Everything posted by druxey
Unfortunately Goodwin's Alert volume has a number of issues, this being another that I hadn't picked up on before. As far as I know, the rove is what tightens up the connection as the nail point is hammered back over it. There is a leverage effect. Perhaps a search of clench construction online might - um - clinch the issue for you!
I wouldn't recommend 'sunning' a model. There are detrimental ultraviolet rays as well as heat - neither of which will do a model any good in the long run. Also, humidity levels wll drop in the sun, and Ben can tell you all about the trouble that can bring to a model! Much of wood color change is due to surface oxidation from the atmosphere. It will darken wood over time indoors anyway.
- 889 replies
Museum Researcher looking for assistance
druxey replied to FRMResearcher's topic in New member Introductions
From the appearance of the model in the photograph, its age looks to be less than 50 years and the estimate of about 25 to 40 seems about right. -
George: Just found your very interesting and informative log. Nice work so far! It's always great to see more unusual subjects modelled.
From Wikipedia: With copper or iron rivets consisting of a square nail and a dish shaped washer called a rove. The land is pierced, the nail knocked through from the outside, the rove punched on while the head is held up by a dolly (a small portable anvil, usually of cylindrical shape). The nail is cut off just proud of the rove and the cut end clenched over the rove while the dolly is used to hold the nail in place. In planking up clinker work, one man can hold both dolly and clenching hammer. From Steel's Naval Architecture: CLINCHING or CLENCHING. Spreading the point of a bolt on a ring, &c. by beating it with a hammer, in order to prevent it drawing.
An impressive start with steps 1 to 5 repeated. Try not to achieve step 6, please, Toni! See you in December....
Sloop from Roslagen by bolin - FINISHED - 1:50
druxey replied to bolin's topic in - Build logs for subjects built 1851 - 1900
Tak! -
You should patent this design and get Byrnes Machine Tools to manufacture it under license! It is far superior to the usual plastic cutters.
ancre La Belle 1684 by Oliver1973 - 1/36
druxey replied to Oliver1973's topic in - Build logs for subjects built 1501 - 1750
Erstaunlich! Beautifully done, Oliver! -
A friend of mine years ago owned a small 16th century cottage in Suffolk (England), built between two even older houses. The place was perhaps 12' 0" wide (4 m) with one room up, one room down. The adjacent buildings' walls were common to his 'new' house. A quaint feature was the upstairs room, nominally the bedroom. The ceiling was perhaps 5' 6" high at the walls. However, over the centuries the ceiling had sagged so that it was more than a foot lower in the center of the room. It gave the impression of a large canvas sail or hammock. Bathroom? Septic system out back and an outhouse. I helped him dig out for the tank. The ground was heavy clay. I was 19 at the time, thank goodness!
Welcome, Colin! I believe that you have a rather nice maritime museum up your way....
Just found your log, bolin. It's always nice to see a model of a less usual subject. You are coming along well with her. -
Swan-Class Sloop by Stuglo - FINISHED - 1:48
druxey replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Hope you heal without complications. Sorry to read of your 'lapse'. Never use power tools when tired or distracted.- 475 replies
Anthony (and everyone else); SeaWatch is a small 'mom and pop' show. They have punched way over their weight for many years. The owner has had serious health problems, however everyone gets their books eventually. Please have some understanding and patience with them. Also the USPS has, as you may know, some issues lately as well!
Bit late to comment, but I recall coal being poured from sacks down coal holes when I was very young.
re: pillars under beams. I don't know about French practice, but the British used a mortise in the beam above to fit the tenon on the upper end of the pillar. On the deck there was a shallow inclined slot so that the post located properly with a ramped tenon. It could still easily be knocked out with a blow or two - in the correct direction.
If that soft, then possibly basswood. Lime (a similar specie) is a bit harder and takes crisp detail. It was used extensively by Grinling Gibbons. See: https://www.telegraph.co.uk/comment/letters/9036493/Horace-Walpoles-wondrous-wooden-necktie.html https://www.geraldblandinc.com/tables/grinling-gibbons-console
- 2,699 replies
- heller
- soleil royal
(and 9 more)
