glbarlow
Everything posted by glbarlow
  1. I built a different version of Fair American, it’s a great ship to model. You can see it via the link in my signature if you’re interested. I have planked 10 models with CA, several are over 10 years old, it is more than strong enough and how you get planks to hold in the rabbit. You’ll find CA verses PVA an ongoing debate on this forum, I’m in the CA camp. I’d add not all CA glue is equal, common store brands aren’t the best for modeling, try Bob Smit Industries, you can find it on Amazon. I use CA for most things, White PVA for a lot of things, and Titebond only for the initial framing to answer your glue question earlier. You have struck on your own the process of Lining The Hull, good work on that. Chuck Passaro has a .pdf and some video tutorial on that and using heat for plank bending. It’s a good process and great that you basically discovered it on your own. The dividers mentioned are a good approach, I prefer tick strips, either way those and your approach the key is determining the taper needed to have a plank run stem to stern without fillers (no small feat). As Greg mentioned, though you’re past this now, the most important step in building a model is proper fairing, something many try to rush and pay the price later. Generally I work down instead of up on planking other than fitting the Garboard and and a couple of bottom planks. That way any sins I might have cover are hidden on the bottom of the hull and by paint below the waterline. From your posts it seems you are only single planking the hull? It looks like it’s lime or bass wood generally used as a first planking which is then covered by walnut (most common in kits) or some other thin veneer. If you’re going to stay with the one planking I’d highly recommend against tree nailing. More often than not it turns out bad, I’ve seen some really nice models turned ugly with the measles. I’d also recommend using Wipe On Poly on your hull, it’s a great look and will provide some definition between the planks. Just wipe it on generously the immediately wipe all you can back off for a nice Matt finish. I probably put 5 coats like than on my Cheerful with light sanding and several days of drying time between. You’re doing a great job on your first model. I’m on my 11th now and still learn something new and better from the generous people in this forum all the time. You’ve come to the right place, and sharing a build log is the best way to learn. Congratulations on your progress.
  2. Two of my favorite models. The AVS was my first model, Fair American came later, I used it as an opportunity to “paint with wood”. Exotic woods were easier to obtain back then. Welcome back to modeling.
  3. That’s what the blue and red say on the bottle. You can learn all about BSI here: https://bsi-inc.com/
  4. Agree the best approach is first sand down the planking, you have a lot of thickness there you can remove. Then thin the wales as it nears the stem to be almost equal to the planking. This in fact is how the wales are done on my Cheerful by design if you want to see an example. For your next model: you should have started tapering the planks right away and not had those full width ones there (referring to where the dark ones start, not those above deck level). Lady Nelson is a good first model, but at least in mine (done as a refresher after a three year layoff) the materials were very shoddy. Your next Vanguard model will be more fun. Use LN had a learning platform and the give it to your son. 😁
  5. There are only the three, plus an accelerator and an “un-cure” which comes in handy on occasion. https://www.amazon.com/Insta-Cure-Filling-Bob-Smith-Ind/dp/B0000DD1QQ/ref=sr_1_2?crid=195Q0ZL64R7G5&dchild=1&keywords=bob+smith+industries+insta-cure&qid=1630071114&sprefix=Smith+indu%2Caps%2C180&sr=8-2
  6. Bob Smith Industries, I get mine from Amazon. They have three versions: thin, medium, and thick. I never use the thin and use the medium for 90% of what I do with CA.
  7. I think you can safely update your signature line from “pre-ordered”. 😂 I’m trying to determine if your goal is to replace James for his highly inadequate (based on your log) instruction manual 🤣😂😅😂🤣
  8. With this beautiful model I plan to do the same and agree with Mike’s call on not rigging the guns. I may include breaching ropes but that’s it. Now I get aligning all the guns, that will stand out so much more nicely without ropes all about.
  9. On this forum I am confident reporting a negative comment using the report function (in the upper right corner of a post) will get that comment deleted by our moderators, and if it continues that person removed from MSW. If it’s in some other place I’m still confident our moderators will deal with it, just bring it to their attention via a direct message. I often say if I want negativity I can go to any Facebook political post, not here on MSW. Your work is excellent, your model of a type one seldom seen here. I enjoy reading how and with what tools others accomplish tasks, especially when it result in such nice results. Thanks for coming back to share it with us.
  10. You’re doing well. One log recommendation, break up the text with photos and the photos with text rather than long runs of texts. Makes it easier to track and for the reader to stay engaged. Good stuff, glad you’re learning so much so fast.
  11. This is a beginning modeler trying to solve a simple task. Everything doesn’t need to go down long confusing trails of maritime history. Sometimes attaching a block on a mast is just attaching a block on a mast.
  12. Thank your for the comment. I still chew through blades😁but quality chisels are an excellent investment.
  13. Thanks for the comment. There is no comparison between the two, it’s a worthwhile investment.
  14. I was reluctant to do this off ship fairing on Flirt so I went light. It does help to get things moving more quickly once back on the ship I found by having the basic introductory shape done off ship.
  15. Wow, lots of complicated historical philosophizing here for such a simple question. Gregory has given you a lot of help. My Cheerful photos seem to hold up under micro photography but I can assure you at a normal viewing distance my “iron band” method, learned from Chuck Passaro btw, it definitely does. Crafty Sail is a good source of hooks, especially for the model your working on. An actual metal band would be hard to do on that mast and not worth the trouble. Your “fishing lure tie,” wraps around a looped line, inserted back through the loop and seized is exactly what’s used to ‘connect’ a hook to a rope. The block is in one loop, the eye of the hook through the other. There is a guy on YouTube, I don’t recall his name, that show how to do this. In fact a granny knot is another method, but use what you know how to do.
  16. And it works quite well I might add. If you get the lathe I’d highly recommend the three jaw chuck accessory, it’s really all I use. This is a relatively inexpensive tool that more than pays for itself. I described my use of it in my Cheerful log, Derek taught me well. i never found the bed extension, turns out I didn’t need it.
  17. You don’t seem to want the help offered. I did exactly what you’re asking about in my rigging of the masts on my Cheerful build. Seizing blocks is a common process in model building. Good luck in figuring it out.
  18. Gregory and Rylan answer your question. Simply put, use black masking tape to simulate the iron band, drill a hole and insert a blackened eyelet to complete the simulation, seize a block to that eyelet using the method described in many logs. Pretty simple. If it’s the basic how to seize a block to an eyelet or a hook there are plenty of tutorials and step by step guides on this site as well as YouTube to see how it’s done.
  19. Great info and helpful, thanks. Just curious, 1. Your reason not to just push the front trucks against the waterway? 2. Is there coaming the full run of the deck, if not how do you see the wheels when the are behind the carriage is open? Thanks
  20. Sorry, they look like they’re made from plastic….oh…🤣The glossy color doesn’t seem very authentic. I guess I’m a scoffer.
  21. Bob, I ordered mine from England, took very little time to get it. It’s a great tool. Thanks Derek, I look for opportunities to use those chisels now😁
  22. First and Second Planking I’ve completed the first planking and the stern second planking. The first planking turned out ok I think. I once again confirmed how well plank bending works and the importance of taking the time for a proper fairing before the first plank is laid. I wasn’t as precise as I needed to be on the lining work, consequently I had gap issues on the bottom of the hull, no problem since it isn’t seen and will be covered by the second planking. I had some some wider basswood of the same thickness, taking some lessons learned from Cheerful I used it for a better fit, why limit myself to a single width when I have options. (The pencil marks the widest/longest part of the hull, bulkheads 7 & 8). I am surprised by how much sanding is required around the stern. The second planking is only 1mm thick so the fit has to be taken into account by the first planking and by reducing the former for the sternpost to match up. The lime wood is plenty thick to allow sufficient sanding to get a smooth finish. I’m a fan of these Soft Sanders. I learned of them here on the forum, they get put to good use with 80,180, and 220 grit to prep the hull for the second planking. As I always do, I prepared the hull for mounting at this early stage, making it easy to mount the final model. While I appreciate the clear stand Chris provides, all my models are mounted the same way using walnut bases with brass pedestals. I make sure to drill the hole is at least a ½ inch past the keel into the former and having the rod run from there to the bottom of the walnut base. Epoxy later makes sure none of it moves once finished. Here I chose to deviate from the excellent instruction manual by attaching the stem and keel (but not the sternpost, its clamped there in the photo just to ensure it and the keel are aligned properly) before the second planking instead of after. I checked with James and Chris on this, their answer is its up to the modeler, after the second planking is how they do it. In my opinion it is much more of a benefit to have it installed now to ensure a tight fit of the garboard plank, plus now it looks more like a ship than a rowboat 😄 Clamping the long strips of lime wood either side as a splint kept the three pieces making up the stem in alignment with each other and the hull while the rubber bands held it firm to the hull while the glue dried. I used white wood glue here to make sure I had time to adjust all the alignments and did each of the three pieces one at a time starting at the stem. Next up is adding the second planking of boxwood, I love boxwood, to the stern and stern counter. More sanding, filing and chisel work to get a tight fit. There are slight curves to the counter, the curve seen from the side and also a slight bow from stern post to transom. The first I addressed by beveling one edge of each plank, the second with a touch of plank bending (using a new 1mm form cut from the kit laser board waste). A moment’s deviation. I never used chisels before Cheerful made it necessary for me to learn, I had a few but they were junk. I learned about Veritas mini-chisels from @DelF and purchased this set. I thought I was doing great until I also learned from Derek that even brand new chisels require sharpening. So I now have my own sharpening station made up from honing fluid and different grits of sandpaper after watching a Youtube video (again linked from Derek as I recall). Then one more Derek gift, the lead on the Richard Kell sharpening guide tool, which is amazing in its simplicity and results. As a test used from my Army days for a blade’s sharpness, can it shave off the lightest bit of a fingernail (I said lightest bit, not trying to remove it, the thinner the sharper). With this set up my Veritas chisels are nearly as sharp as my best Benchmade and SpyderCo knives (I’m a bit of a collector of those). I can’t tell you how often and how effectively I now use these chisels. So once again, thanks Derek. Back to the program. I completed the transom and as with the stern, using top to bottom (instead of side to side) planking. I hadn’t seen it before, but I trust Chris’ has done the research, and I like the different look it creates. As is my process, I run full planks then cut out port openings with a #11 Excel blade as I go (don’t cover up the opening entirely before notching). For those of you enjoying the which is better debate, a scalpel, no matter how sharp, will not do this job, the thin blade would shatter. I like tapering planks with the scalpel, but the sturdier Excel blade is required here, at least for me, Chris probably does this with his Stanley Knife. Also, notice how thin the stern post area is, much thinner than I’d like but necessary given the thickness of the sternpost and second planking. It will all be fine, I’ll just feel better once the second planking is complete. I’m already running color board tests from my upcoming build of HMS Winchelsea, which I hope to complete before the end of the decade. I’m pretty much settled on Winsor & Newton Crimson, because why not be RED. It will also have Cerulean Blue to match the hull decorations. I was surprised how different the shades (three of the five, the other two are different blues) are between different paint manufactures. Deciding on it will depend on which matches the printed decoration best. These color boards are always helpful and entertaining to make. I mention all this because…. Flirt is a trial run of those colors, I’ve painted the interior of the transom Crimson already and I’ve elected to paint the counter one of the Cerulean Blues to match the blue that will later be added to upper strakes. Adding to the counter now is a touch tricky, I don’t want to paint the back edges of the second hull planking, which will be sanded flush to the counter, so it’s touch up now or touch up later. We’ll see how it goes. I already have a little more touch up on the red around the stern ports, often I don’t see these things until I do a close up photo. I also did a like coat of WOP more to seal the wood than anything else at this point. On with the second planking. I said I was going to make these posts shorter, I seem to be failing at that. Thank you for all the likes and especially the comments.
