popeye the sailor
  1. do your garboard strake and go up from the bottom. the clinkering is due from not tapering enough, or starting the tapering too late, with some hulls, depending how blunt the bow is, you may have to do what is called 'joggling'.........starting at the bow with a single strake, and combining it with a second strake, as you proceed to the mid ship this should give you some insight as to what I'm getting at. the mid ship has more surface area that at the bow or stern. with some hulls, the mid ship may require an extra strake or two to cover completely. basically, your merging these plank and integrating them into a single plank
  2. I was kinda wondering what was stuck under the fore deck. looked like it didn't belong there. glad you got things sorted out
  3. ...need a big table.....hmmmmmmm........I wonder if king Arthur wouldn't mind........ anyway........this morning was kind of a bust. I had to make up for lost time. I did do a couple of things Friday evening, before I got ready to hit the bunk for work the next day. I made up the roof for the companionway, and I cemented the forward structure to the deck. the roof for the pilot house was painted as well. in checking the fit this afternoon, I found that it was too short......no way to center it, so there would be a sufficient overhang. I attempted to cement a strip of wood on the end of it, but the corners are rounded, and it would be terrible to fill in the gaps. so I went to the box and got out the part of the sheet where the roof was laser cut....of course another part was to close in one area, leaving a serious void near an end. I cut off the bad part and cemented what there was onto the roof. another small piece was trimmed to fill in the rest of it, adding not quite 1/4 of an inch to it. this was sanded and painted, rounding off the corners again after. when dry, it was cemented to the pilot house. I started doing something else, that was good 'n hostile......I stripped all the wire out of the red hose. I know why it was left in there, but I wanted the ends to be hollow, so to better attach the hose to pins I'll need to create.......the other end I'll have to make a sprayer nozzle. how.......I don't know......but I'll do something this is when I realized that I hadn't sealed the deck, or the pilot house. all my lacquer is in spray cans......I would need to decant them. not wanting to have a debacle with lacquer turning white on me, I decided to use the leftover Poly Urethane I had kick'in around. it left the deck and pilot house 'flat', but it deepened the grain and made it look a bit darker. I hurried this up a tad.......gotta remember to lessen the solder lump near the ring. as mentioned, the anchor is a bit too large...it also would look better on a clipper ship, or similar. on the model {which I was going to show two diagrams, but forgot to post them}, the overhead view shows the stock removed from the anchor, and laid on the deck. the dark shadow is the stock this is the only visual of the the two cold bins hatches on both sides of the deck, as well as what looks like a large hold in the center. for now I will be working with the anchor.......replacing it with a grappling hook style anchor. most of these boats would use a smaller anchor.....like a sand anchor. my first attempt turned out to be too large.........adjusting the scale in my head {no....I'm not stepping on a cat's tail}........ I though that larger diameter brass rod would work better. I fidgeted like crazy trying to get them lined up......I ended up wrapping them in wire that I got from other kits, and then soldering over it. now that I knew what to do, I used the smaller diameter rod. it looked better after trimming the shank length. the ring you see wasn't the one used......I soldered on a smaller one, and I got this. I got too much solder at the top by the ring........gotta fix that. comparing the two together, I think the grappling hook look better. ...and the comparison on the model. all it needs now is the sampson post and some rope. another thing I considered is, why do they have an anchor? they are dragged onto the beach.....an anchor is not needed for mooring at a dock, and while fishing is going on, the boat merely drifts with the current......the net goes out....the boat can't be still, it has to move. don't get me wrong.....it's good to have one in the event it needed. but, in normal operation, it's not needed. oh.....here is another shot of the pilot house base winch. it's not a windlass, or used for the anchor. I'm still stumped what it could be used for.
  4. sounds like you've been busy I use an archive pen for simulated calking. it contains India Ink which won't seep into the wood. one time though, I left the cover off too long and it dried out. I bought a bottle of India ink and gave it a dose.....works fine now, but I will have to toss it soon.....the tip is starting to fray.
  5. the BF 0134 and the BF 0171 are part of the Nordkap fittings. look in the nautical discussion forum......I posted information on the Nordkap. I will do something with the anchor to give you an idea of the direction I'm going. the anchor lays on the deck of the bow, with the stock removed from the stem of the anchor...I've never seen that in a boat or ship, let along a model of one. I will have to look to see how you have yours part #42 can be either called fenders, or breakwaters. I see the notches, but I do believe, I see a hole there as well. comparing this boat to the Cux, or the Mary Ann, both of these vessels have a pulley built into the bulwark near the bow stem. it would be logical, seeing that all three boats are of Danish construction, that I could do the same thing to the Norden, and it would look just as good. as I read about this model, it's based on a combination of information on these types of fishing boats........kinda puts in the category of a mongrel you'll find that quite a few models are generic in nature......likely the main reason why there are so many inaccuracies. I would say cost is a close second. I'm still having a hard time with the net winch......especially after seeing the video. noting that the fish in the net slides of to the left, while the drums are pulling the net in via the ropes on the edges of the net.......how is that possible with the configuration of this winch? unless the fish are removed prior to the net going through the winch, I don't see fish going through there........not unless you want to squish the fish it's gotta be me.......I must be looking for too much functionality. cold bins are located as holds on both sides of the deck......catch is prepped and thrown in the bins. look'in how that guy handled the catch, I probably should have painted the inner bulwarks red. I'll tell ya though, it almost makes me want to create another hull, and change the layout. base the pilot house towards the bow, situate the winch along side, with a sluice table, and have three or four bins situated around the table. hang the buoys off the cap rails and have a ball............ yeeeee-ha!
  6. chances are there are some lashings under there.......you may elect to drill some small holes. nicely done
  7. hi john, yepper....I have a picture of what is in of the fitting kit. I'll post it later. Billing's had fitting kit sets for a small number of their models. since tom Richardson assembled the fitting loose {what he sent me for the first Nordkap}, I surmised that there was no kit for this model. I haven't looked at how the anchor is set up, but the anchor doesn't fit the type of boat. if this was a clipper ship........maybe. I plan on making a grappling hook type anchor. basically, if this boat used a windlass, there should be hawse holes in the bow. for a winch to be that far back........well, the deck is too cluttered for that. the anchor is deployed and retrieved manually. I'll report back soon.......supper is almost ready
  8. in seeing the videos that Samson posted ......and now yours, neither of the winches are involved in pulling the boats onto the beach. the tow rope is fastened to the bow stem and is pulled by a tractor. I thought the same thing about the winch on the base.....if it was used to bring the net in, to logically rig it, I was thinking a gallow. the pulley can redirect the rope over to the roller, which is affixed to the cap rails {port and starboard}. I believe it should be either belt or chain driven....the small structure behind it should be hollow {open}, then detail can be added to give it some sort of functionality. on a much brighter note.........I have been on the lookout for the fitting kit, for the Nordkap. I did get a return on one of my inquiries...my request was being referred to someone in charge at Premier ship models. I have heard nothing since.....this was a week and a half ago. the other evening, I was sent a picture of a model, sold by Billing's. I recalled a kit that was different {but pertained to the subject}, so I went to Billing's USA to check it out. the site had changed somewhat and listed new items......one of which was the Nordkap fitting kit! I wasted no time.......I ordered it! it didn't specify a delivery date. I'll let you know when I get it
  9. super look'in progress to the rigging Bob.........nice 'n neat too
  10. I make them similar, but I don't do the scarf joints. I should give it try look really good Per!
  11. thank you very much Samson for posting these videos. the winch doesn't look like the one supplied in the model.....I notice though that the drums are flat. I had taken the large one and the back smaller one, and sanded them to look more like a reel. perhaps I shouldn't have done that? the piece of equipment that hangs from the mast untangles the net and puts it in the bin.........hmmmm. the deck set up is different. I see other videos......I will look at them as well you given me lots to think about. if you find any more to add, by all means, feel free thanks again! hello Piet! thanks for looking in and the kind comment. so glad to have you looking in saw your latest log......
  12. I don't know how I missed the start Piet.....I was looking in pretty much all last week! sad to hear about your father. I look forward in seeing your progress. how long is the model going to be?
  13. thanks everyone for the kind comments.......and to all of you who hit the like button I did a bit more, but not enough to hoot about....I'll include it in my next update. thanks John and Kevin....appreciate the good word thank you very much Samson for the pictures, but now i'm a little confused. this boat is supposed to be a coaster...is the re a difference between a caster and a 'kutter'? I've always been intrigued with boats that have part of the deck tarped over or the bow encased in a shell. Billing's based a few of their models after the Kutter... perhaps you can help me figure out the winch .....it can be seen at the begging of the log. thanks Pat.......with the number of billing's models I've built, my fleet has certainly grown. if I still had the Cux and the Susan A , the number would stand at around ten. imagine if I was all caught up...I'd be at a whopping 17 {add the bluenose project, it would be twenty} I'm not counting the plastic builds....they are another medium all together thanks for the good word ! thanks OC.......that they will........now it's pretty much deck work. as Johnnyreg has asked me earlier......I still need to make the bin. as for the flotation buoys, I already have some handy....just need to make sure the size is correct. this is always the fun part to me
  14. sorry to hear Jesse...my condolences to you and your family. a dog is just as much part of the family......lost one myself Haps {Happy} has been gone now for almost eight years.......me and the misses still miss him.
  15. there is some framework on the front wall behind it. is it loaded from inside the structure? looks really neat
  16. it's not too much trouble to put in some balsa filler blocks. if you don't want to do that, you could always try thickening the deck platform with some 1/32 basswood flat stock, or sheet wood that might be harder. either way, it's a little extra work
  17. thanks John.....the margins made it easier to plank. I didn't have to do all that cutting around the posts. doing it this way does present problems...one of these days I'll figure out a better way to overcome it. I would try and replace that 1 mm strip, but it can get very messy, so I'll just leave it be. both sides of the mid ship was done this morning. ......and I started to close up the bow section. this makes for some unique plank cutting. the forward structure was dry fitted, as was the pilot house, to unsure a good fit. the mast cap was cleaned out, so it will accept the mast. I will need to make a couple of supports for the aft mast behind the pilot house, since there is no hole for it in the deck. it didn't take long to finish the bow section. although, I will need to make a tiny addition to the starboard side front corner {inside the open area}. before I cement the structures in place, I'll go around the edge with flat black, so no sign of the underlayment can be seen.
  18. that is so cool.........and it's all in that cabinet?!?!?!
  19. oh dear.......one of the knee pieces is missing! did you take the barrel out already?!?!?!
