druxey
Everything posted by druxey
  1. Yes, there was a move to run the breeching line through the large ring bolts in order to control a gun 'jumping' on recoil.
  2. Was the pigtail of L'Orient's conductor bent by the explosion?
  3. No, Jim, you are thinking of formal dessert! Welcome to the silliness that is MSW, jdowney.
  4. No, Tom, the shaped moldings are parallel (when seen from the side) to the ship's sheer (the upward curve). Also, the timberheads 'lean in' according to the tumblehome at the top of the ship's side, so their tops are horizontal as seen from ahead or astern. Complex geometry, varying for each timberhead, that many modelers avoid - but not Alex!
  5. For anyone interested in learning to read old 'hands' such as the sample posted by Allan, there is an excellent free self-tutorial course from the British National Archives. Start here! https://www.nationalarchives.gov.uk/help-with-your-research/reading-old-documents/ The perfect way to educate yourself while waiting for the pandemic to pass....
  6. Each timberhead top has a slightly different angle to it, depending on the ship's sheer. Therefore one has to cut the tops by hand for the best result.
  7. And, of course, the double-s at the end of words like 'exprefs'. In English typesetting the long 's' was used at the beginning of word. One unfortunate example I came across referred to brake pumps as 'sucking pumps', except that the first 's' looked like an 'f'!
  8. One of my father's aphorisms was "Why make a thing simple if you can make it complicated?" Yes, he was an electrical and mechanical engineer!
  9. Keith: The letter you refer to was in common ufe (sorry, use) until about 200 or so years ago. It was known as the 'long s'. If you read many 17th and 18th century texts, you get used to the convention and read it as 's', not 'f'. If you look carefully the crossbar is only to the right of the upright; it does not cross it like the letter 'f'.
  10. What about a simpler solution? Install the carriages as you suggest, but leave off the capsquare. Instead, pre-attach them to the guns' trunnions and insert as a complete unit later. A spot of epoxy on the underside of the trunnion and, voila!
  11. Your wife already has designs on you? That's not a good sign, Mark! Yes, being patient with dilute blackener gives far better results, I find. It usually takes two to five minutes, depending on how fresh the solution is. I still buff the finished pieces to rub off any slight 'soot'.
  12. You need to study a copy of a framing plan to fully understand what you need to do.
  13. So true, Vaddoc!
  14. I used to use sanding sealer as Greg does, but haven't now in some time. I leave natural wood in its natural state, just finished either by scraping or 240 grit paper. Wood will change color over time anyway, due to light and oxygen in the air. Accept it!
  15. Just found your thread, Håken. You are doing a lovely job on her!
  16. Another interesting paper! Thank you, Bruce.
  17. C'est interessant, messieurs; mais écrivez en Anglais, SVP! This interesting, gentlemen, but write in English, please!
  18. An interesting arrangement, Clare. 'Ingrown channels' sounds like a painful condition! Looking good, though.
  19. Fincham is, unfortunately almost a century later (1851). Although changes were slow in the 1700's, they rapidly advanced in the Industrial Age with more iron and steel production, composite hulls and then all-metal ones.
