Everything posted by druxey
CipperFan: get better first, and hopefully with an uneventful recovery. That is more important. I'm sure Rob can wait!
- 3,560 replies
- clipper
- hull model
Well done indeed, Steven. It has been interesting to follow your journey into uncharted territory and ending up with a plausible result. I've enjoyed the presentation of what evidence you had in order to arrive at an outstanding conclusion. And thank you for putting up with my admittedly terrible puns.
Looks as if Gregory's captive audience looks none too happy. "I have to row and listen to him?" The Madrid image has the steersman using a double-handed grip, I note.
Swan-Class Sloop by Stuglo - FINISHED - 1:48
druxey replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Sure gives you an appreciation for the shipwrights of old and why apprenticeships were seven years long. You worte: "Marvellous how alcohol helps a problem." One way or another!- 475 replies
Without seeing the actual model, I really wouldn't want to advise you of the best course to take. Perhaps more photos might make the situation clearer to see.- 475 replies
At each step, be as accurate as you possibly can be. Cumulative error adds up very quickly. Errors never seem to cancel each other out! For cant frames and hawse pieces, check all these factors: 1) Angle of foot 2) Height of step 3) Height from the board to the toptimber line 4) Verticality 5) For hawse timbers, the accumulated width across them as you add each one 6) For cant frames, making sure that the sided dimension (thickness ) at the foot is correct and does not push the next cant off its step 7) Width must equal that of the maximum breadth on the baseboard- 475 replies
When starting out using silver solder, there will be more failures than successes. However, after a while, success will become routine stuff. Occasionally, though, there will be a day where nothing goes right. I had one of those last week. Either the wind was in the wrong direction, the milk had gone sour or I'd stepped on the cat, but when one experiences failure after failure, walk away. The next day I nailed it first time. There's alchemy in there somewhere....
The other possibility is to reduce the gas flow on the torch (if you can) so that the flame does not blow away the silver solder paillon.
I guess that the windlass won't wind, alas! It's interesting the things one discovers on the journey of a build. Either "They can't possibly have done that like that," or "Aha! So that what that's for!".
