Everything posted by glbarlow
It is a nice feature and nicely installed, a definite plus in my book. What blacken product do you use, that’s a very nice sheen you’ve obtained rather than the usual matte result? Also what metal primer? I always go back and forth on whether to prime or not prime...
- 195 replies
- lady eleanor
- vanguard models
Willie is a cool looking dude, I like having scaled figures to stand around on my models during construction to get a sense of size. Enjoying your research on fishing craft and the modifications to Chris' design. I'm like you, no more large models for me - these small craft are more enjoyable and a lot less repetitious tasks. My head still spins from the 3,000 or more copper plates I put on Vanguard.
- 195 replies
- lady eleanor
- vanguard models
I think there is a ”wash” that some artists put on sculptures that give them depth, sort of fills in the crevices and curves with a darker shadow. My artist son would know. However that said, I think they look fine and Dullcote would finish them off great. My opinion is darker isn’t necessary, they look realistic as they are now.
- 642 replies
- winchelsea
- Syren Ship Model Company
So the brass will cut the profile into the wood, it doesn’t need to be sharpened, or you sharpen it as part of the filing?
- 642 replies
- winchelsea
You're quite handy at doing it - amazing work. More amazing is how little time it takes you to do it!
- 109 replies
- Vanguard Models
- Flirt
That’s really all you need for Cheerful, but you do need that. Chose the Byrnes saw when you’re ready, best modeling tool I own.
- 109 replies
- Vanguard Models
- Flirt
Couldn’t choose better for your first, my only issue with this and Speedy is the historically accurate but very tiny guns. I hope you also put Cheerful on your list Bob.
- 109 replies
- Vanguard Models
- Flirt
Such amazing work James. When I do my build log how about I just use your photos since I can’t match your quality🤣😂 Do you mind my asking, is building And photographing models your work, or are you just this good in your spare time?
- 109 replies
- Vanguard Models
- Flirt
To say your modeling skill is next level would imply there is another level beyond, there isn’t. Your work is superb. I may have missed it somewhere, how to you get length for your moldings, a special table or home built mod? Mine Mill is limited to 5 inches.
- 589 replies
- le gros ventre
- cargo
Thank you for all the likes and follows. It’s inspiring to know other builders are watching my progress.
- 778 replies
- cheerful
Thanks Derek and Gart! I’m enjoying the successes and working through the mistakes.
- 778 replies
- cheerful
Thanks for the interest, glad you’re enjoying it. I like your avatar. 😊
- 778 replies
- cheerful
After completing the drop plank and the first two rows of planks below the wales (where the drop plank counts as two at the bow), plus installing more than one or two fashion pieces I’ve now completed the wales. I painted them using Admiralty Paints Ironwork Black, which oddly enough is duller (really more flat) than the Dull Black I normally use. I was really tempted to also paint the counter but decided to wait until I’d at least had a dry-fitting with the square tuck I’ll somehow create after getting the next 8 rows of planks on both sides. I didn’t take any photos of installing the wales, but it’s as straight forward as on any model - I did try extra hard on keeping neat paint lines. Me and Tamiya tape did ok with that, with some effort. It’s worth it to take the time getting the tape right, its either that or scrape, sand, and clean up where you didn’t. If you’re not familiar with Tamiya tape, get some. There is nothing better, blue painter’s tape isn’t even close, in getting a close tight seal for painting - for those of us like me who lack the skill to free-hand. Though I am pretty handy with an 18/0 brush to do touchup. I also followed Chuck’s instruction to thin out the wales at the bow. I cut and dry-fitted both top and bottom planks then held them side by side on a work board and tapered them down to near saxophone reed thickness. In my case they actually did fit into the rabbit. They do look so much better this way. Since I’ll be working upside down it was time for a new stand, really an old stand modified. I go for function over form with these things so its nothing fancy, just a cut-down of a stand made for my Vanguard with some cross blocks added for stability. The fun part is I used my new mill for the very first time - for the very easy job of adding a slot down the center of the cross blocks. So now I'm a miller, sorta. I added a fresh coat of poly across what is now the completed top third of the hull. Now it’s time mark the two belts with artist tape, get out the tick strips and line the hull as I start planking the 8 rows of planks that make up the top belt. Not that anything has been fast, but this next phase will be slow going to get each plank right - and as a bonus I also get to rip more planks, so Yay!
- 778 replies
- cheerful
They aren’t typos, it is Apple making way too many decisions for me with predictive text on my iPad. I type the right word, Apple changes it to something it likes, and I don’t go back and edit. But as long as it entertains then I’m fine with it, though I really should turn off predictive text.
- 725 replies
- vanguard models
- speedy
Your method looks great, and a good choice give the guns are so tiny. You may have converted me on frapping, at least on Flirt when I get to her, Cheerful is big enough I’m sure the coils will work. The difference in your ring bolts is striking, thanks for the detailed explanation on making them, which I’ll put to use. In the book Chris recommended on Cochrane I learned he did replace all the guns with larger ones only to find the wouldn’t work for several reasons and he had to change them back. He could carry a full broadside of the shot in his pockets as he walked the deck. See you on the other side.
- 725 replies
- vanguard models
- speedy
Great work as usual. Darker may be too dark once on the shelf. Maybe look at the test pieces where you plan to display her.
- 642 replies
- winchelsea
I've yet to have a cannon come loose after I've used a drip of CA to each wheel. I do use the medium viscosity version of CA just for this task but I guess if you're adverse to CA in the first place the pin makes sense, likely a good way to have the cannons consistently placed at each gun port. I'll continue with my loose coils on my guns, and with the guns run out, it is just a model after all. Everything I've read, including the book on Cochrane says Captains had near total discretion on how to manage their ships. My Captain likes coils, and CA on his cannon wheels. I'm looking forward to seeing how your Speedy turns out.
- 725 replies
- vanguard models
- speedy
