understanding the level differences of the kit is the consistency of the color/grain matching of the wood used in the billets? Tankerman posted this in the Review of this kit when the same question was asked.... The specifications of HMS enterprise are B and C B. C material: cherry and maple B. CWood carving: Boxwood B. CMetal parts: Brass B: window: Bovine bone 😄 window:Boxwood B has less wood color difference C is in stock, B needs to book (I need to select timber) the estimated processing time is 3-4 weeks I hope this helps, Chris I think the above should read: B. and C. material: etc, etc, so they are the same except for transom lights material and wood color and grain... I think... Lou
- 312 replies
- enterprise
- caf
ancre Coureur by cafmodel - 1/48
ASAT replied to cafmodel's topic in - Build logs for subjects built 1751 - 1800
I believe those lines are to achieve the correct frame bevel? I am asking about frame alignment and not being able to fair them with a long sanding bar. Remove the offending frames and re position? The jig only ensure that a few frames are In alignment- eyeball the rest? -
Tom, I see your hull shape came out very smooth, how do you ensure this when you cannot fair the frames after installing like other POF builds because of the clinker “steps” in your frames, other build methods use jigs and alignment aids but still major fairing must be done to achieve a smooth hull. Do you still fair the frames after installed but maintain the “steps”? -
I think the correct term is ribbands and they were temporary rib supports installed during construction to hold and stiffen the frames in place until the actual planking was installed. So if you are not fully planking they are totally appropriate (and functional) to keep in place!
- 312 replies
- enterprise
- caf
