Everything posted by druxey
I use several layers of material because, as you point out, the holes in gauze/cheesecloth are quite large. Your solution sounds more efficient!
The saws that cut the wood that made the ships.
druxey replied to bruce d's topic in Nautical/Naval History
Bruce: you turn up the most interesting papers! Thank you for this one. -
The gods smiled on you, Gary? I'll say!! You were very fortunate. The base looks terrific and compliments the fabulous model perfectly. A great finish. Now, what's next? We are waiting....
Easy questions, Gary! The placement of the hanging knee to the beam was on the fore side forward and aft side aft. See: https://collections.rmg.co.uk/collections/objects/384163.html although this is an earlier 1709 example. As for cast knees, they were shaped from compass timber, so curved, twisted pieces would have been selected for best grain direction and strength, plus minimum wastage. (Think of the bottom of the trunk and main root area.)
The rudder coat, as it was called, was nailed around the rudderhead a little below the opening in the counter. Imagine an open umbrella, but the rudderhead in the center instead of the ferrule. The loose outer ends of the canvas were then turned up and nailed around the edges of the opening (the helm port) giving a loose bag-like appearance to it.
Reducing mast circumference without a lathe
druxey replied to Charlie pal's topic in Masting, rigging and sails
Or, if that's not practical, clamp the mast in a vise and pull a strip of sandpaper to and fro across the spar. Rotate it in the vise frequently to ensure that wood is being removed evenly all the way around. Do a section at a time. -
You really should make your 17 year old self take a bow! That top was pretty sophisticated work for a teenager.
- 740 replies
- Tudor
- restoration
(and 4 more)
You may find it easier to lay each strake in two planks so that they fit at stem and stern. Shape the plank ends first, then trim the butt joint to land over the center of a frame.
- 179 replies
- longship
- Helga Holm
A little too long is always better than a little too short! Nice progress, bolin.
- 179 replies
- longship
- Helga Holm
A Model Builder’s Cabin
druxey replied to Tim Moore's topic in Modeling tools and Workshop Equipment
Enjoy your new space, Tim! As for ceramics, the mess would be difficult to reconcile with model-making in the same space. -
Gaff sails and backstay rigging rules
druxey replied to Michelnou's topic in Masting, rigging and sails
All supporting rigging is strongest in 'tripod' configuration, so I supposed fore stays and shrouds would probably do it. However, I suspect running backstays added would make for 'belt and braces' - literally! - in severe weather conditions. -
Or that the found object - in fact, a pulley or sheave - has been 'decorated' with line. The condition of the line (and in particular, the worming) does not look as old as the sheave!
Ah - a true ship modeler! Can't let it go until it's right. And, of course, it looks so much better now.
Buxbaum = boxwood. South American 'boxwood' or Castello is a pale orange-yellow to yellow-brown with extremely fine grain. Some pieces can be brittle, but most can be bent with care using steam or dry heat. This specie is excellent for carving. Beech (IMHO) is a lovely specie - for cabinetwork. The grain in most pieces is too prominent for model work.
Paper on HMS Swift: British Sloop-of- War lost off Patagonia 1770
Always finding neat reading matter! Thank you, Bruce, for sharing this. -
Do you have decimal reading calipers? That would be the most direct way.
Terrific setting, Hellmuht! A beautiful piece of work all round. Well done.
- 158 replies
- byblos ship
- Egyptian
Excellent! Thank you for bringing this to our attention, Bruce.
For an ambitious 'first' project, this looks pretty good, Nicholas. Bien fait, monsieur!
