Everything posted by druxey
HMS ANSON 1781 by albert - 1/48 - 64 guns
druxey replied to albert's topic in - Build logs for subjects built 1751 - 1800
The collection of completed frames in the photo really demonstrates the quantity of wood a ship's framing consumed. Very nicely done, Albert. -
Frank: I'm sorry to read that you have other more pressing matters right now, and hope that they are not too serious. Best wishes while your attention is focussed on these. We can wait until you return.
Venting a case will help, but not necessarily eliminate the issue. Sealing lead-bearing metal parts before they deteriorate with something like clear nail varnish will also help, but is no guarantee against break-down over time. The most effective measures? Never use lead or white metal parts. Replace them with lead-free fittings and dispose of the originals using hazardous materials handling and at a suitable waste facility.
Congratulations, Dan. I agree that the light maple base drew the eye too much away from the model. A good decision to stain it. Well done all round.
- 287 replies
- michelangelo
- ocean liner
I've never seen a Fearsome Step Drill before. I'd be terrified to use it on anything, let alone my model! You must have nerves of steel.
Girona by augustus
druxey replied to augustus's topic in - Build logs for subjects built 1501 - 1750
Don't the side planks curve up more to match the top of the sides? -
You may need to take an average reading between uncompressed and maximum compression, Rob.
- 3,618 replies
- young america
- clipper
Very, very organized and neat as well, Albert! -
Nice painting. It could use a clean and revarnish to bring out the true colors. Hopefully you have a professional conservator nearby: that painting is worth it.
- 1,208 replies
- great republic
- clipper
If a thread is laid up right handed, and you need to spin a right-handed line, all you need do is 'unspin' the separate strands (threads) first. As the headstock turns the strands will slacken, so move the tailstock away from the headstock. At a certain point the strands will commence to lay up again left-handed and you will see the tailstock begin to move toward the headstock. Check with a loupe until the strands are fully laid left-handed and continue to spin your line as usual.
- 3,618 replies
- young america
- clipper
Grumble about the time it takes to 'treenail'? Try a ship of the line! Seriously, your model looks very nice, Chuck. One question: weren't bottom boards removable for bailing and repair purposes? If so, that means less treenails!
- 421 replies
- medway longboat
- Syren Ship Model Company
If you decide you'd like to try ship model-making, you will find plenty of willing, friendly hands to offer tips and advice in support of your efforts.
Cutting Planks
druxey replied to sfotinos's topic in Building, Framing, Planking and plating a ships hull and deck
I cut the planks either side of a port slightly overlength then, using a sanding stick with beveled sides away from the sandpaper face, gently sand to the frame edge. To keep the port square athwartships, the stick is rigid and long enough to pass through the port opposite. -
White caulking?
druxey replied to Bare_Koala's topic in Building, Framing, Planking and plating a ships hull and deck
If it is a large scale model, thin plastic sheet does nicely. -
Ten! Those are the most pintles and gudgeons I've ever seen on one rudder! Well done - such neat work!
- 487 replies
- ship of the line
- 80 guns
Sorry you are under the weather: I hope you recover soon, Rob. What you did get done looks neat, though.
- 1,208 replies
- great republic
- clipper
