druxey
Everything posted by druxey
  1. A few more random thoughts: When I went to purchase my first drafting board (wasit really nearly 50 years ago?) I looked at a 4' 0" one and was advised that 5' 0" would be better in the long run. Didn't that turn out to be too small! I 'upgraded' to a 6' 0" board a few years later. A big, solid vintage board it is - I still use it today, My school (British, public) did not offer any technical courses whatsoever. So I taught myself the fundamentals and then more advanced work such as producing two and three point perspectives from floor plans and elevations. I became proficient enough to be engaged by architectural companies to produce renderings for them. Later, as a theatrical designer, I channelled these skills into both working drawings for set construction as well as accurately render sets from an audience POV. It was gratifying to get feedback from construction and painting crews that my work was the easiest that they ever received to work from. Season's greetings to all readers!
  2. Most folk think wood is uniform in consistency, but it is not. While a plank may stay fairly stable in length, its width can change quite a bit, as Bob has pointed out. Try to keep models at a consistent humidity level if you can. Temperature change has a less, but still appreciable, effect.
  3. Small scans are done at home, but large 24" x 36" sheets are taken to a local architectural reproduction/sign company office where I have the sheet(s) scanned at 300 dpi. The resulting scan is imported into any vector program such as Illustrator or whatever.
  4. Tim wrote: I'm just curious, does anyone still sit at a drafting board and design and draw anymore? Actually, yes. I do preliminary drafting that way, scan and then transfer to computer. After years at a conventional drawing board equipped with a rail machine, I find it a rapid process to start with. Jaager: I feel for your frustration with Deane. I think that there are errors either in his instructions or in the transcription. There is a small international group researching how hulls were drafted back in the 1680 time period. Slowly the 'shipwrights' secrets are being unravelled! All the evidence points to various ingenious mathematical and geometrical constructions by different designers such as Pett and Deane.
  5. Just catching up, Tom. Congratulations on a fine result. Just make sure that the model is not in direct sunlight on the sill there. Heat and light - particularly if uneven on both sides - do horrible things to models.
  6. I notice quite a jump in date stamps. Is this project still under way?
  7. Yes, it's best to get back in the saddle, Mark. As others have said, we've all made silly mistakes at one time or another. Onward and upward!
  8. Nice to see you back on this project, Allan! It has been a while, hasn't it?
  9. Rasps are good for rough-shaping solid wood hulls. However, if you try to shape a framed hull that way, you will get chip-out of the frames on the 'far' side of the cut. A great way to destroy hours of careful framing! I use my beautifully made Auriou rasps only on furniture related activities.
  10. Best wishes for the holiday season, Siggi
  11. Terrific detail: I love the fact you included the drainage/handhold gaps on the entry steps. So seldom seen on models.
  12. Love the details of the locks! Terrific work.
  13. While the above information and personal experience is interesting as well as eliciting my sympathy, we seem to have wandered a long way from chisels and edge tools in general, which is what the original enquiry was all about!
  14. I absolutely agree with Jim! Buy cheap and repent at leisure. If you can't afford a full set of quality chisels, just buy two different sizes and add to as needed and budget affords. You won't regret it. As for internal frame fairing, I simply use a shallow Pfeil palm gouge, then shaped sanding blocks. Not chisels.
  15. Part of the issue here is folk like Gary and myself giving you instructions from the cheap seats! Or is that the cheap sholes?
  16. That's a great start and yes; things get easier and faster with practice, or we'd never finish a model!
  17. There may be a hammer, JD, but it won't be tiny and will be heading at high speed directly at you. I understand Toni has good aim.
  18. Now, now, JD! Stop putting ideas into people's heads.
  19. The sails are more likely to be of parchment paper. These 'galleons' were very popular decorative items after the First World War.
