druxey
Everything posted by druxey
  1. Ad infinitum or ad nauseam, HH? Example of capsquare attached to a 12lb carronade carriage. Admittedly it is at 1:48 scale, but on a carriage that size they are pretty small!
  2. OK, oh OCD one: what about the hinge on one end and the square hole at the other?
  3. Morgan: I would agree with your assessment of the 'stand-off' effect of the cleats, as well as preventing the breeching from hanging up on top of the front of the cheek.
  4. Gee, that's the Rolls Royce version, Mark. Mine was a Ford: just a half-round the diameter of the trunnion glued to a flat surface. The strip of copper was pressed down using a suitable pair of tweezers on edge each side of the half-round. Worked fine. I am definitely not my father's son! (See previous comment).
  5. Ah yes, the good old (literally) 'thorn' that looks like a 'y' ( as in ye olde). I suppose, Steven, that the Anglo-Saxon Beowulf is your bed-time reading? I like Seamus Heaney's translation, although I hear that a new really good version has just been published. But I digress!
  6. Para Handy - I love your 'handle' and reference to those Neil Munro stories! - I agree completely with your assessment of the various tool brands. Some are "Chust sublime!"
  7. I think you've got the idea now!
  8. Sometimes explosive effects are very strange.
  9. Yes, there was a move to run the breeching line through the large ring bolts in order to control a gun 'jumping' on recoil.
  10. Was the pigtail of L'Orient's conductor bent by the explosion?
  11. No, Jim, you are thinking of formal dessert! Welcome to the silliness that is MSW, jdowney.
  12. No, Tom, the shaped moldings are parallel (when seen from the side) to the ship's sheer (the upward curve). Also, the timberheads 'lean in' according to the tumblehome at the top of the ship's side, so their tops are horizontal as seen from ahead or astern. Complex geometry, varying for each timberhead, that many modelers avoid - but not Alex!
  13. For anyone interested in learning to read old 'hands' such as the sample posted by Allan, there is an excellent free self-tutorial course from the British National Archives. Start here! https://www.nationalarchives.gov.uk/help-with-your-research/reading-old-documents/ The perfect way to educate yourself while waiting for the pandemic to pass....
  14. Each timberhead top has a slightly different angle to it, depending on the ship's sheer. Therefore one has to cut the tops by hand for the best result.
  15. And, of course, the double-s at the end of words like 'exprefs'. In English typesetting the long 's' was used at the beginning of word. One unfortunate example I came across referred to brake pumps as 'sucking pumps', except that the first 's' looked like an 'f'!
  16. One of my father's aphorisms was "Why make a thing simple if you can make it complicated?" Yes, he was an electrical and mechanical engineer!
  17. Keith: The letter you refer to was in common ufe (sorry, use) until about 200 or so years ago. It was known as the 'long s'. If you read many 17th and 18th century texts, you get used to the convention and read it as 's', not 'f'. If you look carefully the crossbar is only to the right of the upright; it does not cross it like the letter 'f'.
  18. What about a simpler solution? Install the carriages as you suggest, but leave off the capsquare. Instead, pre-attach them to the guns' trunnions and insert as a complete unit later. A spot of epoxy on the underside of the trunnion and, voila!
  19. Your wife already has designs on you? That's not a good sign, Mark! Yes, being patient with dilute blackener gives far better results, I find. It usually takes two to five minutes, depending on how fresh the solution is. I still buff the finished pieces to rub off any slight 'soot'.
  20. You need to study a copy of a framing plan to fully understand what you need to do.
  21. So true, Vaddoc!
