Everything posted by druxey
Many early models show no bobstay, and I would agree that the jib outhaul passes through a block at the side of the stem.
- 102 replies
- speedy
- model shipwright
Atlantis by Thistle17 - FINISHED - Robbe
druxey replied to Thistle17's topic in RC Kits & Scratch building
Lovely work, Joe. Have a safe trip transporting her (or should that be 'herself'?) to her new berth. -
When forming brass - or silver, for that matter - one cannot anneal too often. If you don't, the metal will tear. Beautifully done, Michael. That is a tough shape to achieve.
- 2,214 replies
Using a moulding scraper tool?
druxey replied to alde's topic in Modeling tools and Workshop Equipment
My watchmakers' screw slotting files go down to a little under 0.010" wide. Unlike fret files, they cut a square bottom slot. Jewellers' saw blades are a good and cheaper alternative! -
Any guitar fret file I've ever seen is far larger and rounded compared to the minute watchmakers' screw slotting ones. -
HMCSS Victoria 1855 by BANYAN - 1:72
druxey replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Nice progress, Pat. Are there really only three turns of line around the drum of the wheel?- 1,005 replies
- gun dispatch vessel
- victoria
It's not cheap, but a watchmakers' screw slotting file is perfect for fine detailed profiles. -
Chuck's comments on planking (post #131) are right on. We have so many older books that have brainwashed us into wrestling straight planks into shapes they can't assume, using so many clamps, pins and hold-downs of every variety. Most of this received wisdom needs to be challenged. If you planks are properly spiled and shaped, of a suitable specie of wood to the correct thickness, bent using moisture, heat or a combination thereof, you should never need to clamp them!
- 421 replies
- medway longboat
- Syren Ship Model Company
The icing on the cake, eh, Toni? Looks good.
- 1,449 replies
Cool old sail ship request for info please
druxey replied to Muskies's topic in New member Introductions
Please send the buyer my way. I have this rather large bridge for sale, you see.... -
I wasn't thinking of the spur as a bridge, Steven; just as a locking device to prevent the vessels drifting apart.
Hurrah! Nice to see her again in her current state, Michael.
- 2,214 replies
Usually blocks are hooked to eyebolts. This means threading a hook onto the strop and seizing it in before wrapping the strop around the block.
Hmm. Food for thought. Was the above-the-waterline spur a device for locking ships together so that the attackers could board?
Ancient galleys had the ram below the waterline: one would want to hole the opposing vessel below the waterline. Much more effective than smashing a few oars and holing the ship above the water!
Sorry to disappoint you , but it's a relatively modern, mass produced 'decorative' model (probably from the Far East) that does not resemble any real ship. It's a total fantasy vessel.
