Everything posted by druxey
Well, this has unexpectedly generated some interesting discussion! Ron: You are absolutely correct; I do enjoy the challenges of making, not keeping my models. And that they go to appreciative collectors. Although not destitute, I can assure you that I'm far from wealthy in the usual sense, but am fortunate in having a very rich life. I think the above answers the idea of donating one of my models for auction as this is my livelihood, not my hobby. I wish I were of independent means! Back to the topic in hand: I've settled on ten 14' 0" oars for the model. Perhaps the bow pair may be a little shorter. Thanks to those who have contributed their knowledge; it's really appreciated.
- 433 replies
- open boat
- small boat
I usually only build editions of one. However, if someone would care to commission a different model, please PM me.... Thanks for the compliments, everyone.
- 433 replies
- open boat
- small boat
Thank you, Roger. That confirms the 14' 0" length I've been considering. Also, I agree that ten oars was the compliment, as the aftermost tholes could not be used unless sitting on the stern sheets with the officers - most unlikely! Thank you for the reference; it is most helpful and varies only slightly in dimensions from the sizes I came up with. I appreciate the input from everyone on this model. I'd also like to mention that the model has now been pre-sold to a member of this forum.
- 433 replies
- open boat
- small boat
Thanks, Eberhard. The pattern of the oars you show are a little different, but 14' 0" is pretty close to my estimate of 15' 0". The bow-most oars would be a bit shorter in the shaft, for sure. That is very helpful.
- 433 replies
- open boat
- small boat
I agree, TB. I'm thinking 15' 0" overall would be closer to the mark.
- 433 replies
- open boat
- small boat
Thanks, Bedford. Now I have to figure out the oar length. Theoretically for her beam, they should be about 19' 0" long. Seems a bit too long to me, but....
- 433 replies
- open boat
- small boat
Bien fait, Alex, et bienvenue au MSW. Welcome aboard!
The rudder has now been completed and fitted. One question I had was whether it was fitted with a short tiller or a yoke. There is a tenon on the upper end of the rudder, but no clue as to what the original boat was fitted with. Rightly or wrongly, I opted for a yoke. It is similar to that seen in some contemporary models. This completes the boat itself, apart from a little tidying up. The last task on the model itself is to make a set of oars. With a beam of under 7 ' 0", rowing double banked would seem rather crowded. Opinions, please?
- 433 replies
- open boat
- small boat
ancre La Belle 1684 by Oliver1973 - 1/36
druxey replied to Oliver1973's topic in - Build logs for subjects built 1501 - 1750
Those clamps are awkward pieces to cut and fit; you've done an excellent job. The scores for the deck beams are an additional level of difficulty. Well done! -
Absolut verrückt! Bikini babes from the Middle Ages.... What next?
- 130 replies
- wütender hund
- hanseatic
HMCSS Victoria 1855 by BANYAN - 1:72
druxey replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Very, very impressive, Pat!- 1,013 replies
- gun dispatch vessel
- victoria
Despite your own opinion, you are doing well. Improvising when something goes sideways (as will happen to all of us!) is a valuable skill in itself. And is there a deadline? Take as much time as you need to build your model. No-one has a stopwatch and is timing you! "It's the journey, not the destination."
- 160 replies
- Model Shipways
- norwegian sailing pram
Stitching sails with sewing machine
druxey replied to Jorge Hedges's topic in Masting, rigging and sails
You are the expert reef point tamer! Looks great. Nice photo demo as well, Ted. Well done! -
Thanks for looking in, everyone. The tholes were completed and the rub strake installed. The rub strake profile was rounded using a molding scraper and lengths then cut off using a slitting blade in the saw. The last challenge was the roundels at the bow. The lettering was too small to paint by hand, so I created the roundels in PhotoShop at 600 dpi and printed multiple copies. The rope ring was beige thread. I formed the rings by wrapping thread around a drill bit shank, stiffening them with white glue. When dry, the rings were sliced off and glued to the roundels. The roundels were then cut free of the paper and the cut edges match painted. The rudder is next, as this completed the boat itself.
- 433 replies
- open boat
- small boat
Minimum plank length
druxey replied to Don Case's topic in Building, Framing, Planking and plating a ships hull and deck
If only a hull were as easy to plank a s a roof!!! -
Ingenious - especially your technique for producing (sub)miniature chain.
It all depends, Don! -
Progressing nicely, Steve. Neatness pays off!
- 70 replies
- Lowell Grand Banks Dory
- Finished
And, of course, shorter lengths were employed at the bow and stern! -
Your idea that: "There is a little decorative carving on it but most importantly, it appears to be rotated to starboard and the lower end of the stem head protrudes into the stem." is, I think, misinterpreting the plan. The head knee is central and let in with a shallow scarphed mortise on to the stem head. The shading at the tip of the knee is indicative only of the carved detail. The bowsprit is centered between the two bollard timbers. There is a minimal shallow groove centrally on the breast hook for the bowsprit. I suspect that the stem head proper was cut down and is either shown before it was revised or is erroneously drawn. If the bowsprit were offset, it was more frequently done to starboard, not port. The only reason to offset a bowsprit was to run it inboard past the mast, as on a Revenue cutter. In that case, it would never be lashed to the knee of the stem as shown. Other opinions?
