Everything posted by druxey
Congratulations, Dan. I agree that the light maple base drew the eye too much away from the model. A good decision to stain it. Well done all round.
- 287 replies
- michelangelo
- ocean liner
I've never seen a Fearsome Step Drill before. I'd be terrified to use it on anything, let alone my model! You must have nerves of steel.
Girona by augustus
druxey replied to augustus's topic in - Build logs for subjects built 1501 - 1750
Don't the side planks curve up more to match the top of the sides? -
You may need to take an average reading between uncompressed and maximum compression, Rob.
- 3,618 replies
- young america
- clipper
HMS ANSON 1781 by albert - 1/48 - 64 guns
druxey replied to albert's topic in - Build logs for subjects built 1751 - 1800
Very, very organized and neat as well, Albert! -
Nice painting. It could use a clean and revarnish to bring out the true colors. Hopefully you have a professional conservator nearby: that painting is worth it.
- 1,208 replies
- great republic
- clipper
If a thread is laid up right handed, and you need to spin a right-handed line, all you need do is 'unspin' the separate strands (threads) first. As the headstock turns the strands will slacken, so move the tailstock away from the headstock. At a certain point the strands will commence to lay up again left-handed and you will see the tailstock begin to move toward the headstock. Check with a loupe until the strands are fully laid left-handed and continue to spin your line as usual.
- 3,618 replies
- young america
- clipper
Grumble about the time it takes to 'treenail'? Try a ship of the line! Seriously, your model looks very nice, Chuck. One question: weren't bottom boards removable for bailing and repair purposes? If so, that means less treenails!
- 421 replies
- medway longboat
- Syren Ship Model Company
If you decide you'd like to try ship model-making, you will find plenty of willing, friendly hands to offer tips and advice in support of your efforts.
Cutting Planks
druxey replied to sfotinos's topic in Building, Framing, Planking and plating a ships hull and deck
I cut the planks either side of a port slightly overlength then, using a sanding stick with beveled sides away from the sandpaper face, gently sand to the frame edge. To keep the port square athwartships, the stick is rigid and long enough to pass through the port opposite. -
White caulking?
druxey replied to Bare_Koala's topic in Building, Framing, Planking and plating a ships hull and deck
If it is a large scale model, thin plastic sheet does nicely. -
Ten! Those are the most pintles and gudgeons I've ever seen on one rudder! Well done - such neat work!
- 487 replies
- ship of the line
- 80 guns
Sorry you are under the weather: I hope you recover soon, Rob. What you did get done looks neat, though.
- 1,208 replies
- great republic
- clipper
Caroline's bottom
druxey replied to GrantGoodale's topic in Building, Framing, Planking and plating a ships hull and deck
That is an interesting theory, John. Thank you, and see Dafi's post #20. Also, one would hardly describe studded nails as a 'coat'. This implies a mixture applied by brush (e.g. "a coat of paint"). Also, copper nails would surely last longer than over a single winter. Copper apparently turns green only at the waterline where there is more oxygen exposure: it would turn brownish underwater. -
Girona by augustus
That's a fair size model. Should keep you busy for the winter: I hear you've already had a good snowfall!
