Everything posted by druxey
Need help with saw blade output
druxey replied to bigcreekdad's topic in Modeling tools and Workshop Equipment
And, unfortunately, I can tell stories of severed digits (not my own - I still have all ten and intend to maintain that number!) -
Respect is a good attitude to have! -
I was not being flippant. It's all too easy to have an accident if you aren't well versed in saw usage. From your questions I presumed that you are not that familiar with the subject. I'd rather you were safe than sorry. -
You might also want to read up on safe techniques when using power saws. -
Usually, as mentioned, the inner end of the boom was drilled with a hole. A length of line, knotted at one end, was passed through this hole, then around the boom and yard several times. The line was then hove tight with several round turns taken between the yard and boom and finished with a couple of half hitches.
That fascinating fitting is new to me. Lovely work so far!
- 3,618 replies
- young america
- clipper
Interesting method of construction, Dick.
- 263 replies
- nave tonda
- round ship
Very nice sheet metalwork, Valeriy. Do you use a soldering iron or resistance soldering?
Brilliant, as usual, Doris!
- 1,035 replies
- royal katherine
- ship of the line
In some of those photos it's hard to realize how small the model really is! Nice going, Rob.
- 1,208 replies
- great republic
- clipper
Interesting set-up for the main sheet that you have there, Mark. A snap block is called a snatch block here. Beautiful work, as usual!
1.5mm layer height is enormous! 0.1 to 0.2mm would be much, much better and capture the detail you so carefully created. Again, consider printing in vertical sections to further minimize stepping.
- 125 replies
- 9 pound naval cannon
- 3d cannon barrel
I think that the printer used has too coarse a resolution for what you need, Alan.
- 125 replies
- 3d cannon barrel
The latter painting appears to have some of her sails aback in order to brake the ship's speed, not to change tack.
- 1,208 replies
- great republic
- clipper
I've tried Frog tape and found its tack still an issue. I've used Tamiya flexible tape with much more success.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Well done, Dan. Now enjoy holidays and the family!
- 238 replies
- leviathan
- troop ship
I'm impressed by the time and care you are taking in evaluating various paints and finishes, Marc. Theatrical set painters know how a single color looks 'flat', especially under stage lighting. There are always wash coats and spatters to enliven the surface, as well as wear and weathering techniques that bring things to life. You are doing exactly the same in miniature. Well done!
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Part of the texture issue may be the limitation of the printer. Ideally it should have been printed in one piece and done vertically. Obviously that printer couldn't 'stack' a piece that tall. Could it be re-printed in vertical sections with the joint lines at the reinforcement junctions?
- 125 replies
- 3d cannon barrel
Oooh! Much nicer, Michael. It was time well spent on the re-do.
- 2,214 replies
