Posts posted by pirozzi
- kmart, petervisser, KARAVOKIRIS and 5 others
- 8
Nice build. What's next?
Vince P.
- zappto, marktiedens, Oliver24 and 2 others
- 5
On 9/22/2016 at 9:33 PM, marktiedens said:
Me too! Mark and I are builders of Euromodel ships. Mark did a fabulous job on his Royal William, and I am still in the process of finishing mine. You are quite correct about Peter Coward (Pirate Pete). He is the man to count on with any and all questions about Euromodel ships.
Good luck,
Vince P.
- Zapto, piratepete007, GeorgeKapas and 3 others
- 6
On 11/12/2018 at 10:44 AM, kmart said:
Eric Good question. I haven't really decided yet. Putting that decision off as long as I can. I'm leaning towards keeping the full 8 beams just because I like the look. But I also realize its not accurate as the 1812 version. So there's my dilemma.
In the mean time...
Christmas came in Oct. Got two new Books.
Kens... Just looking through it.... WOW. just unbelievable craftsmanship. It will inspire me to do a lot more metalwork on my Connie than I intended! I Highly recommend the book to any ship modelers. I have to say it again WOW!
Second Book I had on my watch list. Normally a Very expensive book, (> $300 Yikes!) but I saw great deal on a used copy on Amazon ($50) so I grabbed it. Not so helpfully on to Connie. but will be invaluable on my next ship post Connie. I have Euromodels Royal William sitting on my shelf for retirement. But that a Looong way off. 10 years. Besides it will take me that long to finish Connie 🙂
Hi Kmart,
I have the ship book too. Paid way more than you did. 😪 I am about 75% done with the Royal William and have used this book for reference occasionally. It is also great reading. You say you have the RW waiting. It should take a long time because it is a very intense project to say the least. I have over 3 years into her so far and I am retired.
Good luck,
Vince P.
Finally finished the foremast. All of the standing and running rigging is complete except for the Course sheet, clew, and tack lines. These will be done at the very end of the build to allow easy access to the sides of the hull for what is left.
Next up is to construct the mizzen mast and step it. Then I can finish the main mast rigging. I can see the light at the end of the tunnel. A few more months and she will be completed. 🤩
Vince P.
Welcome aboard mate!
Vince P.
- geoff, Milos-1971 and BETAQDAVE
- 3
On Fri Nov 09 2018 at 5:10 PM, EJ_L said:
I did not have any problems with shipping, just took about a month to get it. Not a problem as I had plenty to do while I waited.
So far it has been worth it. It makes a solid and steady work platform and with all the components being able to tilt, swivel, slide or simply removed if not needed, it is a very versatile piece of equipment. Looking forward to seeing how it performs when I rotate the hull over for planking.
The website says that you have to get special information on shipping to the USA. They give an email address to ask. I have sent 2 messages with no response. What to do? Did you have the same issue?
Vince P.
- EJ_L, FrankWouts, Old Collingwood and 1 other
- 4
4 hours ago, mispeltyoof said:
Posting my "car crash" planking to share with others like me who see the wonderful builds on here and despair of their own efforts. I have decided then rather then fill the in enivitable gaps with filler I'll do what the original makers did and fill the gaps with slivers of lime wood.
Hopefully it can only get better 🤞
If is that bad, why don't you just double plank it. Use a thin layer of about 0.5mm x 5.0mm walnut over the first layer. Many kits are double planked for just this reason. The first layer is course to cover frames. Then second layer is easy to apply and will look good.
Vince P. 😁
- Glenns_TX, BETAQDAVE, mispeltyoof and 1 other
- 4
On 11/11/2018 at 10:42 AM, mispeltyoof said:
Vince P .In response to you ? Re workdesk,it is a computer desk though not that 'fancy" it's a solid pine desk that can be bought as self assembly on line for £100. The work station at the end is by Ochre I believe and was £50 for Cornwall ships.
A massive purchase for me as it cost nearly more than my Scottish Maid kit.
Thanks for the info mate. It sure looks efficient and neat. Also glad you decided to stick it out here. We are a great group and do help each other out immensely. I for one have been building models for decades, and I learn something new every time I log on.
Vince P.
Thanks EJ.
Hi There,
I would like to order that Building Slip you have. It is just what I need. Did you have trouble getting it shipped to the US? There is some rule about a 10kg minimum weight limit and this is just 7.4kg.
Thanks,
Vince P.
Vince P. 😁
- Fright, GrantGoodale and Ryland Craze
- 3
Hi Mike,
I did use the cloth from the kit but there was not enough. Since sewing is out of my league, I had a friend of mine who happens to be a seamstress, make the basic sails. She found more cloth that closely matched the kit. I had her stain the cloth with tea because it was very white. Real sails had a stained and weathered look. The tea did the job. When she delivered the sails, I added the corner cringles, the edge ropes, and the reefing ties.
I think adding the sails makes for a more authentic model. It does however add a considerable amount of labor and supplies.
Vince
Royal William by pirozzi - FINISHED - Euromodels - 1/70
The stern lanterns are constructed and mounted. I used some 0.8mm brass wire for the side brackets. The main supports came with the kit. I painted the lanterns so it looks like candle light in the windows.
Next up is to finish the mizzen shrouds and backstays.
Vince P.
